STM8L-DISCOVERY带的SWIM接口可以对stm8s或stm32芯片进行调试或下载吗?谢谢
jordonwu 提问时间:2011-4-9 09:10 /
下面是STM8L-DISCOVERY 的功能描述,我想问的是STM8L-DISCOVERY带的SWIM接口可以对stm8s或stm32芯片进行调试或下载吗?有没有人试过或者能提供些资料吗(中英文都可以)? 谢谢!
STM8L-DISCOVERY Discovering board for STM8L15x (32KB flash) MCUs
Description
The STM8L-DISCOVERY helps you to discover the STM8L ultralow power features and to develop and share your applications. It is based on an STM8L152C6T6 and includes an ST-Link embedded debug tool interface, LCD (24 segments, 4 commons), LEDs and push buttons.
Key Features
STM8L152C6T6 microcontroller, 32 KB Flash, 2 KB RAM, 1 KB EEPROM in 48-pin LQFP
On-board ST-Link with selection mode switch to use the kit as a stand-alone ST-Link (with SWIM connector for programming and debugging)
Two red LEDs; LD1 for USB communication, LD2 for 3.3 V power on
Designed to be powered by USB or an external supply of 5 V or 3.3 V
Can supply target application with 5 V and 3 V
Two user LEDs, LD3 and LD4 (green and blue)
Two push buttons (User and Reset)
IDD current measurement
LCD 28-pin DIP (24 segments, 4 commons)
Extension header for all QFP48 I/Os for quick connection to prototyping board for easy probing
赞 收藏 评论6 发布时间:2011-4-9 09:10
6个回答
fxw451 回答时间:2011-4-9 09:14:18
RE:STM8L-DISCOVERY带的SWIM接口可以对stm8s或stm32芯片进行调试或下载吗?谢谢
没接触过,过来支持下!
k10k10k10-19309 回答时间:2011-4-9 10:11:23
理论上是可以滴
net1234599 回答时间:2011-4-11 17:39:02
应该可以,我同学买了同一个系列的KIT,可以对STM32调试和下载,所以理论上是可以的!
yinguangwei-173 回答时间:2011-4-11 22:58:59
理论上可以什么概念呢?   我看个那个kit那个套件的原理图调试那块没看明白
wangyin1226 回答时间:2011-4-12 22:26:53
这个是可以的,以前看到别人这样做过,不过比较麻烦一些
dwwzl 回答时间:2012-10-1 12:44:48
回复:STM8L-DISCOVERY带的SWIM接口可以对stm8s或stm32芯片进行调试或下载吗?谢谢
{:tongue:}哪位有多余的STM8L-discovery,我拿其他开发板互换
