RC522 SPI通信不通
漂泊的雨林 提问时间:2015-3-25 22:17 /
悬赏10ST金币未解决
SPI程序
void spi_init(void)
SPI_InitTypeDef  SPI_InitStructure;
    /*ʱÖÓÉèÖà */
RCC_APB2PeriphClockCmd(RCC_APB2Periph_SPI1, ENABLE);
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOC, ENABLE);//Ç°ÃæGPIOÉèÖÃʱʱÖÓÒÑ¿ªÆô ´Ë´¦²»ÔÙÉèÖÃ
    /*SCK ʱÖӹܽÅÉèÖÃ*/
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5;
    /*MOSI ¹Ü½ÅÉèÖà */
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7;
    /* MISO ¹Ü½ÅÉèÖÃ*/
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_OD;
    /*NSS Ƭѡ¹Ü½ÅÉèÖÃ*/
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
    GPIO_Init(GPIOC, &GPIO_InitStructure);
/*RC522复位管脚*/
    /*À­¸ß NSS¹Ü½Å*/
    SET_SPI_CS;
    SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex;//SPI ÉèÖÃΪ˫ÏßË«Ïòȫ˫¹¤
    SPI_InitStructure.SPI_Mode = SPI_Mode_Master;  //ÉèÖÃΪÖ÷SPI
    SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b; //ÉèÖÃΪ·¢ËͽÓÊÕ8λ֡½á¹¹
    SPI_InitStructure.SPI_CPOL = SPI_CPOL_Low;         //ʱÖÓÐü¿ÕµÍ
    SPI_InitStructure.SPI_CPHA = SPI_CPHA_1Edge;   //Êý¾Ý²¶»ñÓëµÚ1¸öʱÖÓÑØ
    SPI_InitStructure.SPI_NSS = SPI_NSS_Soft;          //ÄÚ²¿NSSÐźÅÓÉSSIλ¿ØÖÆ
    SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_8;        //²¨ÌØÂÊ·ÖÆµÖµÎª4 ²¨ÌØÂÊΪ9M
    SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;        //Êý¾Ý´«Êä´Ó¸ßλ¿ªÊ¼
    SPI_InitStructure.SPI_CRCPolynomial = 7;        //CRCУÑé
    SPI_Init(SPI1, &SPI_InitStructure);
    /*ʹÄÜSPI1 */
    SPI_Cmd(SPI1, ENABLE);
u8 SPIWriteByte(u8 Byte)
while (SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_TXE) == RESET);//µÈ´ý·¢ËÍΪ¿Õ
SPI_I2S_SendData(SPI1, Byte);//·¢ËÍÒ»¸ö×Ö½Ú
    while (SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_RXNE) == RESET);//µÈ´ý·¢ËÍÍê³É
return SPI_I2S_ReceiveData(SPI1);//½ÓÊÕÒ»¸ö×Ö½Ú
RC522读寄存器程序
u8 ReadRawRC(unsigned char Address)
     u8   ucAddr;
    u8   ucResult=0;
CLR_SPI_CS;
    ucAddr = ((Address<<1)&0x7E)|0x80;
SPIWriteByte(ucAddr);
ucResult=SPIWriteByte(0);
SET_SPI_CS;
   return ucResult;
读寄存器时无法读到
收藏 评论7 发布时间:2015-3-25 22:17
7个回答
漂泊的雨林 最优答案 回答时间:2015-3-26 10:59:16
问题是解决了 我把SPI MISO的管教配置成复用推挽输出 就可以了  但是这样一来我又有疑问了
我之前有个关于SPI  MISO管脚配置的帖子    跟FLASH芯片通信的时候  MISO 管脚配置成3种输出 通信都可以成功 但是 为什么 跟RC522的时候 只能配置复用推挽呢??????
埃斯提爱慕 回答时间:2015-3-25 23:59:03
埃斯提爱慕 回答时间:2015-3-25 23:59:28
kqh1120 回答时间:2015-3-26 00:41:19
_ilikerome_ 回答时间:2015-3-26 06:51:02
LZ传下源文件,方便看看。
还有具体是什么问题?
cxtarm 回答时间:2015-3-26 09:59:29
代码好长,看着头痛
dear祝子 回答时间:2015-3-26 15:31:24
自己动手丰衣足食,用示波器先看图形
