![shequ.stmicroelectronics.cn](./template/st_v1/static/img/logo2.png)
板子做出来很长时间都问题,前几天在烧写时有一个板子突然出现如下错误,网上搜索答案未果,请大家帮忙看下,谢谢 Contents mismatch at: 08000039H (Flash=FFH Required=14H) ! Contents mismatch at: 0800003AH (Flash=FFH Required=00H) ! Contents mismatch at: 0800003BH (Flash=FFH Required=08H) ! Contents mismatch at: 0800003CH (Flash=FFH Required=E7H) ! Contents mismatch at: 0800003DH (Flash=FFH Required=14H) ! Contents mismatch at: 0800003EH (Flash=FFH Required=00H) ! Contents mismatch at: 0800003FH (Flash=FFH Required=08H) ! Contents mismatch at: 08000040H (Flash=FFH Required=63H) ! Contents mismatch at: 08000041H (Flash=FFH Required=55H) ! Contents mismatch at: 08000042H (Flash=FFH Required=00H) ! Contents mismatch at: 08000043H (Flash=FFH Required=08H) ! Contents mismatch at: 08000044H (Flash=FFH Required=63H) ! Contents mismatch at: 08000045H (Flash=FFH Required=55H) ! Contents mismatch at: 08000046H (Flash=FFH Required=00H) ! Contents mismatch at: 08000047H (Flash=FFH Required=08H) ! Contents mismatch at: 08000048H (Flash=FFH Required=63H) ! Contents mismatch at: 08000049H (Flash=FFH Required=55H) ! Contents mismatch at: 0800004AH (Flash=FFH Required=00H) ! Contents mismatch at: 0800004BH (Flash=FFH Required=08H) ! Contents mismatch at: 0800004CH (Flash=FFH Required=D5H) ! Contents mismatch at: 0800004DH (Flash=FFH Required=14H) ! Contents mismatch at: 0800004EH (Flash=FFH Required=00H) ! Contents mismatch at: 0800004FH (Flash=FFH Required=08H) ! Contents mismatch at: 08000050H (Flash=FFH Required=63H) ! Contents mismatch at: 08000051H (Flash=FFH Required=55H) ! Contents mismatch at: 08000052H (Flash=FFH Required=00H) ! Contents mismatch at: 08000053H (Flash=FFH Required=08H) ! Contents mismatch at: 08000054H (Flash=FFH Required=63H) ! Contents mismatch at: 08000055H (Flash=FFH Required=55H) ! Contents mismatch at: 08000056H (Flash=FFH Required=00H) ! Contents mismatch at: 08000057H (Flash=FFH Required=08H) ! Contents mismatch at: 08000058H (Flash=FFH Required=63H) ! Contents mismatch at: 08000059H (Flash=FFH Required=55H) ! Contents mismatch at: 0800005AH (Flash=FFH Required=00H) ! Contents mismatch at: 0800005BH (Flash=FFH Required=08H) ! Contents mismatch at: 0800005CH (Flash=FFH Required=29H) ! Contents mismatch at: 0800005DH (Flash=FFH Required=15H) ! Contents mismatch at: 0800005EH (Flash=FFH Required=00H) ! Contents mismatch at: 0800005FH (Flash=FFH Required=08H) ! Contents mismatch at: 08000060H (Flash=FFH Required=EBH) ! Contents mismatch at: 08000061H (Flash=FFH Required=14H) ! Contents mismatch at: 08000062H (Flash=FFH Required=00H) ! Contents mismatch at: 08000063H (Flash=FFH Required=08H) ! Too many errors to display ! |
我就是做USB OTG的时候出现的这个问题,之前下载很多次都是好的。能尝试的方法也只有你刚说的方法没试过,因为板子上只有SWD,在下载的时候如果不勾选Verity选项,程序可以下载,但是运行的时候好像是部分代码在运行
我又看到网上有人说是复位电路的原因,也没有说具体是什么原因,害我找了半天硬件复位的原因,也没有找出结果……
然后擦除整个FLASH,还是不行。。。
不知道各位有什么办法没有
还是不行。
检查了没问题
网上说的检查复位电路,我也检查了,也不行。。。
有一个比较低级的错误也会出现你这样类似的提示,比如拿F1(M3)的程序烧写F4(M4)的板子,估计你应该不是这个问题导致的。
我的不是这个原因
是STM32F205RGT6V,用的swd下载的
