出错如下 #1 ERROR(24) File not found Packager files not found #2 ERROR(102) Run stopped because errors were detected netrev run on Jun 30 10:43:48 2011 COMPILE 'logic' CHECK_PIN_NAMES OFF CROSS_REFERENCE OFF FEEDBACK OFF INCREMENTAL OFF INTERFACE_TYPE PHYSICAL MAX_ERRORS 500 MERGE_MINIMUM 5 NET_NAME_CHARS '#%&()*+-./:=>?@[]^_`|' NET_NAME_LENGTH 24 OVERSIGHTS ON REPLACE_CHECK OFF SINGLE_NODE_NETS ON SPLIT_MINIMUM 0 SUPPRESS 20 WARNINGS ON 2 errors detected No oversight detected No warning detected 补充内容 (2018-8-7 16:20): 原理图DRC检测没出错 |
封装文件没找到,检查下封装路么是否正确,另外封装是否错误
封装路径要添加进去,
