USB internal IP DMA
王斯 提问时间:2025-12-25 11:44 / 未解决
大佬们 为什么我的USB不开启internal IP DMA 设备可以正常枚举,开启了后就不行了,是不是哪里需要手动添加配置程序
/ USER CODE BEGIN Header /
  • @file usb_otg.c
  • @brief This file provides code for the configuration
  • of the USB_OTG instances.
  • @attention
  • Copyright (c) 2025 STMicroelectronics.
  • All rights reserved.
  • This software is licensed under terms that can be found in the LICENSE file
  • in the root directory of this software component.
  • If no LICENSE file comes with this software, it is provided AS-IS.
/ USER CODE END Header /
/ Includes ------------------------------------------------------------------/
include "usb_otg.h"
/ USER CODE BEGIN 0 /
/ USER CODE END 0 /
PCD_HandleTypeDef hpcd_USB_OTG_HS1;
/ USB1_OTG_HS init function /
void MX_USB1_OTG_HS_PCD_Init(void)
/ USER CODE BEGIN USB1_OTG_HS_Init 0 /
memset(&hpcd_USB_OTG_HS1, 0x0, sizeof(PCD_HandleTypeDef)); / USER CODE END USB1_OTG_HS_Init 0 /
/ USER CODE BEGIN USB1_OTG_HS_Init 1 /
/ USER CODE END USB1_OTG_HS_Init 1 /
hpcd_USB_OTG_HS1.Instance = USB1_OTG_HS;
hpcd_USB_OTG_HS1.Init.dev_endpoints = 9;
hpcd_USB_OTG_HS1.Init.speed = PCD_SPEED_HIGH;
hpcd_USB_OTG_HS1.Init.phy_itface = USB_OTG_HS_EMBEDDED_PHY;
hpcd_USB_OTG_HS1.Init.Sof_enable = DISABLE;
hpcd_USB_OTG_HS1.Init.low_power_enable = DISABLE;
hpcd_USB_OTG_HS1.Init.lpm_enable = DISABLE;
hpcd_USB_OTG_HS1.Init.use_dedicated_ep1 = DISABLE;
hpcd_USB_OTG_HS1.Init.vbus_sensing_enable = DISABLE;
hpcd_USB_OTG_HS1.Init.dma_enable = DISABLE;
if (HAL_PCD_Init(&hpcd_USB_OTG_HS1) != HAL_OK)
Error_Handler(); }
/ USER CODE BEGIN USB1_OTG_HS_Init 2 /
HAL_PCDEx_SetRxFiFo(&hpcd_USB_OTG_HS1, 0x120);
HAL_PCDEx_SetTxFiFo(&hpcd_USB_OTG_HS1, 0, 0x40);
HAL_PCDEx_SetTxFiFo(&hpcd_USB_OTG_HS1, 1, 0x400);
/ USER CODE END USB1_OTG_HS_Init 2 /
void HAL_PCD_MspInit(PCD_HandleTypeDef* pcdHandle)
RCC_PeriphCLKInitTypeDef PeriphClkInitStruct = {0};
if(pcdHandle->Instance==USB1_OTG_HS)
/ USER CODE BEGIN USB1_OTG_HS_MspInit 0 /
RCC_OscInitTypeDef RCC_OscInitStruct = {0};
RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;
RCC_OscInitStruct.HSEState = RCC_HSE_ON;
if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
    Error_Handler();
/ USER CODE END USB1_OTG_HS_MspInit 0 /
/** Initializes the peripherals clock
PeriphClkInitStruct.PeriphClockSelection = RCC_PERIPHCLK_USBOTGHS1;
PeriphClkInitStruct.UsbPhy1ClockSelection = RCC_USBOTGHS1CLKSOURCE_HSE_DIV2;
PeriphClkInitStruct.UsbOtgHs1ClockSelection = RCC_USBPHY1REFCLKSOURCE_OTGPHY1;
if (HAL_RCCEx_PeriphCLKConfig(&PeriphClkInitStruct) != HAL_OK)
Error_Handler();
/ Enable VDDUSB /
HAL_PWREx_EnableVddUSB();
/ USB1_OTG_HS clock enable /
__HAL_RCC_USB1_OTG_HS_CLK_ENABLE();
__HAL_RCC_USB1_OTG_HS_PHY_CLK_ENABLE();
/ USB1_OTG_HS interrupt Init /
HAL_NVIC_SetPriority(USB1_OTG_HS_IRQn, 0, 0);
HAL_NVIC_EnableIRQ(USB1_OTG_HS_IRQn); / USER CODE BEGIN USB1_OTG_HS_MspInit 1 /
HAL_Delay(1);
USB1_HS_PHYC->USBPHYC_CR &= ~USB_USBPHYC_CR_FSEL;
USB1_HS_PHYC->USBPHYC_CR |= USB_USBPHYC_CR_OTGDISABLE0 | USB_USBPHYC_CR_FSEL_1 | USB_USBPHYC_CR_CMN | USB_USBPHYC_CR_RETENABLEN1;
__HAL_RCC_USB1_OTG_HS_PHY_CLK_ENABLE(); / USER CODE END USB1_OTG_HS_MspInit 1 /
void HAL_PCD_MspDeInit(PCD_HandleTypeDef* pcdHandle)
/ USER CODE BEGIN USB1_OTG_HS_MspDeInit 0 /
/ USER CODE END USB1_OTG_HS_MspDeInit 0 /
/ Peripheral clock disable /
__HAL_RCC_USB1_OTG_HS_CLK_DISABLE();
__HAL_RCC_USB1_OTG_HS_PHY_CLK_DISABLE();
/ Disable VDDUSB /
HAL_PWREx_DisableVddUSB();
/ USB1_OTG_HS interrupt Deinit /
HAL_NVIC_DisableIRQ(USB1_OTG_HS_IRQn); / USER CODE BEGIN USB1_OTG_HS_MspDeInit 1 /
/ USER CODE END USB1_OTG_HS_MspDeInit 1 /
/ USER CODE BEGIN 1 /
/ USER CODE END 1 /
收藏 评论0 发布时间:2025-12-25 11:44
