暂时附上MX的网盘分享,其余大伙先自己更新:微云 Enhancements Added support of code generation, clock and power consumption calculation for support for STM32L0 series new part numbers About the power consumption calculator: – It can now interpolate consumption data based on user defined frequency – The L4 consumption data now supports voltage from 1.8V to 3.6V – It computes max ambient temperature – The load sequence mechanism can now load sequences from different low power series (STM32Lxxx) User defined labels are now generated in the code In the clock configuration a new button has been added, to trigger automatic clock issue resolution DMA parameters are now dependent on the DMA request User constants can be defined for string values
| 这可是一个好消息 |
| 目前主要考虑更新F0和F4 |
| 更新好快啊,不更新应该也没问题吧? |
好消息... |
