STM8S 的触摸库是如何在主程序中查询键的呢、
wangdong-365265 提问时间:2012-6-27 17:13 /
试了几天了。看了ST的一个官方说明文件。配置好了各个端口的按键 。可是我不知道如何在主程序中调用触摸键查询子程序获取结果。请高手指点。
以下是我改的配置文件,
#ifndef __TSL_CONFIGURATION__
#define __TSL_CONFIGURATION__
// 1) MCU FAMILY SELECTION
// Uncomment only one line.
//#define STM8L (1)  /**< Select it if the STM8L MCU is used (value not used) */
#define STM8S (1)  /**< Select it if the STM8S MCU is used (value not used) */
// 2) ACQUISITION TIMER SELECTION (TIMACQ)
// Set the acquisition timer name and its counter high register address.
// The timer you select must be a 16-bit timer, have a 8-bit prescaler and
// must be different of the TIMTICK timer described below.
// This table summarizes the values for some products (consult the datasheet
// if your product is not in the list):
// Product                TIMACQ        TIMACQ_CNTR_ADD
// STM8S20x               TIM2          0x530B
//     "                  TIM3          0x5328
// STM8S105               TIM2          0x530B
//     "                  TIM3          0x5328
// STM8S103               TIM2          0x530B
// STM8L101               TIM2          0x525B
//     "                  TIM3          0x528B
#define TIMACQ           (TIM3)
#define TIMACQ_CNTR_ADD  (0x5328)
// 3) GENERIC TIMEBASE TIMER SELECTION (TIMTICK)
// Set the generic timebase timer.
// The timer you select must be a basic 8-bit timer and must be different
// of the TIMACQ timer described above.
// Product                TIMTICK
// STM820x                TIM4
// STM8S105               TIM4
// STM8S103               TIM4
// STM8L101               TIM4
// Warning: The selected timer update/overflow interrupt vector must point to
// the TSL_Timer_ISR() interrupt routine.
#define TIMTICK         (TIM4)
// 4) REFERENCE LOAD I/O DEFINITION
// Set the port
// Set the pin mask
#define LOADREF_PORT_ADDR  (GPIOB_BaseAddress)  /**< LOADREF pin GPIO base address */
#define LOADREF_BIT        (0x40)               /**< LOADREF pin mask */
// 5) SINGLE CHANNEL KEYS DEFINITION - PORT 1
// Set the number of keys
// Set the port
// Set the pins mask
// Warning: This port is mandatory and one key at least must be defined.
#define SCKEY_P1_KEY_COUNT  (3)  /**< Single channel key Port 1: Number of keys used (value from 1 to 8) */
#define SCKEY_P1_PORT_ADDR  (GPIOB_BaseAddress)  /**< Single channel key Port 1: GPIO base address */
#define SCKEY_P1_A  (0x02)  /**< Single channel key Port 1: 1st key mask */
#define SCKEY_P1_B  (0x04)  /**< Single channel key Port 1: 2nd key mask */
#define SCKEY_P1_C  (0x08)  /**< Single channel key Port 1: 3rd key mask */
#define SCKEY_P1_D  (0)     /**< Single channel key Port 1: 4th key mask */
#define SCKEY_P1_E  (0)     /**< Single channel key Port 1: 5th key mask */
#define SCKEY_P1_F  (0)     /**< Single channel key Port 1: 6th key mask */
#define SCKEY_P1_G  (0)     /**< Single channel key Port 1: 7th key mask */
#define SCKEY_P1_H  (0)     /**< Single channel key Port 1: 8th key mask */
#define SCKEY_P1_DRIVEN_SHIELD_MASK (0x80)
// 6) SINGLE CHANNEL KEYS DEFINITION - PORT 2
// Set the port
// Note: This port is optional. Set SCKEY_P2_KEY_COUNT to 0 to not use this port.
#define SCKEY_P2_KEY_COUNT  (5)  /**< Single channel key Port 2: Number of keys used (value from 0 to 8) */
#define SCKEY_P2_PORT_ADDR  (GPIOG_BaseAddress)  /**< Single channel key Port 2: GPIO base address */
#define SCKEY_P2_A  (0x01)     /**< Single channel key Port 2: 1st key mask */
#define SCKEY_P2_B  (0x02)     /**< Single channel key Port 2: 2nd key mask */
#define SCKEY_P2_C  (0x04)     /**< Single channel key Port 2: 3rd key mask */
#define SCKEY_P2_D  (0x08)     /**< Single channel key Port 2: 4th key mask */
#define SCKEY_P2_E  (0x10)     /**< Single channel key Port 2: 5th key mask */
#define SCKEY_P2_F  (0)     /**< Single channel key Port 2: 6th key mask */
#define SCKEY_P2_G  (0)     /**< Single channel key Port 2: 7th key mask */
#define SCKEY_P2_H  (0)     /**< Single channel key Port 2: 8th key mask */
#define SCKEY_P2_DRIVEN_SHIELD_MASK (0x20)
// 7) SINGLE CHANNEL KEYS DEFINITION - PORT 3
// Set the port
// Note: This port is optional. Set SCKEY_P3_KEY_COUNT to 0 to not use this port.
#define SCKEY_P3_KEY_COUNT  (0)  /**< Single channel key Port 3: Number of keys used (value from 0 to 8) */
#define SCKEY_P3_PORT_ADDR  (0)  /**< Single channel key Port 3: GPIO base address */
#define SCKEY_P3_A  (0)  /**< Single channel key Port 3: 1st key mask */
#define SCKEY_P3_B  (0)  /**< Single channel key Port 3: 2nd key mask */
#define SCKEY_P3_C  (0)  /**< Single channel key Port 3: 3rd key mask */
#define SCKEY_P3_D  (0)  /**< Single channel key Port 3: 4th key mask */
#define SCKEY_P3_E  (0)  /**< Single channel key Port 3: 5th key mask */
#define SCKEY_P3_F  (0)  /**< Single channel key Port 3: 6th key mask */
#define SCKEY_P3_G  (0)  /**< Single channel key Port 3: 7th key mask */
#define SCKEY_P3_H  (0)  /**< Single channel key Port 3: 8th key mask */
#define SCKEY_P3_DRIVEN_SHIELD_MASK (0x00)
// 8) NUMBER OF MULTI CHANNEL KEYS AND NUMBER OF CHANNELS USED
// Set the total number of multi channel keys used (0, 1 or 2)
// Set the number of channels (5 or 8)
#define NUMBER_OF_MULTI_CHANNEL_KEYS  (0)  /**< Number of multi channel keys (value from 0 to 2) */
#define CHANNEL_PER_MCKEY             (5)  /**< Number of channels per key (possible values are 5 or 8 only) */
// 9) MULTI CHANNEL KEY 1 DEFINITION
// Set the port used
// Note: This key is optional
#if NUMBER_OF_MULTI_CHANNEL_KEYS > 0
#define MCKEY1_A_PORT_ADDR  (0)  /**< Multi channel key 1: 1st channel port */
#define MCKEY1_A            (0)               /**< Multi channel key 1: 1st channel mask */
#define MCKEY1_B_PORT_ADDR  (0)  /**< Multi channel key 1: 2nd channel port */
#define MCKEY1_B            (0)               /**< Multi channel key 1: 2nd channel mask */
#define MCKEY1_C_PORT_ADDR  (0)  /**< Multi channel key 1: 3rd channel port */
#define MCKEY1_C            (0)               /**< Multi channel key 1: 3rd channel mask */
#define MCKEY1_D_PORT_ADDR  (0)  /**< Multi channel key 1: 4th channel port */
#define MCKEY1_D            (0)               /**< Multi channel key 1: 4th channel mask */
#define MCKEY1_E_PORT_ADDR  (0)  /**< Multi channel key 1: 5th channel port */
#define MCKEY1_E            (0)               /**< Multi channel key 1: 5th channel mask */
#define MCKEY1_F_PORT_ADDR  (0)                  /**< Multi channel key 1: 6th channel port */
#define MCKEY1_F            (0)                  /**< Multi channel key 1: 6th channel mask */
#define MCKEY1_G_PORT_ADDR  (0)                  /**< Multi channel key 1: 7th channel port */
#define MCKEY1_G            (0)                  /**< Multi channel key 1: 7th channel mask */
#define MCKEY1_H_PORT_ADDR  (0)                  /**< Multi channel key 1: 8th channel port */
#define MCKEY1_H            (0)                  /**< Multi channel key 1: 8th channel mask */
#define MCKEY1_TYPE (1)                          /**< Multi channel key 1 type: 0=wheel, 1=slider */
#define MCKEY1_LAYOUT_TYPE (0)                   /**< Multi channel key 1 layout type: 0=interlaced, 1=normal */
#define MCKEY1_DRIVEN_SHIELD_MASK (0x00)
#endif
// 10) MULTI CHANNEL KEY 2 DEFINITION
// Note: This key is optional.
#if NUMBER_OF_MULTI_CHANNEL_KEYS > 1
#define MCKEY2_A_PORT_ADDR  (0)                  /**< Multi channel key 2: 1st channel port */
#define MCKEY2_A            (0)                  /**< Multi channel key 2: 1st channel mask */
#define MCKEY2_B_PORT_ADDR  (0)                  /**< Multi channel key 2: 2nd channel port */
#define MCKEY2_B            (0)                  /**< Multi channel key 2: 2nd channel mask */
#define MCKEY2_C_PORT_ADDR  (0)                  /**< Multi channel key 2: 3rd channel port */
#define MCKEY2_C            (0)                  /**< Multi channel key 2: 3rd channel mask */
#define MCKEY2_D_PORT_ADDR  (0)                  /**< Multi channel key 2: 4th channel port */
#define MCKEY2_D            (0)                  /**< Multi channel key 2: 4th channel mask */
#define MCKEY2_E_PORT_ADDR  (0)                  /**< Multi channel key 2: 5th channel port */
#define MCKEY2_E            (0)                  /**< Multi channel key 2: 5th channel mask */
#define MCKEY2_F_PORT_ADDR  (0)                  /**< Multi channel key 2: 6th channel port */
#define MCKEY2_F            (0)                  /**< Multi channel key 2: 6th channel mask */
#define MCKEY2_G_PORT_ADDR  (0)                  /**< Multi channel key 2: 7th channel port */
#define MCKEY2_G            (0)                  /**< Multi channel key 2: 7th channel mask */
#define MCKEY2_H_PORT_ADDR  (0)                  /**< Multi channel key 2: 8th channel port */
#define MCKEY2_H            (0)                  /**< Multi channel key 2: 8th channel mask */
#define MCKEY2_TYPE (0)                          /**< Multi channel key 2 type: 0=wheel, 1=slider */
#define MCKEY2_LAYOUT_TYPE (0)                   /**< Multi channel key 2 layout type: 0=interlaced, 1=normal */
#define MCKEY2_DRIVEN_SHIELD_MASK (0x00)
#endif
// 11) ELECTRODES MASKS USED ON EACH GPIO
// Define the electrodes mask for each GPIO used (SCKeys + MCKeys but not LOADREF)
#define GPIOA_ELECTRODES_MASK  (0x00)  /**< Electrodes mask for GPIOA */
#define GPIOB_ELECTRODES_MASK  (0x8E)  /**< Electrodes mask for GPIOB */
#define GPIOC_ELECTRODES_MASK  (0x00)  /**< Electrodes mask for GPIOC */
#define GPIOD_ELECTRODES_MASK  (0x00)  /**< Electrodes mask for GPIOD */
#define GPIOE_ELECTRODES_MASK  (0x00)  /**< Electrodes mask for GPIOE */
#define GPIOF_ELECTRODES_MASK  (0x00)  /**< Electrodes mask for GPIOF */
#define GPIOG_ELECTRODES_MASK  (0x3F)  /**< Electrodes mask for GPIOG */
#define GPIOH_ELECTRODES_MASK  (0x00)  /**< Electrodes mask for GPIOH */
#define GPIOI_ELECTRODES_MASK  (0x00)  /**< Electrodes mask for GPIOI */
// 12) TSL PARAMETERS CONFIGURATION
/** @addtogroup TSL_parameters
// IO acquisition
#define SCKEY_ACQ_NUM                   (1)  /**< Single channel key acquisition number - N (value from 1 to 255) */
#define SCKEY_ADJUST_LEVEL              (2)  /**< Single channel key adjustment level (value from 0 to 255) */
#define MCKEY_ACQ_NUM                   (6)  /**< Multi channel key acquisition number - N (value from 1 to 255) */
#define MCKEY_ADJUST_LEVEL              (2)  /**< Multi channel key adjustment level (value from 0 to 255) */
// IO acquisition number of rejected values and measure guardbands
#define MAX_REJECTED_MEASUREMENTS      (20)  /**< Max number of rejected measurements allowed (value from 0 to 255) */
#define MAX_MEAS_COEFF             (0x011A)  /**< Max measure guardband (MSB=integer part, LSB=decimal part) */
#define MIN_MEAS_COEFF             (0x00E6)  /**< Min measure guardband (MSB=integer part, LSB=decimal part) */
// Thresholds
#define SCKEY_DETECTTHRESHOLD_DEFAULT          (30)  /**< Single channel key detection threshold (value from 1 to 127) */
#define SCKEY_ENDDETECTTHRESHOLD_DEFAULT        (18)  /**< Single channel key end detection threshold (value from 1 to 127) */
#define SCKEY_RECALIBRATIONTHRESHOLD_DEFAULT   (-18)  /**< Single channel key calibration threshold (value from -1 to -128) */
#define MCKEY_DETECTTHRESHOLD_DEFAULT          (30)  /**< Multi channel key detection threshold (value from 1 to 127) */
#define MCKEY_ENDDETECTTHRESHOLD_DEFAULT       (20)  /**< Multi channel key end detection threshold (value from 1 to 127) */
#define MCKEY_RECALIBRATIONTHRESHOLD_DEFAULT  (-20)  /**< Multi channel key calibration threshold (value from -1 to -128) */
// MCKey resolution
#define MCKEY_RESOLUTION_DEFAULT                   (4)  /**< Multi channel key resolution (value from 1 to 8) */
// MCKey Direction Change process
#define MCKEY_DIRECTION_CHANGE_ENABLED               (1)  /**< Multi channel key direction change enable (1) or disable (0) switch */
#define MCKEY_DIRECTION_CHANGE_MAX_DISPLACEMENT    (255)  /**< Multi channel key direction change maximum displacement (value from 0 to 255) */
#define MCKEY_DIRECTION_CHANGE_INTEGRATOR_DEFAULT    (1)  /**< Multi channel key direction change integrator (value from 1 to 255) */
#define MCKEY_DIRECTION_CHANGE_THRESHOLD_DEFAULT    (16)  /**< Multi channel key direction change threshold (value from 1 to 255) */
// Integrators
#define DETECTION_INTEGRATOR_DEFAULT       (2)  /**< Detection Integrator = Debounce Filter (value from 0 to 255) */
#define END_DETECTION_INTEGRATOR_DEFAULT   (2)  /**< End detection Integrator = Debounce Filter (from 0 to 255 */
#define RECALIBRATION_INTEGRATOR_DEFAULT  (10)  /**< Calibration integrator (value from 1 to 255) */
// IIR Filter
#define ECS_TIME_STEP_DEFAULT  (20)  /**< Sampling frequency, multiple of 10ms */
#define ECS_TEMPO_DEFAULT      (20)  /**< Delay after detection, multiple of 100ms */
#define ECS_IIR_KFAST_DEFAULT  (20)  /**< K factor for fast filtering */
#define ECS_IIR_KSLOW_DEFAULT  (10)  /**< K factor for slow filtering */
// Detection Timeout
#define DTO_DEFAULT  (0)  /**< 1s unit (value from 0 (= infinite!) to 255) */
// Automatic Calibration
#define NEGDETECT_AUTOCAL (1)  /**< 0 (Enable negative threshold for noise), 1 (Enable autocalibration)  */
// Acquisition values limits
#define SCKEY_MIN_ACQUISITION   (150) /**< Single channel key minimum acquisition value */
#define SCKEY_MAX_ACQUISITION  (3000) /**< Single channel key maximum acquisition value */
#define MCKEY_MIN_ACQUISITION   (150) /**< Multi channel key minimum acquisition value */
#define MCKEY_MAX_ACQUISITION  (5000) /**< Multi channel key maximum acquisition value */
// Optional parameters for Delta Normalization Process (for Multi channel keys only).
// The MSB is the integer part, the LSB is the real part:
// For example to apply a factor 1.10:
// 0x01 to the MSB
// 0x19 to the LSB (0.1 x 256 = 25.6 = 0x1A)
// Final value to define is: 0x011A
#define MCKEY1_DELTA_COEFF_A (0x011A) /**< MCKey1 Channel A parameter */
#define MCKEY1_DELTA_COEFF_B (0x0100) /**< MCKey1 Channel B parameter */
#define MCKEY1_DELTA_COEFF_C (0x0100) /**< MCKey1 Channel C parameter */
#define MCKEY1_DELTA_COEFF_D (0x0100) /**< MCKey1 Channel D parameter */
#define MCKEY1_DELTA_COEFF_E (0x0100) /**< MCKey1 Channel E parameter */
#define MCKEY1_DELTA_COEFF_F (0x0100) /**< MCKey1 Channel F parameter */
#define MCKEY1_DELTA_COEFF_G (0x0100) /**< MCKey1 Channel G parameter */
#define MCKEY1_DELTA_COEFF_H (0x0100) /**< MCKey1 Channel H parameter */
#define MCKEY2_DELTA_COEFF_A (0x0100) /**< MCKey2 Channel A parameter */
#define MCKEY2_DELTA_COEFF_B (0x0100) /**< MCKey2 Channel B parameter */
#define MCKEY2_DELTA_COEFF_C (0x0100) /**< MCKey2 Channel C parameter */
#define MCKEY2_DELTA_COEFF_D (0x0100) /**< MCKey2 Channel D parameter */
#define MCKEY2_DELTA_COEFF_E (0x0100) /**< MCKey2 Channel E parameter */
#define MCKEY2_DELTA_COEFF_F (0x0100) /**< MCKey2 Channel F parameter */
#define MCKEY2_DELTA_COEFF_G (0x0100) /**< MCKey2 Channel G parameter */
#define MCKEY2_DELTA_COEFF_H (0x0100) /**< MCKey2 Channel H parameter */
// Interrupt synchronisation (Beta)
#define IT_SYNC  (0) /**< Interrupt synchronisation (Beta). (=1) Allow to synchronize the aquisition with a flag set in an interrupt routine */
// Spread spectrum (Beta)
#define SPREAD_SPECTRUM     (0)  /**< Spread spectrum (Beta). (=1) Add a variable delay between acquisitions */
#define SPREAD_COUNTER_MIN  (0)  /**< Spread min value */
#define SPREAD_COUNTER_MAX  (20) /**< Spread max value */
// DEFINITIONS CHECK. DO NOT TOUCH ANYTHING BELOW !!!
#include "STM8_TSL_RC_CheckConfig.h"
#endif /* __TSL_CONFIGURATION__ */
/*********************** (c) 2009 STMicroelectronics **************************/
收藏 1 评论13 发布时间:2012-6-27 17:13
13个回答
沐紫 回答时间:2012-6-28 16:26:40
回复:STM8S 的触摸库是如何在主程序中查询键的呢、
坐等大牛来解决。。。
废鱼 回答时间:2012-6-28 17:05:46
RE:STM8S 的触摸库是如何在主程序中查询键的呢、
你用的是触摸屏还是说触摸按键?
cxzjx-146657 回答时间:2012-6-29 09:10:31
我不用库,也不用C,我用汇编,我设计的汇编程序触摸键都是按次序扫描的,程序执行过程一清二楚,扫描速度,次序都可以自由控制。
蓝调街口-366393 回答时间:2012-6-29 09:31:34
授之以鱼不如授之以渔,楼主请阅读一下此文档,相信会对你的学习有很大收获
stm8s触摸按键.pdf
320.56 KB, 下载次数: 450
as78er96 回答时间:2014-3-7 14:54:36
   继续努力!
如何基于STM8S系列单片机以及触摸式软件库方案进行项目开发.pdf
2.98 MB, 下载次数: 429
luli201007 回答时间:2014-3-12 15:45:08
谢谢楼上。
leefine 回答时间:2016-2-26 22:08:49
   if ((TSL_GlobalSetting.b.CHANGED) && (TSLState == TSL_IDLE_STATE))
                TSL_GlobalSetting.b.CHANGED = 0;
        if (sSCKeyInfo[0].Setting.b.DETECTED) /* KEY 1 touched */
            //asm("nop");
            //__no_operation();
            nop();
            LEDON;
        else
            LEDOFF;
            nop();
zcl201207 回答时间:2016-2-27 23:29:26
buddy_wwq 回答时间:2018-8-7 11:53:08
都是官方文件
炎七炎 回答时间:2018-12-7 10:53:08
谢谢楼上资源!
折翼的信鸽 回答时间:2019-6-13 15:28:18
楼主关于stm8s触摸库使用,同时点击2个按键会锁死,你有碰到过么,如果有方便告知下思路么,感谢
qytcs 回答时间:2019-9-21 22:47:58
各位大神厉害啊学习了
liht1634 回答时间:2021-10-20 11:40:23
路过的。
关于意法半导体
招聘信息
