stm32 每条中断线只能有一个中断源
lhb292 提问时间:2015-1-9 18:18 /
今天才发现stm32的外部中断,每条中断线只能有一个中断源啊!!!
我的PA4,PA5,PA6,PA7,PC4,PC5,PB0,PB1,PE7这几个引脚只能PA4,PA5,PA6,PA7,PB0,PB1用外部中断了,
大家有什么好的办法,能让其他的几个引脚也用上外部中断吗? 分时开启的办法就算了,不实用。
#ifndef _COUNTER_H_
#define _COUNTER_H_
#include"driver_about.h"
#define COUNTER1_PORT    GPIOE
#define COUNTER1_PIN     GPIO_Pin_7
#define COUNTER2_PORT    GPIOB
#define COUNTER2_PIN     GPIO_Pin_1
#define COUNTERCTRL_PORT GPIOE
#define COUNTERCTRL_PIN  GPIO_Pin_8
#define COUNTER1_GPIO_PortSource  GPIO_PortSourceGPIOE
#define COUNTER1_GPIO_PinSource   GPIO_PinSource7
#define COUNTER2_GPIO_PortSource  GPIO_PortSourceGPIOB
#define COUNTER2_GPIO_PinSource   GPIO_PinSource1
#define COUNTER1_EXTI_Line        EXTI_Line7
#define COUNTER2_EXTI_Line        EXTI_Line1
#define Counter1_IRQn       EXTI9_5_IRQn
#define Counter1_IRQHandler EXTI9_5_IRQHandler
#define Counter2_IRQn       EXTI1_IRQn
#define Counter2_IRQHandler EXTI1_IRQHandler
#define COUNTERCTRL_Open()     GPIO_ResetBits(COUNTERCTRL_PORT,COUNTERCTRL_PIN)
#define COUNTERCTRL_Close()          GPIO_SetBits(COUNTERCTRL_PORT,COUNTERCTRL_PIN)
void Counter_Init(void);
void Set_Coin1(u8 coin);
void Set_Coin2(u8 coin);
u8 Get_Coin1(void);
u8 Get_Coin2(void);
u8 Add_Coin1(u8 value);
u8 Add_Coin2(u8 value);
#endif
#include"counter.h"
static u8 Coin1=0;
static u8 Coin2=0;
void Counter_GPIO(void)
    GPIO_InitStructure.GPIO_Pin =  COUNTER1_PIN;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;
    GPIO_InitStructure.GPIO_Speed = GPIO_Speed_2MHz;
    GPIO_Init(COUNTER1_PORT, &GPIO_InitStructure);
          GPIO_InitStructure.GPIO_Pin =  COUNTER2_PIN;
    GPIO_Init(COUNTER2_PORT, &GPIO_InitStructure);
          GPIO_InitStructure.GPIO_Pin =  COUNTERCTRL_PIN;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
    GPIO_Init(COUNTERCTRL_PORT, &GPIO_InitStructure);
          COUNTERCTRL_Open();
void Counter1_EXIT_Init(void)
  EXTI_InitTypeDef EXTI_InitStructure;//定义外部中断初始化参数的结构体
  GPIO_EXTILineConfig(COUNTER1_GPIO_PortSource,COUNTER1_GPIO_PinSource);//选择中断管脚
  EXTI_ClearITPendingBit(COUNTER1_EXTI_Line);//清除外部中断挂起标志
  EXTI_InitStructure.EXTI_Line = COUNTER1_EXTI_Line;   //选择中断线路
  EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt;//设置为中断请求,非事件请求
  EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Falling;//设置中断触发方式为下降沿触发
  EXTI_InitStructure.EXTI_LineCmd = ENABLE; //外部中断使能
  EXTI_Init(&EXTI_InitStructure);//初始化外部中断
void Counter1_NVIC_EXIT_Init(void)
  NVIC_InitTypeDef NVIC_InitStructure;//定义NVIC的结构体变量
  NVIC_InitStructure.NVIC_IRQChannel = Counter1_IRQn;//选择中断通道
  NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority =0;//抢占式中断优先级设置
  NVIC_InitStructure.NVIC_IRQChannelSubPriority =5;//响应式中断优先级设置
  NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;//使能中断
void Counter2_EXIT_Init(void)
  GPIO_EXTILineConfig(COUNTER2_GPIO_PortSource,COUNTER2_GPIO_PinSource);//选择中断管脚
  EXTI_ClearITPendingBit(COUNTER2_EXTI_Line);//清除外部中断挂起标志
  EXTI_InitStructure.EXTI_Line = COUNTER2_EXTI_Line;   //选择中断线路
void Counter2_NVIC_EXIT_Init(void)
  NVIC_InitStructure.NVIC_IRQChannel = Counter2_IRQn;//选择中断通道
  NVIC_InitStructure.NVIC_IRQChannelSubPriority =4;//响应式中断优先级设置
  Counter_GPIO();
        Counter1_EXIT_Init();
  Counter1_NVIC_EXIT_Init();
        Counter2_EXIT_Init();
  Counter2_NVIC_EXIT_Init();
  Coin1=coin;
u8 Get_Coin1(void)
  return Coin1;
         Coin1+=value;
  return Coin1;
  Coin2=coin;
u8 Get_Coin2(void)
  return Coin2;
        Coin2+=value;
  return Coin2;
void Counter1_IRQHandler(void)
        OS_ERR err;
        OSIntEnter();
  if(EXTI_GetITStatus(COUNTER1_EXTI_Line)!= RESET)
    OSTaskQPost  (&CounterStkTCB,&Coin1,1,OS_OPT_POST_FIFO,&err);
  else
          EXTI9_5_IRQHandler_Input();//输入产生的中断
        //EXTI_ClearITPendingBit(COUNTER1_EXTI_Line);
  OSIntExit();
void Counter2_IRQHandler(void)
        OS_ERR err;
        OSIntEnter();
  if(EXTI_GetITStatus(COUNTER2_EXTI_Line)!= RESET)//后半部分判断中断来源
    OSTaskQPost  (&CounterStkTCB,&Coin2,2,OS_OPT_POST_FIFO,&err);
  //EXTI_ClearITPendingBit(COUNTER2_EXTI_Line);
  OSIntExit();
赞 收藏 评论0 发布时间:2015-1-9 18:18
