PA2脚输入方波,想在PA1脚输出反向的方波,PA2状态监测不对..
any012 提问时间:2016-6-4 16:07 /
悬赏1ST金币已解决
感觉挺简单的,可就是在PA1脚输出不了波形。
单独控制PA1脚有定时器控制反转,没问题。
应该能排除硬件故障的问题。
想不出原因在哪?求助,自个看不出问题来...#include "stm32f10x.h"
  1. #include "stm32f10x.h"
  2. #include "gpio.h"
  3. int main(void)
  4. {
  5.         GPIO_Config();
  6.         while(1)
  7.         {
  8.                 if(PA2() == 1)
  9.                         PA1(1);
  10.                 else
  11.                         PA1(0);
  12.         }
  13. }
  1. #include "gpio.h"
  2. void GPIO_Config(void)
  3. {
  4.         GPIO_InitTypeDef GPIO_InitStructure;
  5.         RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOC, ENABLE);
  6.
  7.         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1;
  8.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_OD;
  9.         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  10.         GPIO_Init(GPIOA, &GPIO_InitStructure);
  11.
  12.         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
  13.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;
  14.         GPIO_Init(GPIOA, &GPIO_InitStructure);
  15.
  16.         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6;
  17.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
  18.         GPIO_Init(GPIOC, &GPIO_InitStructure);
  19.
  20.         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7;
  21.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  22.         GPIO_Init(GPIOC, &GPIO_InitStructure);
  23. }
  1. #ifndef __GPIO_H_
  2. #define __GPIO_H_
  3. #include "stm32f10x.h"
  4. #define PA0(a)          if(a)\
  5.                                                         GPIO_SetBits(GPIOA, GPIO_Pin_0);\
  6.                                                 else\
  7.                                                         GPIO_ResetBits(GPIOA, GPIO_Pin_0)
  8. #define PA1(a)          if(a)\
  9.                                                         GPIO_SetBits(GPIOA, GPIO_Pin_1);\
  10.                                                 else\
  11.                                                         GPIO_ResetBits(GPIOA, GPIO_Pin_1)
  12. #define PC7(a)          if(a)\
  13.                                                         GPIO_SetBits(GPIOC, GPIO_Pin_7);\
  14.                                                 else\
  15.                                                         GPIO_ResetBits(GPIOC, GPIO_Pin_7)
  16. #define PA2()                GPIO_ReadInputDataBit(GPIOA, 2)
  17. #define PC6()                GPIO_ReadInputDataBit(GPIOC, 6)
  18. void GPIO_Config(void);
  19.
  20. #endif
PA2-PA1.zip (1.09 MB, 下载次数: 1)
最佳答案
查看完整内容
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU; 这个要改成输入。或者用输入捕获功能进行处理。
收藏 评论13 发布时间:2016-6-4 16:07
13个回答
废鱼 回答时间:2016-6-4 16:07:26
参与人数 1ST金币 +2 收起 理由
zero99 + 2 赞一个!
any012 回答时间:2016-6-4 16:08:19
晕了,GPIO配置函数没有被调用...
调用了也不行,主楼已更新。
废鱼 回答时间:2016-6-4 16:47:47
频率太高了。加个延时。
any012 回答时间:2016-6-4 16:57:05
安 发表于 2016-6-4 16:47
频率太高了。加个延时。
主循环太短吗?
按我的想法,主程序不停的检测PA2的状态,然后根据检测时PA2的状态,将PA1拉高或拉低。
any012 回答时间:2016-6-6 09:01:11
周一人多一些吧,希望有朋友能帮分析下。
埃斯提爱慕 回答时间:2016-6-6 10:30:04
any012 回答时间:2016-6-6 10:40:51
dsjsjf 发表于 2016-6-6 10:30
PA2() == 1 改成 PA2() != Bit_RESET再试试
改成这样了,不行。
  1. int main(void)
  2. {
  3.         GPIO_Config();
  4.         while(1)
  5.         {
  6.                 if(GPIO_ReadInputDataBit(GPIOA, 1) != Bit_RESET)
  7.                         PA1(0);
  8.                 else
  9.                         PA1(1);
  10.         }
  11. }
any012 回答时间:2016-6-6 10:43:56
这样也不行。
  1. int main(void)
  2. {
  3.         GPIO_Config();
  4.         while(1)
  5.         {
  6.
  7.                 if(PA2() != Bit_RESET)
  8.                 {
  9.                         if(GPIO_ReadInputDataBit(GPIOA, 1) == Bit_RESET)
  10.                                 PA1(1);
  11.                 }
  12.                 else
  13.                 {
  14.                         if(GPIO_ReadInputDataBit(GPIOA, 1) != Bit_RESET)
  15.                                 PA1(0);
  16.                 }
  17.         }
  18. }
any012 回答时间:2016-6-6 10:45:07
现在PA1引脚改成OD模式,输出外加个上拉电阻。
问题依旧。
any012 回答时间:2016-6-6 10:52:57
用定时器产生1秒中断,中断里加上:GPIOA->ODR ^= GPIO_Pin_1A1可观测到2s的方波。
硬件应该没问题。还是我理解的不对,程序写的有问题。
any012 回答时间:2016-6-6 11:01:16
主句话错了,应该是:
#define PA2()                GPIO_ReadInputDataBit(GPIOA, GPIO_Pin_2)
参与人数 1ST金币 +2 收起 理由
zero99 + 2 赞一个!
yfy123 回答时间:2016-6-6 12:09:56
研究下。。。
any012 回答时间:2016-6-7 13:57:29
IPU就是上拉输入吧?
