nucleo 072上手
netlhx 提问时间:2014-12-20 09:06 /
收到STM32NUCLEO F072,感谢沐紫!
简单试用,发现几个要注意的地方,分享一下。
1. 板子上的外部晶振是没有焊接的,所以就不要去配置外部时钟了,配了也是白配。手头虽然也有8M的晶振,只是那几个小电容实在看着汗颜……,只好做罢,老老实实用HSI吧。
2. 使用VCP虚拟串口做串口通讯实验的筒子们注意了,MCU使用的是USART2,所以配置的时候还是选USART2吧,使用其它的UART口得自己连线,呵呵!
3. LSE倒是焊接好了,应该做RTC实验没问题。
4. HAL库比老库更好用了,复用GPIO外设口都不用配置了
也发个DMA发送信息到串口的代码,简单代码,不值一笑
  1. /**
  2.   ******************************************************************************
  3.   * File Name          : main.c
  4.   * Date               : 20/12/2014 08:55:52
  5.   * Description        : Main program body
  6.   ******************************************************************************
  7.   *
  8.   * COPYRIGHT(c) 2014 STMicroelectronics
  9.   *
  10.   * Redistribution and use in source and binary forms, with or without modification,
  11.   * are permitted provided that the following conditions are met:
  12.   *   1. Redistributions of source code must retain the above copyright notice,
  13.   *      this list of conditions and the following disclaimer.
  14.   *   2. Redistributions in binary form must reproduce the above copyright notice,
  15.   *      this list of conditions and the following disclaimer in the documentation
  16.   *      and/or other materials provided with the distribution.
  17.   *   3. Neither the name of STMicroelectronics nor the names of its contributors
  18.   *      may be used to endorse or promote products derived from this software
  19.   *      without specific prior written permission.
  20.   *
  21.   * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
  22.   * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
  23.   * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
  24.   * DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE
  25.   * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
  26.   * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR
  27.   * SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER
  28.   * CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
  29.   * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
  30.   * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
  31.   *
  32.   ******************************************************************************
  33.   */
  34. /* Includes ------------------------------------------------------------------*/
  35. #include "stm32f0xx_hal.h"
  36. /* USER CODE BEGIN Includes */
  37. #include "string.h"
  38. /* USER CODE END Includes */
  39. /* Private variables ---------------------------------------------------------*/
  40. UART_HandleTypeDef huart2;
  41. DMA_HandleTypeDef hdma_usart2_tx;
  42. /* USER CODE BEGIN PV */
  43. /* USER CODE END PV */
  44. /* Private function prototypes -----------------------------------------------*/
  45. void SystemClock_Config(void);
  46. static void MX_GPIO_Init(void);
  47. static void MX_DMA_Init(void);
  48. static void MX_USART2_UART_Init(void);
  49. /* USER CODE BEGIN PFP */
  50. /* USER CODE END PFP */
  51. /* USER CODE BEGIN 0 */
  52. /* USER CODE END 0 */
  53. int main(void)
  54. {
  55.   /* USER CODE BEGIN 1 */
  56.         uint8_t msg[] = "Hello, world";
  57.
  58.   /* USER CODE END 1 */
  59.   /* MCU Configuration----------------------------------------------------------*/
  60.   /* Reset of all peripherals, Initializes the Flash interface and the Systick. */
  61.   HAL_Init();
  62.   /* Configure the system clock */
  63.   SystemClock_Config();
  64.   /* Initialize all configured peripherals */
  65.   MX_GPIO_Init();
  66.   MX_DMA_Init();
  67.   MX_USART2_UART_Init();
  68.   /* USER CODE BEGIN 2 */
  69.
  70.         //HAL_UART_Transmit(&huart2, msg, sizeof(msg), 5);
  71.         HAL_UART_Transmit_DMA(&huart2, msg, sizeof(msg) - 1);
  72.   /* USER CODE END 2 */
  73.   /* USER CODE BEGIN 3 */
  74.   /* Infinite loop */
  75.   while (1)
  76.   {
  77.   }
  78.   /* USER CODE END 3 */
  79. }
  80. /** System Clock Configuration
  81. */
  82. void SystemClock_Config(void)
  83. {
  84.   RCC_OscInitTypeDef RCC_OscInitStruct;
  85.   RCC_ClkInitTypeDef RCC_ClkInitStruct;
  86.   RCC_PeriphCLKInitTypeDef PeriphClkInit;
  87.   RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI;
  88.   RCC_OscInitStruct.HSIState = RCC_HSI_ON;
  89.   RCC_OscInitStruct.HSICalibrationValue = 16;
  90.   RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
  91.   RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSI;
  92.   RCC_OscInitStruct.PLL.PLLMUL = RCC_PLL_MUL12;
  93.   RCC_OscInitStruct.PLL.PREDIV = RCC_PREDIV_DIV2;
  94.   HAL_RCC_OscConfig(&RCC_OscInitStruct);
  95.   RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_SYSCLK;
  96.   RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
  97.   RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
  98.   RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV1;
  99.   HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_1);
  100.   PeriphClkInit.PeriphClockSelection = RCC_PERIPHCLK_USART2;
  101.   PeriphClkInit.Usart2ClockSelection = RCC_USART2CLKSOURCE_PCLK1;
  102.   HAL_RCCEx_PeriphCLKConfig(&PeriphClkInit);
  103.   __SYSCFG_CLK_ENABLE();
  104. }
  105. /* USART2 init function */
  106. void MX_USART2_UART_Init(void)
  107. {
  108.   huart2.Instance = USART2;
  109.   huart2.Init.BaudRate = 38400;
  110.   huart2.Init.WordLength = UART_WORDLENGTH_8B;
  111.   huart2.Init.StopBits = UART_STOPBITS_1;
  112.   huart2.Init.Parity = UART_PARITY_NONE;
  113.   huart2.Init.Mode = UART_MODE_TX_RX;
  114.   huart2.Init.HwFlowCtl = UART_HWCONTROL_NONE;
  115.   huart2.Init.OverSampling = UART_OVERSAMPLING_16;
  116.   huart2.Init.OneBitSampling = UART_ONEBIT_SAMPLING_DISABLED ;
  117.   huart2.AdvancedInit.AdvFeatureInit = UART_ADVFEATURE_NO_INIT;
  118.   HAL_UART_Init(&huart2);
  119. }
  120. /**
  121.   * Enable DMA controller clock
  122.   */
  123. void MX_DMA_Init(void)
  124. {
  125.   /* DMA controller clock enable */
  126.   __DMA1_CLK_ENABLE();
  127.   /* DMA interrupt init */
  128. }
  129. /** Configure pins as
  130.         * Analog
  131.         * Input
  132.         * Output
  133.         * EVENT_OUT
  134.         * EXTI
  135. */
  136. void MX_GPIO_Init(void)
  137. {
  138.   GPIO_InitTypeDef GPIO_InitStruct;
  139.   /* GPIO Ports Clock Enable */
  140.   __GPIOC_CLK_ENABLE();
  141.   __GPIOA_CLK_ENABLE();
  142.   /*Configure GPIO pin : PC13 */
  143.   GPIO_InitStruct.Pin = GPIO_PIN_13;
  144.   GPIO_InitStruct.Mode = GPIO_MODE_EVT_RISING;
  145.   GPIO_InitStruct.Pull = GPIO_NOPULL;
  146.   HAL_GPIO_Init(GPIOC, &GPIO_InitStruct);
  147.   /*Configure GPIO pin : PA5 */
  148.   GPIO_InitStruct.Pin = GPIO_PIN_5;
  149.   GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;
  150.   GPIO_InitStruct.Pull = GPIO_NOPULL;
  151.   GPIO_InitStruct.Speed = GPIO_SPEED_LOW;
  152.   HAL_GPIO_Init(GPIOA, &GPIO_InitStruct);
  153. }
  154. /* USER CODE BEGIN 4 */
  155. /* USER CODE END 4 */
  156. #ifdef USE_FULL_ASSERT
  157. /**
  158.    * @brief Reports the name of the source file and the source line number
  159.    * where the assert_param error has occurred.
  160.    * @param file: pointer to the source file name
  161.    * @param line: assert_param error line source number
  162.    * @retval None
  163.    */
  164. void assert_failed(uint8_t* file, uint32_t line)
  165. {
  166.   /* USER CODE BEGIN 6 */
  167.   /* User can add his own implementation to report the file name and line number,
  168.     ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  169.   /* USER CODE END 6 */
  170. }
  171. #endif
  172. /**
  173.   * @}
  174.   */
  175. /**
  176.   * @}
  177. */
  178. /************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
CUBEMX写代码如此简单。
下面是终端结果
赞 收藏 1 评论6 发布时间:2014-12-20 09:06
6个回答
沐紫 回答时间:2014-12-22 09:25:24
谢谢
巅峰残狼 回答时间:2014-12-22 09:43:53
相当不错,谢谢分享
foxglove 回答时间:2015-2-11 17:08:55
嗯,啊可能可能
zhangdaijin 回答时间:2015-5-2 20:03:13
不错不错!
hooke 回答时间:2015-5-3 13:40:47
趁着劳动节学学板子
党国特派员 回答时间:2015-5-3 21:47:03
楼主多分享点。。。 nothing.png nothing.png nothing.png nothing.png nothing.png nothing.png nothing.png nothing.png nothing.png nothing.png
