错误提示如图所示,主芯片是stm32h743vgt,工具keil5,烧写方式SWD。 另外,CubeMX的debug mode配置如下:
附上初始化代码: / MPU Configuration--------------------------------------------------------/ MPU_Config(); / Enable I-Cache---------------------------------------------------------/ SCB_EnableICache(); / Enable D-Cache---------------------------------------------------------/ SCB_EnableDCache(); / MCU Configuration--------------------------------------------------------/ / Reset of all peripherals, Initializes the Flash interface and the Systick. / HAL_Init(); / USER CODE BEGIN Init / / USER CODE END Init / / Configure the system clock / SystemClock_Config(); 时钟配置(外部25MHz晶振): void SystemClock_Config(void) { RCC_OscInitTypeDef RCC_OscInitStruct = {0}; RCC_ClkInitTypeDef RCC_ClkInitStruct = {0}; /* Supply configuration update enable / HAL_PWREx_ConfigSupply(PWR_EXTERNAL_SOURCE_SUPPLY); /* Configure the main internal regulator output voltage / __HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE1); while(!__HAL_PWR_GET_FLAG(PWR_FLAG_VOSRDY)) {} /** Initializes the RCC Oscillators according to the specified parameters
/* Initializes the CPU, AHB and APB buses clocks / RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK |RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2 |RCC_CLOCKTYPE_D3PCLK1|RCC_CLOCKTYPE_D1PCLK1; RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK; RCC_ClkInitStruct.SYSCLKDivider = RCC_SYSCLK_DIV1; RCC_ClkInitStruct.AHBCLKDivider = RCC_HCLK_DIV2; RCC_ClkInitStruct.APB3CLKDivider = RCC_APB3_DIV2; RCC_ClkInitStruct.APB1CLKDivider = RCC_APB1_DIV2; RCC_ClkInitStruct.APB2CLKDivider = RCC_APB2_DIV2; RCC_ClkInitStruct.APB4CLKDivider = RCC_APB4_DIV2; if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_2) != HAL_OK) { Error_Handler(); } } MPU配置: void MPU_Config(void) { MPU_Region_InitTypeDef MPU_InitStruct = {0}; / Disables the MPU / HAL_MPU_Disable(); /* Initializes and configures the Region and the memory to be protected / MPU_InitStruct.Enable = MPU_REGION_ENABLE; MPU_InitStruct.Number = MPU_REGION_NUMBER0; MPU_InitStruct.BaseAddress = 0x30040000; MPU_InitStruct.Size = MPU_REGION_SIZE_256B; MPU_InitStruct.SubRegionDisable = 0x0; MPU_InitStruct.TypeExtField = MPU_TEX_LEVEL0; MPU_InitStruct.AccessPermission = MPU_REGION_FULL_ACCESS; MPU_InitStruct.DisableExec = MPU_INSTRUCTION_ACCESS_ENABLE; MPU_InitStruct.IsShareable = MPU_ACCESS_NOT_SHAREABLE; MPU_InitStruct.IsCacheable = MPU_ACCESS_NOT_CACHEABLE; MPU_InitStruct.IsBufferable = MPU_ACCESS_BUFFERABLE; HAL_MPU_ConfigRegion(&MPU_InitStruct); /* Initializes and configures the Region and the memory to be protected / MPU_InitStruct.Number = MPU_REGION_NUMBER1; MPU_InitStruct.BaseAddress = 0x30024000;//MPU_InitStruct.BaseAddress = 0x30044000; MPU_InitStruct.Size = MPU_REGION_SIZE_64KB;//MPU_InitStruct.Size = MPU_REGION_SIZE_16KB; MPU_InitStruct.IsCacheable = MPU_ACCESS_CACHEABLE; MPU_InitStruct.IsBufferable = MPU_ACCESS_NOT_BUFFERABLE; HAL_MPU_ConfigRegion(&MPU_InitStruct); / Enables the MPU / HAL_MPU_Enable(MPU_PRIVILEGED_DEFAULT); } |
STM32H743 的ADC线性校准问题
关于STM32WB09例子程序中,是否能够不使用串口的问题,引脚另有他用
关于使用STM32CubeIDE for vscode配置freertos的问题
NUCLEO-H7S3L8开发板,操作板载FLASH出错,无法进入APP
关于STM32WB09使用CUBEMX进行配置的问题
H743 ulpi phy 引脚配置
DMAMUX 使用内部外设Request Event(不使用TIM12和LPTIM)
STM32H747XG下载一次仿真器就检测不到,运行不能正常
——STM32H747XG下载一次仿真器就检测不到,运行不能正常 原理图是否有问
STM32H7开发LWIP时遇到的问题
我以前碰到过,在SYS选项里勾选SW,且SW不得启用第二功能PIN,否则就不能SW下载了。
