新手请教,请各位高手帮忙解释一下下面的程序中ADC,DMA,USART之间怎么联系起来的,通过什么指令联系起来的,如果我用ADC1和ADC2转换两路模拟输入,然后通过USART1和USART2输出,怎么判断ADC是通过USART1输出还是USART2 /******************************************************************************* * Function Name : RCC_Configuration * Description : 系统时钟设置 * Input : None * Output : None * Return : None *******************************************************************************/ void RCC_Configuration(void) { ErrorStatus HSEStartUpStatus; //使能外部晶振 RCC_HSEConfig(RCC_HSE_ON); //等待外部晶振稳定 HSEStartUpStatus = RCC_WaitForHSEStartUp(); //如果外部晶振启动成功,则进行下一步操作 if(HSEStartUpStatus==SUCCESS) { //设置HCLK(AHB时钟)=SYSCLK RCC_HCLKConfig(RCC_SYSCLK_Div1); //PCLK1(APB1) = HCLK/2 RCC_PCLK1Config(RCC_HCLK_Div2); //PCLK2(APB2) = HCLK RCC_PCLK2Config(RCC_HCLK_Div1); //设置ADC时钟频率 RCC_ADCCLKConfig(RCC_PCLK2_Div2); //FLASH时序控制 //推荐值:SYSCLK = 0~24MHz Latency=0 // SYSCLK = 24~48MHz Latency=1 // SYSCLK = 48~72MHz Latency=2 FLASH_SetLatency(FLASH_Latency_2); //开启FLASH预取指功能 FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable); //PLL设置 SYSCLK/1 * 9 = 8*1*9 = 72MHz RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9); //启动PLL RCC_PLLCmd(ENABLE); //等待PLL稳定 while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET); //系统时钟SYSCLK来自PLL输出 RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK); //切换时钟后等待系统时钟稳定 while(RCC_GetSYSCLKSource()!=0x08); } //下面是给各模块开启时钟 //启动GPIO RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOB | \ RCC_APB2Periph_GPIOC | RCC_APB2Periph_GPIOD,\ ENABLE); //启动AFIO RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO, ENABLE); //启动USART1 RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1, ENABLE); //启动DMA时钟 RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE); //启动ADC1时钟 RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1, ENABLE); } /******************************************************************************* * Function Name : GPIO_Configuration * Description : GPIO设置 * Input : None * Output : None * Return : None *******************************************************************************/ void GPIO_Configuration(void) { GPIO_InitTypeDef GPIO_InitStructure; //PC口4567脚设置GPIO输出,推挽 2M GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4 | GPIO_Pin_5 | GPIO_Pin_6 | GPIO_Pin_7; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_2MHz; GPIO_Init(GPIOC, &GPIO_InitStructure); //KEY2 KEY3 JOYKEY //位于PD口的3 4 11-15脚,使能设置为输入 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3 | GPIO_Pin_4 | GPIO_Pin_11 | GPIO_Pin_12 |\ GPIO_Pin_13 | GPIO_Pin_14 | GPIO_Pin_15; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING; GPIO_Init(GPIOD, &GPIO_InitStructure); //USART1_TX GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; GPIO_Init(GPIOA, &GPIO_InitStructure); //USART1_RX GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING; GPIO_Init(GPIOA, &GPIO_InitStructure); //ADC_CH10--> PC0 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN; GPIO_Init(GPIOC, &GPIO_InitStructure); } /******************************************************************************* * Function Name : NVIC_Configuration * Description : NVIC设置 * Input : None * Output : None * Return : None *******************************************************************************/ void NVIC_Configuration(void) { NVIC_InitTypeDef NVIC_InitStructure; #ifdef VECT_TAB_RAM // Set the Vector Table base location at 0x20000000 NVIC_SetVectorTable(NVIC_VectTab_RAM, 0x0); #else /* VECT_TAB_FLASH */ // Set the Vector Table base location at 0x08000000 NVIC_SetVectorTable(NVIC_VectTab_FLASH, 0x0); #endif //设置NVIC优先级分组为Group2:0-3抢占式优先级,0-3的响应式优先级 NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2); //串口中断打开 NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQChannel; NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0; NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1; NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; NVIC_Init(&NVIC_InitStructure); } /******************************************************************************* * Function Name : USART1_Configuration * Description : NUSART1设置 * Input : None * Output : None * Return : None *******************************************************************************/ void USART1_Configuration(void) { USART_InitTypeDef USART_InitStructure; USART_InitStructure.USART_BaudRate = 19200; USART_InitStructure.USART_WordLength = USART_WordLength_8b; USART_InitStructure.USART_StopBits = USART_StopBits_1; USART_InitStructure.USART_Parity = USART_Parity_No; USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None; USART_InitStructure.USART_Mode = USART_Mode_Tx | USART_Mode_Rx; USART_Init(USART1, &USART_InitStructure); USART_ITConfig(USART1, USART_IT_RXNE, ENABLE); USART_Cmd(USART1, ENABLE); } /******************************************************************************* * Function Name : ADC1_Configuration * Description : ADC1设置(包括ADC模块配置和自校准) * Input : None * Output : None * Return : None *******************************************************************************/ void ADC1_Configuration(void) { ADC_InitTypeDef ADC_InitStructure; ADC_InitStructure.ADC_Mode = ADC_Mode_Independent; ADC_InitStructure.ADC_ScanConvMode = ENABLE; ADC_InitStructure.ADC_ContinuousConvMode = ENABLE; //连续转换开启 ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None; ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right; ADC_InitStructure.ADC_NbrOfChannel = 2; //设置转换序列长度为2 ADC_Init(ADC1, &ADC_InitStructure); //ADC内置温度传感器使能(要使用片内温度传感器,切忌要开启它) ADC_TempSensorVrefintCmd(ENABLE); //常规转换序列1:通道10 ADC_RegularChannelConfig(ADC1, ADC_Channel_10, 1, ADC_SampleTime_13Cycles5); //常规转换序列2:通道16(内部温度传感器),采样时间>2.2us,(239cycles) ADC_RegularChannelConfig(ADC1, ADC_Channel_16, 2, ADC_SampleTime_239Cycles5); // Enable ADC1 ADC_Cmd(ADC1, ENABLE); // 开启ADC的DMA支持(要实现DMA功能,还需独立配置DMA通道等参数) ADC_DMACmd(ADC1, ENABLE); // 下面是ADC自动校准,开机后需执行一次,保证精度 // Enable ADC1 reset calibaration register ADC_ResetCalibration(ADC1); // Check the end of ADC1 reset calibration register while(ADC_GetResetCalibrationStatus(ADC1)); // Start ADC1 calibaration ADC_StartCalibration(ADC1); // Check the end of ADC1 calibration while(ADC_GetCalibrationStatus(ADC1)); // ADC自动校准结束--------------- } /******************************************************************************* * Function Name : DMA_Configuration * Description : DMA设置:从ADC模块自动读转换结果至内存 * Input : None * Output : None * Return : None *******************************************************************************/ void DMA_Configuration(void) { DMA_InitTypeDef DMA_InitStructure; DMA_DeInit(DMA1_Channel1); DMA_InitStructure.DMA_PeripheralBaseAddr = ADC1_DR_Address; DMA_InitStructure.DMA_MemoryBaseAddr = (u32)&AD_Value; DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC; //BufferSize=2,因为ADC转换序列有2个通道 //如此设置,使序列1结果放在AD_Value[0],序列2结果放在AD_Value[1] DMA_InitStructure.DMA_BufferSize = 2; DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable; DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable; DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord; DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord; //循环模式开启,Buffer写满后,自动回到初始地址开始传输 DMA_InitStructure.DMA_Mode = DMA_Mode_Circular; DMA_InitStructure.DMA_Priority = DMA_Priority_High; DMA_InitStructure.DMA_M2M = DMA_M2M_Disable; DMA_Init(DMA1_Channel1, &DMA_InitStructure); //配置完成后,启动DMA通道 DMA_Cmd(DMA1_Channel1, ENABLE); } |
RE:请各位高手帮忙解释一下程序
回复:请各位高手帮忙解释一下程序
这个应该在AD中断输出的,只看这么一点程序看不到实际的代码连接。最好把工程发出来。
下面有一个工程,帮忙看一下ADC,DMA与USART怎么联系在一起的,从哪个文件看出来的,谢谢!!!
ADC_test.rar
2011-10-15 10:03 上传
点击文件名下载附件
573.97 KB, 下载次数: 1
RE:请各位高手帮忙解释一下程序
2、配置AD采集开启,但是不开启中断采集
3、while里面在实时读取AD采集到的值
4、间隔1秒,串口输出一次AD采集到的值
5、他们之间并没有太直接的联系,你需要逐句理解,初学时,要多看代码和理解代码的实际意义。
