CUBE在用GPIO模拟I2C的时候 怎么给GPIO配置输入输出呀?
beary 提问时间:2015-9-23 12:29 /
收藏 评论3 发布时间:2015-9-23 12:29
3个回答
JackieLaura 回答时间:2015-9-23 15:49:07
没有用过Cube
deanquan 回答时间:2015-9-23 17:26:34
同以前的库一样,只是改了个函数而已。
GPIO_Init改为了HAL_GPIO_Init
void Single_IO_Config(GPIO_TypeDef *GPIOx, uint32_t Port_Pin, uint32_t GPIO_Speed, uint32_t GPIO_Mode, uint32_t pull)
    GPIO_InitTypeDef GPIO_InitStruct;
    GPIO_InitStruct.Pin = Port_Pin;
    GPIO_InitStruct.Mode = GPIO_Mode;
    GPIO_InitStruct.Speed = GPIO_Speed;
    GPIO_InitStruct.Pull = pull;
    HAL_GPIO_Init(GPIOx, &GPIO_InitStruct);
wyxy163@126.com 回答时间:2015-9-23 19:49:40
