Build started: Project: LSTM_SOC *** Using Compiler 'V5.06 update 6 (build 750)', folder: 'D:\Keilv5\Keil_v5\ARM\ARMCC\Bin' Build target 'LSTM_SOC' compiling network_data.c... ../X-CUBE-AI/App/network_data_params.h(21): error: #5: cannot open source input file "ai_platform.h": No such file or directory include "ai_platform.h"../X-CUBE-AI/App/network_data.c: 0 warnings, 1 error compiling network_data_params.c... ../X-CUBE-AI/App/network_data_params.h(21): error: #5: cannot open source input file "ai_platform.h": No such file or directory include "ai_platform.h"../X-CUBE-AI/App/network_data_params.c: 0 warnings, 1 error compiling network.c... ../X-CUBE-AI/App/network.h(24): error: #5: cannot open source input file "ai_platform.h": No such file or directory include "ai_platform.h"../X-CUBE-AI/App/network.c: 0 warnings, 1 error compiling app_x-cube-ai.c... ../X-CUBE-AI/App/app_x-cube-ai.h(26): error: #5: cannot open source input file "ai_platform.h": No such file or directory include "ai_platform.h"../X-CUBE-AI/App/app_x-cube-ai.c: 0 warnings, 1 error compiling main.c... ../X-CUBE-AI/App/app_x-cube-ai.h(26): error: #5: cannot open source input file "ai_platform.h": No such file or directory include "ai_platform.h"../Core/Src/main.c: 0 warnings, 1 error "LSTM_SOC\LSTM_SOC.axf" - 5 Error(s), 0 Warning(s). Target not created. Build Time Elapsed: 00:00:01 |
能在一个程序中同时使用TIM的callback和uart的callback函数吗?
Cubemax 生成的文件夹选项包含Core文件夹
多路ADC使用DMA模式有没有教程呀,芯片STM32L151
cubemx升级6.11后,左侧congfiguration选项出不来,鼠标转圈
STM32CubeMX有没有汉化版啊,该怎么搞?
STSPIN32G4内部驱动电压输出问题
STM32G474 发送CANFD数据出现异常,FIFO满,没有bus-off
STM32L051K8U6没有供电时,io是不是高阻态?
重酬找有高频高压放电电源仪器经验的嵌入式软件开发人员合作开发,电源控制
USBH CDC通讯,如何修改通讯波特率?
你好,
这个ai_platform.h是我们STM32Cube.AI runtime的一部分,如果X-CUBE-AI有正常安装的话,生成代码的时候会从它的用户目录下直接将整个Middleware拷贝过来,其中就有这个文件。这个目录在:C:\Users\xxx\STM32Cube\Repository\Packs\STMicroelectronics\X-CUBE-AI\8.1.0\Middlewares\ST\AI。如果你在这个目录找不到这个文件,建议卸载X-CUBE-AI重新安装。如果还是有问题可以把工程发给我看看。我邮箱[email]yijun.deng@st.com[/email]。
[md]我这也有同样的问题,卸载重下也一样,6.0.0版本的,可以加一下qq或者wx交流一下吗
