NUCLEO-F413ZH开发板评测及工程示例(基于HAL库)
wjandsq 提问时间:2016-12-9 09:04 /
赞 收藏 2 评论31 发布时间:2016-12-9 09:04
31个回答
liuxy236@tom.co 回答时间:2016-12-10 08:30:15
5265325 回答时间:2016-12-10 10:39:17
lzts 回答时间:2016-12-10 18:59:22
恭喜楼主,谢谢分享.
wjandsq 回答时间:2016-12-12 14:25:49
System Workbench for STM32 - Bare Metal Edition
System Workbench for STM32 - Bare Metal edition 新建开发板例程
小小超 回答时间:2016-12-12 16:23:37
谢谢分享!!!!!!
wjandsq 回答时间:2016-12-13 11:15:09
System Workbench for STM32 - C/C++ Embedded Development Tools for MCU
(STM32官网)
Installation
Installation of System Workbench for STM32 - Bare edition will be done through the standard Eclipse installer.
You should Start Eclipse then open menu "Help >> Install New Software"; this will open the "Available Software" dialog:
You must then create a new update site, to be able to install System Workbench for STM32 - Bare Metal Edition:
1. You should click on "Add:"
2. Then give a name to the update site (System Workbench for STM32 - Bare Machine edition) and set the location to http://www.openstm32.org/Eclipse ... stem-workbench.site
3. Then click "OK" to create the update site
Then you should select all of the OpenSTM32 tools and click "Next>"
You will then just have to accept the license and System Workbench for STM32 - Bare Metal edition will install itself in your Eclipse setup.
Note that you will probably have to restart Eclipse for the tools to be available; Eclipse will automatically suggest the restart.
zero99 回答时间:2016-12-13 13:27:51
来晚了,支持一下,期待楼主更多的评测
wjandsq 回答时间:2016-12-15 22:08:07
新增了两个适用于NUCLEO-F413ZH开发板的示例,串口DMA通讯,按键中断。
USART.zip   USART.zip (1.36 MB, 下载次数: 2)
wjandsq 回答时间:2016-12-15 22:35:33
Ac6软件的最新版本
Ac6软件的最新版本
在最新版本的Eclipse上安装Ac6(System Workbench for STM32)
Ac6高速编译的设置
Ac6高速编译的设置
Ac6高速编译的设置
导入一个Ac6工程
导入一个Ac6工程
导入一个Ac6工程(相当于打开一个工程)
选择导入的工程路径(必须是SW4SSTM32工程)
3生成SW4SSTM32工程的设置
3生成SW4SSTM32工程的设置
生成SW4S STM32工程的STM32CubeMX设置
4Ac6编译速度飞快
4Ac6编译速度飞快
Ac6编译速度飞快
5按键中断调试截图
5按键中断调试截图
按键中断调试截图
NUCLEO-F413ZH开发板 板载ST-LINKV2-1仿真器,而Ac6也可以支持J-Link仿真器,不知道设置的可以找我。
kunchen 回答时间:2017-1-10 13:45:32
谢谢分享
ataudio 回答时间:2017-1-16 10:27:41
为楼主点赞。
还是看不穿 回答时间:2017-1-16 23:20:56
谢谢楼主的讲解,很清晰!!!
lyzjz 回答时间:2018-5-20 00:26:35
好好好好好好好好好好好好
wandashan 回答时间:2019-3-16 19:44:51
这个怎么能下载呢,为何???
wandashan 回答时间:2020-2-28 09:49:46
这个怎么能下载呢,为何???
