大家都用什么字体编码呢?
qianfan 提问时间:2015-6-1 10:01 /
赞 收藏 1 评论20 发布时间:2015-6-1 10:01
20个回答
Mandelbrot_Set 回答时间:2015-6-2 13:38:22
QianFan 发表于 2015-6-1 16:18
这个只能设置当前打开的,不能设置全体的。
MDK5没则么试过
mdk4设置里也可以设置(虽然好像有bug,顺带定义下U8 U16 uint16_t等为关键字...)
或者直接修改global.prop里的内容 size:10 改大...
# C/CPP Editor files
template.cpp="#define","#define |";"#if","#if |\r\n\r\n#endif";\\
    "#include","#include ";"Header","// Header:\r\n// File Name: |\r\n// Author:\r\n// Date:\r\n";\\
    "continue","continue;";"do","do\r\n{\r\n\t// TODO: enter the block content here\r\n\t\r\n\t|\r\n} while ();\r\n";\\
    "enum","enum |\r\n{\r\n\t\r\n};\r\n";"for","for(|;;)\r\n{\r\n}";\\
    "fpointer_type","typedef int (* |F)();\r\n";"function","void function(|)\r\n{\r\n\r\n}\r\n";\\
    "if","if (|)";"ifelse","if (|)\r\n{\r\n}\r\nelse\r\n{\r\n}";\\
    "struct","struct | \r\n{\r\n\r\n};\r\n";"switch","switch (|)\r\n{\r\n\tcase:\r\n\t\tbreak;\r\n\tcase:\r\n\t\tbreak;\r\n\tdefault:\r\n\t\tbreak;\r\n}";\\
    "void","void | ();\r\n";"while","while (|)\r\n{\r\n}";\\
font.monospace.cpp=Courier New
style.cpp.32=font:Courier New,size:10,fore:#000000,back:#FFFFFF
style.cpp.4=font:Courier New,size:10,fore:#007F7F,back:#FFFFFF
style.cpp.10=font:Courier New,size:10,fore:#000000,back:#FFFFFF
style.cpp.1=font:Courier New,size:10,fore:#007F00,back:#FFFFFF
style.cpp.2=font:Courier New,size:10,fore:#007F00,back:#FFFFFF
style.cpp.5=font:Courier New,size:10,fore:#0000FF,back:#FFFFFF
style.cpp.6=font:Courier New,size:10,fore:#7F007F,back:#FFFFFF
style.cpp.11=font:Courier New,size:10,fore:#000000,back:#FFFFFF
style.cpp.9=font:Courier New,size:10,fore:#7F7F00,back:#FFFFFF
style.cpp.7=font:Courier New,size:10,fore:#7F007F,back:#FFFFFF
style.cpp.34=font:Courier New,size:10,fore:#500000,back:#20FFFF
style.cpp.35=font:Courier New,size:10,fore:#FF0000,back:#FFFFFF
style.cpp.16=font:Courier New,size:10,fore:#B00040,back:#FFFFFF
759611 回答时间:2015-6-2 13:42:57
没怎么关注过字体……小白一个
小小超 回答时间:2015-6-2 14:03:29
红色+绿色+蓝色+黑色
熊猫s885 回答时间:2015-6-2 21:36:25
我怎么感觉标点符号始终不对呢
w453509596 回答时间:2015-6-2 21:41:04
我一直用飞思卡尔的codewarrior,那个界面很不错,我的KEIL也是按那个设置的。
qianfan 回答时间:2015-6-3 09:24:38
794760169 发表于 2015-6-2 21:36
我怎么感觉标点符号始终不对呢
哪里的不对?
12
