stm32f103把spi1换成spi2需要做哪些修改
胡杨-345459 提问时间:2012-3-5 16:30 /
程序本来使用的spi1,我想将其换成spi2,请问应该怎样修改程序,需要修改哪些地方。我刚刚接触这种片子,实在是无从下手,下面有源程序代码,请修改好后加上注释,先谢谢了
unsigned char RCC_Configuration(void){        ErrorStatus                HSEStartUpStatus;          /* RCC system reset(for debug purpose) */          RCC_DeInit();          /* Enable HSE */          RCC_HSEConfig(RCC_HSE_ON);          /* Wait till HSE is ready */          HSEStartUpStatus = RCC_WaitForHSEStartUp();          if(HSEStartUpStatus == SUCCESS)          {            /* HCLK = SYSCLK */            RCC_HCLKConfig(RCC_SYSCLK_Div1);            /* PCLK2 = HCLK */            RCC_PCLK2Config(RCC_HCLK_Div1);                RCC_PCLK1Config(RCC_HCLK_Div2);                RCC_ADCCLKConfig(RCC_PCLK2_Div4);                FLASH_SetLatency(FLASH_Latency_2);            FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);                   RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9);            RCC_PLLCmd(ENABLE);            while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET){};            RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);            while(RCC_GetSYSCLKSource() != 0x08){};          }        else                return FALSE;         RCC_APB1PeriphClockCmd(RCC_APB1Periph_I2C2 | RCC_APB1Periph_TIM2, ENABLE);          /* Enable GPIOA GPIOB SPI1 and USART1 clocks */          RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOB                                        | RCC_APB2Periph_GPIOC |RCC_APB2Periph_GPIOF| RCC_APB2Periph_USART1                                        | RCC_APB2Periph_SPI1 | RCC_APB2Periph_ADC1                                        | RCC_APB2Periph_AFIO, ENABLE);        return TRUE;}void SPI_Configuration(void){        GPIO_InitTypeDef                 GPIO_InitStructure;        SPI_InitTypeDef           SPI_InitStructure;          /* Configure SPI1 pins: SCK, MISO and MOSI -------------*/          GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5 | GPIO_Pin_6 | GPIO_Pin_7;          GPIO_InitStructure.GPIO_Speed = GPIO_Speed_10MHz;          GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;          GPIO_Init(GPIOA, &GPIO_InitStructure);                /* Set Chip Select pin */        GPIO_InitStructure.GPIO_Pin=GPIO_Pin_3| GPIO_Pin_4;        GPIO_InitStructure.GPIO_Speed=GPIO_Speed_10MHz;        GPIO_InitStructure.GPIO_Mode=GPIO_Mode_Out_PP;        GPIO_Init(GPIOA, &GPIO_InitStructure);        GPIO_InitStructure.GPIO_Pin=GPIO_Pin_1;        GPIO_InitStructure.GPIO_Speed=GPIO_Speed_10MHz;        GPIO_InitStructure.GPIO_Mode=GPIO_Mode_Out_PP;        GPIO_Init(GPIOA, &GPIO_InitStructure);        GPIO_SetBits(GPIOA, GPIO_Pin_3);         GPIO_SetBits(GPIOA, GPIO_Pin_1);         GPIO_SetBits(GPIOA, GPIO_Pin_4);        /* Set SPI interface */        SPI_InitStructure.SPI_Direction=SPI_Direction_2Lines_FullDuplex;        SPI_InitStructure.SPI_Mode=SPI_Mode_Master;        SPI_InitStructure.SPI_DataSize=SPI_DataSize_8b;        SPI_InitStructure.SPI_CPOL=SPI_CPOL_Low;        SPI_InitStructure.SPI_CPHA=SPI_CPHA_1Edge;        SPI_InitStructure.SPI_NSS=SPI_NSS_Soft;        SPI_InitStructure.SPI_BaudRatePrescaler=SPI_BaudRatePrescaler_8;        SPI_InitStructure.SPI_FirstBit=SPI_FirstBit_MSB;        SPI_InitStructure.SPI_CRCPolynomial=7;        SPI_Init(SPI1,&SPI_InitStructure);        SPI_Cmd(SPI1,ENABLE);                                        //Enable  SPI1}
收藏 评论5 发布时间:2012-3-5 16:30
5个回答
废鱼 回答时间:2012-3-5 22:01:15
RE:stm32f103把spi1换成spi2需要做哪些修改
1、开启SPI2的时钟
2、配置SPI2
使用和SPI1一样,先开时钟,再配置,然后再使用。
胡杨-345459 回答时间:2012-3-6 09:02:52
能帮我看一下,我配置的时钟和spi2有哪里不妥吗?
          RCC_DeInit();
          /* Enable HSE */
            /* HCLK = SYSCLK */
            /* PCLK2 = HCLK */
            /* PCLK1 = HCLK/2 */
                /* ADCCLK = PCLK2/4 */
            /* Flash 2 wait state */
            /* Enable Prefetch Buffer */
            /* PLLCLK = 8MHz * 9 / 2 = 36 MHz */
            /* Enable PLL */
            RCC_PLLCmd(ENABLE);
            /* Wait till PLL is ready */
            /* Select PLL as system clock source */
            /* Wait till PLL is used as system clock source */
        else
                return FALSE;
        /* Enable peripheral clocks --------------------------------------------------*/
          /* Enable I2C1 and I2C1 clock */
        RCC_APB1PeriphClockCmd(RCC_APB1Periph_SPI2 | /*RCC_APB1Periph_I2C2 | */RCC_APB1Periph_TIM2, ENABLE);
        return TRUE;
*@brief SPI Initialization
          GPIO_InitStructure.GPIO_Pin =GPIO_Pin_13 | GPIO_Pin_14 | GPIO_Pin_15;
        // 片选
        GPIO_InitStructure.GPIO_Pin=GPIO_Pin_12;
        //使能端
        GPIO_InitStructure.GPIO_Pin=GPIO_Pin_11;
        //复位端
    GPIO_InitStructure.GPIO_Pin=GPIO_Pin_10;
        GPIO_SetBits(GPIOB, GPIO_Pin_11);
        GPIO_SetBits(GPIOB, GPIO_Pin_10);
        GPIO_SetBits(GPIOB, GPIO_Pin_12);
        SPI_Init(SPI2,&SPI_InitStructure);
        SPI_Cmd(SPI2,ENABLE);                                        //Enable  SPI2
pengpeng-360286 回答时间:2012-9-10 21:27:37
回复:stm32f103把spi1换成spi2需要做哪些修改
unsigned char RCC_Configuration(void)//时钟配置
ErrorStatus HSEStartUpStatus;//定义了一个布尔型变量
RCC_DeInit(); //将时钟配置寄存器初始化为默认值
/* Enable HSE */
RCC_HSEConfig(RCC_HSE_ON);//使能外部高速时钟
HSEStartUpStatus = RCC_WaitForHSEStartUp();//等待外部高速时钟准备好
if(HSEStartUpStatus == SUCCESS)//如果外部高速时钟准备好
/* HCLK = SYSCLK */
RCC_HCLKConfig(RCC_SYSCLK_Div1);//AHB总线时钟为系统时钟的一分频
/* PCLK2 = HCLK */
RCC_PCLK2Config(RCC_HCLK_Div1);//APB2总线时钟为AHB总线时钟的一分频
RCC_PCLK1Config(RCC_HCLK_Div2);//AHPB1总线时钟为AHB总线时钟的二分频
RCC_ADCCLKConfig(RCC_PCLK2_Div4);//ADC时钟为APB2总线时钟的四分频
FLASH_SetLatency(FLASH_Latency_2);//设置Flash为2个等待周期
FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);//使能预取指缓冲区
RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9);//锁相环时钟源外外部高速时钟、倍频系数为9(如果外部高速时钟为8MHZ,外部时钟经PPL倍频后的时钟频率为8*9=72MHZ)
/* Enable PLL */
RCC_PLLCmd(ENABLE);//PPL使能
while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET){};//等待锁相环时钟准备好
RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);//将锁相环时钟作为系统时钟源
while(RCC_GetSYSCLKSource() != 0x08){};//等待锁相环时钟作为系统时钟准备好
else //如果外部高速时钟无法启动成功
return FALSE; //返回错误值
/* 使能外设时钟 --------------------------------------------------*/
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB|RCC_APB2Periph_AFIO, ENABLE );        //spi2端口时钟使能
RCC_APB1PeriphClockCmd(        RCC_APB1Periph_SPI2, ENABLE );
} //spi2使能
/* Configure SPI2 pins: SCK, MISO and MOSI -------------*/
// 片选
//使能端
//复位端
xindefangxiang0 回答时间:2015-8-22 15:52:05
ErrorStatus HSEStartUpStatus;//定义了一个布尔型变 ...
如果SPI1和SPI2都使用,并且各去接不同的外设模块,会造成冲突吗?谢谢
xindefangxiang0 回答时间:2015-8-22 15:52:49
