写eeprom
leaf198310 提问时间:2010-10-14 13:56 /
请问,stm8s103k3内部eeprom写一个字节时间是多少?调用库函数时发现用时超过1ms而且不稳定,有时更高,请高人指点
赞 收藏 评论1 发布时间:2010-10-14 13:56
leaf198310 回答时间:2010-10-14 16:44:48
RE:写eeprom
没人回复呀 附上程序,请帮忙看下哪里耽误了读写的时间
EEPROM.H文件内容:
/* Includes ------------------------------------------------------------------*/
#include "STM8S103k3u.h"
#define FLASH_DATA_START_PHYSICAL_ADDRESS ((unsigned long int)0x004000) /*!< Data EEPROM memory: start address */
#define FLASH_DATA_END_PHYSICAL_ADDRESS   ((unsigned long int)0x00427F) /*!< Data EEPROM memory: end address */
#define FLASH_RASS_KEY1 ((unsigned char)0xAE) /*!< First RASS key */
#define FLASH_RASS_KEY2 ((unsigned char)0x56) /*!< Second RASS key */
unsigned char EEPROM_ReadByte(unsigned long int Address);
void EEPROM_ProgramByte(unsigned long int Address, unsigned char Data);
EEPROM.C文件内容
#include "EEPROM.h"
/* ROUTINE NAME: Check_EEPROM_Address.                                        */
/* INPUT/OUTPUT: EEPROM Target Address.                                       */
/* DESCRIPTION:  Check_EEPROM_Address is available address.                   */
unsigned char Check_EEPROM_Address(unsigned long int Address)
        if(Address >= FLASH_DATA_START_PHYSICAL_ADDRESS && Address
