Ubuntu下开发STM32---0.软件搭建
qianfan 发布时间:2015-10-23 15:17
赞 收藏 7 评论33 发布时间:2015-10-23 15:17
33个回答
ataudio 回答时间:2015-10-30 13:41:52
我是从github下载的zip包,在ubuntu下unzip解压,然后直接配置编译的,没有改过。。请你发一个编好的给我吧。。邮箱:aoems@126.com。谢谢了。
qianfan 回答时间:2015-10-30 13:56:08
ataudio 发表于 2015-10-30 13:414 J7 r0 ^& a( m: D' S7 _8 r3 e
我是从github下载的zip包,在ubuntu下unzip解压,然后直接配置编译的,没有改过。。请你发一个编好的给我吧 ...
7 e' o. Z9 [0 b) N已发。。。
ataudio 回答时间:2015-10-30 15:54:57
QianFan 发表于 2015-10-30 13:56; I+ S5 e. S7 p( Z0 n& J
已发。。。
2 a, w8 I5 p  s5 q0 n! o. n
收到,多谢。
ataudio 回答时间:2015-11-3 10:42:53
换成ubuntu 15.10桌面版,gcc版本是5.2,编译stlink成功。, k- k" V7 Z& M0 |$ }4 Q
checking for sys/mman.h... yes
2 n+ t4 @1 l. D# |0 ?8 d5 lchecking sys/poll.h usability... yes
! B( h( R9 P) O+ S$ ochecking sys/poll.h presence... yes& m0 h/ g" @+ M' s' |
checking for sys/poll.h... yes
0 R, v. V* m: O* wchecking for mmap... yes, {( `: J; f5 G4 a
checking for pkg-config... /usr/bin/pkg-config
3 {0 A# ], d: vchecking pkg-config is at least version 0.9.0... yes9 U  T8 x9 q, k! n. f
checking for USB... yes: D$ d9 T- D5 A- ?2 x2 e" Z9 x0 c
checking for usb_path2devnum in -lusbpath... no( {+ f, {+ }* v! g0 t/ a2 e
checking that generated files are newer than configure... done
0 E' a. N0 X- p7 ?2 Iconfigure: creating ./config.status" D( C/ |5 P3 F1 P
config.status: creating Makefile
; a! \! @  C& l  o* p$ `6 r6 `% Qconfig.status: executing depfiles commands
- N' ]. J% E2 {) G! {aoems@ubuntu:~/stlink-master$ gcc --version
1 S8 ]% B, U1 C3 `gcc (Ubuntu 5.2.1-22ubuntu2) 5.2.1 201510109 x( N5 n* ^' C  y6 y, V) [
Copyright (C) 2015 Free Software Foundation, Inc./ i% K4 G! X3 N& d
This is free software; see the source for copying conditions.  There is NO- U! U! H- m; X0 G- b1 M& K1 o6 O% l
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  s4 ]1 P6 ]* Y  l
1 O( i/ h- M/ N& h) q4 B5 Uaoems@ubuntu:~/stlink-master$ sudo make install
2 G- }5 B! B4 @9 l9 }, U...
4 b0 ?. b0 K% t% k, S% C6 i1 F; \; Emake[2]: Entering directory '/home/aoems/stlink-master'
# c4 q" d  o* H1 v( g; _  `3 [# T /bin/mkdir -p '/usr/local/bin'3 X* V9 K1 c7 B3 |4 H2 A/ c9 e/ k
  /usr/bin/install -c st-flash st-util st-term st-info '/usr/local/bin'* E7 U% c. p7 j* K& S$ _
make[2]: Nothing to be done for 'install-data-am'.$ L' b  U, B! y( u' h2 x' j
make[2]: Leaving directory '/home/aoems/stlink-master'
, ?3 ~$ Z- r! h! |; omake[1]: Leaving directory '/home/aoems/stlink-master'
  f* O, q5 ^, g7 t5 haoems@ubuntu:~/stlink-master$
0 _# J# e# L  ~' M+ q2 m+ U; M9 Y( V# m5 z( B% v: p$ p
安装时,显示没做任何事情,不明白安装是否成功。
qianfan 回答时间:2015-11-3 13:31:47
ataudio 发表于 2015-11-3 10:425 l, T0 Y* _( t: u3 d
- Y3 s/ ]( F9 Rchecking for sys/mman.h... yes
4 C0 [( K1 T! y3 u+ w4 ?2 Echecking sys/p ...
( j" N8 \: T$ m% D  P% n8 N
你有没有安装过之前我的那个包?如果安装过的话,这次就不需要使用了。可以试试st-flash。如果有提示,那就是安装成功了。
Mandelbrot_Set 回答时间:2015-11-5 17:34:54
st-info
) F, P9 e& r6 Q3 L6 H, k. K& xst-term" n- s1 ?. x& o
是干什么的
qianfan 回答时间:2015-11-5 18:02:58
Mandelbrot_Set 发表于 2015-11-5 17:34; A/ F! M2 y* r
st-info
  v, W- E  G, h3 s2 ]st-term
/ z2 `1 M8 a* X( `9 d$ i# q是干什么的
* f& Q4 q; k  Y, m6 l- `. fst-info是用来获取芯片的内存大小和FLASH大小的。不过我的st-info并不输出任何内容。st-term不知道是干啥的。
9 w1 q" s: b6 j9 z  q我只会用st-flash和st-util。
qianfan 回答时间:2015-11-5 18:03:32
7 B* c& o- D' }8 c6 R# s3 ost-info
, D# L6 x$ t! Z7 K; ast-term1 P* d# k3 g! z) w
是干什么的
$ p0 W- H9 V/ N
这两个程序可能有bug。连--help都不会进行提示。
Cux 回答时间:2015-11-5 22:19:44
干货 虽然我不会操作系统
拼命三郎 回答时间:2015-11-9 09:01:01
学习学习  好定西啊
idodoyo 回答时间:2016-1-6 12:10:32
LINUX 做开发就是舒服,关键是先要把环境搞定!!谢谢指导啊
木木鱼 回答时间:2016-1-8 20:36:31
跟着学学。
随风飘扬 回答时间:2016-1-8 20:41:58
学习学习了
zcl201207 回答时间:2016-1-8 22:16:37
学习分享
Alliances 回答时间:2018-1-31 15:37:03
可以的,逗哥,紧随你的开发脚步
