求救 新建工程串口log都打不出来
As you like 提问时间:2020-9-22 20:03 /
STM32F429新建一个工程。但是串口log都没有打出来,不知道开没有开机呢!
main.h
#define USART_LOG                        USART3
#define USART_LOG_CLK_ENABLE()              __HAL_RCC_USART3_CLK_ENABLE()
#define USART_LOG_RX_GPIO_CLK_ENABLE()      __HAL_RCC_GPIOB_CLK_ENABLE()
#define USART_LOG_TX_GPIO_CLK_ENABLE()      __HAL_RCC_GPIOB_CLK_ENABLE()
#define USART_LOG_FORCE_RESET()             __HAL_RCC_USART3_FORCE_RESET()
#define USART_LOG_RELEASE_RESET()           __HAL_RCC_USART3_RELEASE_RESET()
/* Definition for USART_LOG Pins */
#define USART_LOG_TX_PIN                    GPIO_PIN_10
#define USART_LOG_TX_GPIO_PORT              GPIOB
#define USART_LOG_TX_AF                     GPIO_AF7_USART3
#define USART_LOG_RX_PIN                    GPIO_PIN_11
#define USART_LOG_RX_GPIO_PORT              GPIOB
#define USART_LOG_RX_AF                     GPIO_AF7_USART3
/* Definition for USART_LOG's NVIC */
#define USART_LOG_IRQn                      USART3_IRQn
#define USART_LOG_IRQHandler                USART3_IRQHandler
main.c
static void Init_USART_Log_GPIO(void)
    Uart_Log.Instance = USART3;
    Uart_Log.Init.BaudRate = 115200;
    Uart_Log.Init.WordLength = UART_WORDLENGTH_8B;
    Uart_Log.Init.StopBits = UART_STOPBITS_1;
    Uart_Log.Init.Parity = UART_PARITY_NONE;
    Uart_Log.Init.Mode = UART_MODE_TX_RX;
    Uart_Log.Init.HwFlowCtl = UART_HWCONTROL_NONE;
    Uart_Log.Init.OverSampling = UART_OVERSAMPLING_16;
    if(HAL_UART_Init(&Uart_Log) != HAL_OK)
        _Error_Handler(__FILE__, __LINE__);
    /* USART3_IRQn interrupt configuration */
    //HAL_NVIC_SetPriority(USART_LOG_IRQn, 5, 0);
    //HAL_NVIC_EnableIRQ(USART_LOG_IRQn);
#ifdef __GNUC__
/* With GCC, small printf (option LD Linker->Libraries->Small printf
   set to 'Yes') calls __io_putchar() */
#define PUTCHAR_PROTOTYPE int __io_putchar(int ch)
#else
#define PUTCHAR_PROTOTYPE int fputc(int ch, FILE *f)
#endif /* __GNUC__ */
PUTCHAR_PROTOTYPE
  /* Place your implementation of fputc here */
  /* e.g. write a character to the USART3 and Loop until the end of transmission */
  HAL_UART_Transmit(&Uart_Log, (uint8_t *)&ch, 1, 0xFFFF);
  return ch;
stm32f4xx_hal_msp.c
void HAL_UART_MspInit(UART_HandleTypeDef *huart)
  GPIO_InitTypeDef  GPIO_InitStruct;
  /*##-1- Enable peripherals and GPIO Clocks #################################*/
  /* Enable GPIO TX/RX clock */
  USART_LOG_TX_GPIO_CLK_ENABLE();
  USART_LOG_RX_GPIO_CLK_ENABLE();
  /* Enable USART1 clock */
  USART_LOG_CLK_ENABLE();
  /*##-2- Configure peripheral GPIO ##########################################*/
  /* UART TX GPIO pin configuration  */
  GPIO_InitStruct.Pin       = USART_LOG_TX_PIN;
  GPIO_InitStruct.Mode      = GPIO_MODE_AF_PP;
  GPIO_InitStruct.Pull      = GPIO_NOPULL;
  GPIO_InitStruct.Speed     = GPIO_SPEED_FAST;
  GPIO_InitStruct.Alternate = USART_LOG_TX_AF;
  HAL_GPIO_Init(USART_LOG_TX_GPIO_PORT, &GPIO_InitStruct);
  /* UART RX GPIO pin configuration  */
  GPIO_InitStruct.Pin = USART_LOG_RX_PIN;
  GPIO_InitStruct.Alternate = USART_LOG_RX_AF;
  HAL_GPIO_Init(USART_LOG_RX_GPIO_PORT, &GPIO_InitStruct);
  /*##-3- Configure the NVIC for UART ########################################*/
  /* NVIC for USART1 */
  HAL_NVIC_SetPriority(USART_LOG_IRQn, 0, 1);
请大神指点一二,有与新人没有币,有酬必报。
赞 收藏 评论0 发布时间:2020-9-22 20:03
