STM32PWM产生30K以上的频率就不行了,大家给看看程序!!(已解决)
看不透说不穿 提问时间:2013-8-29 17:16 /
void TIM4_PWM_init(CHn ch, u32 freq, u32 duty)
 TIM_TimeBaseInitTypeDef  TIM4_TimeBaseStructure;//¶¨Òå½á¹¹Ìå
 TIM_OCInitTypeDef  TIM4_OCInitStructure;
 RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD|RCC_APB2Periph_AFIO, ENABLE);//ʹÄÜGPIOD¼°¹¦Äܸ´ÓÃIOʱÖÓ
 RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM4, ENABLE);//ʹÄÜTIM4ʱÖÓ
 //GPIOAÅäÖÃΪ£º¶¨Ê±Æ÷4µÄPWM4¸öͨµÀ¸´Óù¦ÄÜÊä³ö
   GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14|GPIO_Pin_15;
   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; //¸´ÓÃÍÆÍìÊä³ö
   GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;//I/OʱÖÓΪ50MHz
   GPIO_Init(GPIOD, &GPIO_InitStructure);//¸ù¾ÝÉÏÃæÖ¸¶¨²ÎÊý³õʼ»¯GPIO½á¹¹Ìå
 GPIO_PinRemapConfig(GPIO_Remap_TIM4, ENABLE); //½«TIM4Òý½ÅÍêÈ«ÖØÓ³Éä
 //¶¨Ê±Æ÷»ù±¾ÅäÖÃ
 TIM4_TimeBaseStructure.TIM_Period =(u16)(36000000/freq-1);//¼ÆÊýֵΪ1000
 TIM4_TimeBaseStructure.TIM_Prescaler = 2-1;//2·ÖƵ  36M
 TIM4_TimeBaseStructure.TIM_ClockDivision = 0;//²ÉÑù·ÖƵ0
 TIM4_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;//ÏòÉϼÆÊý
 TIM_TimeBaseInit(TIM4, &TIM4_TimeBaseStructure);
 TIM4_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;//¶¨Ê±Æ÷ÅäÖÃΪPWM1ģʽ
 TIM4_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;//TIMÊä³ö±È½Ï¼«ÐÔ¸ß
 // PWM1ģʽͨµÀ1
 if(ch==1)
 TIM4_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;//ͨµÀ1Êä³öʹÄÜ
 TIM4_OCInitStructure.TIM_Pulse =(u16)(36000000/freq/PWM_precision*duty);//Âö¿íֵΪ200
 TIM_OC1Init(TIM4,&TIM4_OCInitStructure); //¸ù¾ÝTIM_OCInitStructÖÐÖ¸¶¨µÄ²ÎÊý³õʼ»¯TIM2
 TIM_OC1PreloadConfig(TIM4, TIM_OCPreload_Enable); //ʹÄÜTIM2ÔÚCCR1ÉϵÄÔ¤×°ÔØ¼Ä´æÆ÷
 // PWM1ģʽͨµÀ2
 if (ch==2)
 TIM4_OCInitStructure.TIM_Pulse =(u16)(36000000/freq/PWM_precision*duty);//Âö¿íÖµÎ
 TIM_OC2Init(TIM4, &TIM4_OCInitStructure);
 TIM_OC2PreloadConfig(TIM4, TIM_OCPreload_Enable);//ʹÄÜTIM2ÔÚCCR2ÉϵÄÔ¤×°ÔØ¼Ä´æÆ÷
 // PWM1ģʽͨµÀ3
  if (ch==3)
 TIM_OC3Init(TIM4, &TIM4_OCInitStructure);
 TIM_OC3PreloadConfig(TIM4, TIM_OCPreload_Enable);
 // PWM1ģʽͨµÀ4
 if (ch==4)
 TIM_OC4Init(TIM4, &TIM4_OCInitStructure);
 TIM_OC4PreloadConfig(TIM4, TIM_OCPreload_Enable);
 TIM_ARRPreloadConfig(TIM4, ENABLE);//ʹÄÜTIM2ÔÚARRÉϵÄÔ¤×°ÔØ¼Ä´æÆ÷
 TIM_ClearITPendingBit(TIM4, TIM_IT_CC1|TIM_IT_CC2|TIM_IT_CC3|TIM_IT_CC4);//Ô¤ÏÈÇå³ýËùÓÐÖжÏλ
 /* ÅäÖÃÊä³ö±È½ÏͨµÀ1ÖжÏ*/
 TIM_ITConfig(TIM4,TIM_IT_CC1,DISABLE);
 TIM_Cmd(TIM4, ENABLE);//ʹÄܶ¨Ê±Æ÷2
收藏 评论3 发布时间:2013-8-29 17:16
3个回答
feiante-155820 回答时间:2013-8-30 08:16:53
RE:STM32PWM产生30K以上的频率就不行了,大家给看看程序!!
产生30K以上的波不行是什么意思?
下面是我产生38KHz,占空比为1/3的程序,你可以看看
void TIM1_Configuration(void)
        TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;             //Õâ¾ä±ØÐë·ÅÔÚ×îÉÏÃæ
        TIM_OCInitTypeDef TIM_OCInitStructure;
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1, ENABLE);
        TIM_TimeBaseStructure.TIM_Period = 1894;
        TIM_TimeBaseStructure.TIM_Prescaler = 0;
        TIM_TimeBaseStructure.TIM_ClockDivision = 0;
        TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
        TIM_TimeBaseInit(TIM1, &TIM_TimeBaseStructure);
  /* PWM1 Mode configuration: Channel1 */
        TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;
        TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
        TIM_OCInitStructure.TIM_Pulse = 1894/3;
        TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;
        TIM_OC1Init(TIM1, &TIM_OCInitStructure);
        TIM_OC1PreloadConfig(TIM1, TIM_OCPreload_Enable);
        TIM_ARRPreloadConfig(TIM1, ENABLE);
  /* TIM1 enable counter */
        TIM_Cmd(TIM1, DISABLE);
        TIM_CtrlPWMOutputs(TIM1, ENABLE);
feiante-155820 回答时间:2013-8-30 08:17:18
产生30K以上的波不行是什么意思?
fengye5340 回答时间:2013-8-30 10:30:11
回复:STM32PWM产生30K以上的频率就不行了,大家给看看程序!!
看你的代码好费劲,发一个我的吧,默认50KHZ,可以随意设置频率和占空比,楼主可以参考一下:这个代码已经验证:
extern  unsigned char Pwm_freg ;
unsigned char Pwm_duty_num =20 ; // 50kHZ
extern volatile unsigned short int  Pwm_period_num ;
unsigned short int  CCR1_Val;
unsigned short int  CCR2_Val;
//unsigned short int  CCR3_Val = 50;
//unsigned short int  CCR4_Val = 20;
* 函数名称: Timer3_PWM_Init();
* 功能描述: 定时器3初始化--用于产生四路PWM
* 输入参数: void
* 返回参数: 无
void Timer3_PWM_Init(void)
        TIM_TimeBaseInitTypeDef      TIM_TimeBaseInitStructure;
          CCR1_Val = (unsigned short int)(50*(Pwm_period_num+1)/100);
          CCR2_Val = (unsigned short int)(50*(Pwm_period_num+1)/100);
          //时钟配置
          RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOE , ENABLE);   // 使能GPIOB端口
          RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3, ENABLE);   // 打开定时器3的时钟
          //TIM3-CH1-CH4GPIO通道配置--PE2-PE5
          GPIO_InitStructure.GPIO_Pin =   GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5;
                GPIO_InitStructure.GPIO_Mode =  GPIO_Mode_AF;
                GPIO_InitStructure.GPIO_PuPd =  GPIO_PuPd_UP ;
                GPIO_Init(GPIOE, &GPIO_InitStructure);
        GPIO_PinAFConfig(F303C_PWM3_CH1_P0RT ,  F303C_PWM3_CH1_SOURCE,  F303C_PWM3_CH1_AF);
                GPIO_PinAFConfig(F303C_PWM3_CH2_P0RT ,  F303C_PWM3_CH2_SOURCE,  F303C_PWM3_CH2_AF);
                GPIO_PinAFConfig(F303C_PWM3_CH3_P0RT ,  F303C_PWM3_CH3_SOURCE,  F303C_PWM3_CH3_AF);
          GPIO_PinAFConfig(F303C_PWM3_CH4_P0RT ,  F303C_PWM3_CH4_SOURCE , F303C_PWM3_CH4_AF);
          //设置定时器相关参数
          TIM_TimeBaseInitStructure.TIM_Prescaler = 71;                  // 定时器时钟分频后: 72000000 / (72 + 1) = 1MHZ.
          TIM_TimeBaseInitStructure.TIM_CounterMode = TIM_CounterMode_Up; // 向上计数模式
          TIM_TimeBaseInitStructure.TIM_Period = Pwm_period_num ;         // 自动重装载计数器周期的值--默认50KHZ
          TIM_TimeBaseInitStructure.TIM_ClockDivision = TIM_CKD_DIV1;     // 时钟分频系数--不分频
          TIM_TimeBaseInit(TIM3, &TIM_TimeBaseInitStructure);             // TIM2, 每1ms中断一次.
        //PWM模式设置-CH3
                TIM_OCInitStructure.TIM_Pulse = CCR1_Val;
        TIM_OC3Init(TIM3, &TIM_OCInitStructure);
        TIM_OC3PreloadConfig(TIM3, TIM_OCPreload_Enable);
                //PWM模式设置-CH4
                TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM2;
                TIM_OCInitStructure.TIM_Pulse = CCR2_Val;
        TIM_OC4Init(TIM3, &TIM_OCInitStructure);
                TIM_OC4PreloadConfig(TIM3, TIM_OCPreload_Enable);
                TIM_ARRPreloadConfig(TIM3, ENABLE);
          TIM_Cmd(TIM3, ENABLE);
