周二 九月 24, 2013 15:27:13: Loaded macro file: D:\Program Files (x86)\IAR Systems\Embedded Workbench 6.5\arm\config\flashloader\ST\ FlashSTM32F2xxxx.mac 周二 九月 24, 2013 15:27:14: JLINK command: ProjectFile = D:\Program Files (x86)\IAR Systems\Embedded Workbench 6.5\arm\examples\ST\ STM32F2xx\IAR-STM32F207ZG-SK\Buzzer\settings\Buzzer_Flash Debug.jlink, return = 0 周二 九月 24, 2013 15:27:14: Device "STM32F207ZE" selected (512 KB flash, 64 KB RAM). 周二 九月 24, 2013 15:27:14: DLL version: V4.62 周二 九月 24, 2013 15:27:14: Firmware: J-Link ARM V8 compiled Nov 14 2012 22:34:52 周二 九月 24, 2013 15:27:14: Selecting SWD as current target interface. 周二 九月 24, 2013 15:27:14: JTAG speed is initially set to: 32 kHz 周二 九月 24, 2013 15:27:14: Found SWD-DP with ID 0x2BA01477 周二 九月 24, 2013 15:27:14: Found SWD-DP with ID 0x2BA01477 周二 九月 24, 2013 15:27:14: TPIU fitted. 周二 九月 24, 2013 15:27:14: ETM fitted. 周二 九月 24, 2013 15:27:14: FPUnit: 6 code (BP) slots and 2 literal slots 周二 九月 24, 2013 15:27:14: Found Cortex-M3 r2p0, Little endian. 周二 九月 24, 2013 15:27:14: Hardware reset with strategy 0 was performed 周二 九月 24, 2013 15:27:14: Initial reset was performed 周二 九月 24, 2013 15:27:14: 712 bytes downloaded and verified (4.46 Kbytes/sec) 周二 九月 24, 2013 15:27:14: Warning: Verify error at address 0x20000002, target byte: 0x00, byte in file: 0x02 周二 九月 24, 2013 15:27:14: Warning: Verify error at address 0x20000003, target byte: 0x00, byte in file: 0x20 //此处省略好多上面四行的类似信息 周二 九月 24, 2013 15:27:14: Warning: Too many verify errors, only the first 200 are displayed 周二 九月 24, 2013 15:27:18: Fatal error: There were warnings during download of FLASH loader, see Log Window Session aborted! 周二 九月 24, 2013 15:27:18: Failed to load flash loader: D:\Program Files (x86)\IAR Systems\Embedded Workbench 6.5\arm\config\flashloader\ST\ FlashSTM32F2xxxx.out 周二 九月 24, 2013 15:27:18: Failed to load flash loader: D:\Program Files (x86)\IAR Systems\Embedded Workbench 6.5\arm\config\flashloader\ST\ FlashSTM32F205xE.flash 上面是提示的错误,环境IAR6 j-link v8 stm32f207zgt6 |
RE:stm32无法下载程序求助
RE:stm32无法下载程序求助
RE:stm32无法下载程序求助
RE:stm32无法下载程序求助
用stvp能读出来但是不能写,而且读出来的也很奇怪是从0x08008000开始有数据之前的都是FF
回复:stm32无法下载程序求助
同一个工程以前的板子可以,现在的不行,应该不是配置的问题
这钟一般是写保护了,估计你启动了写保护,但是STLINK是没法擦除写保护的,需要用ISP方式擦除一下。
RE:stm32无法下载程序求助
RE:stm32无法下载程序求助
RE:stm32无法下载程序求助
RE:stm32无法下载程序求助
