为什么我stm串口中断不响应?
gene719-190105 提问时间:2010-5-29 22:58 /
void NVIC_Configuration(void)
  //NVIC_SetVectorTable(NVIC_VectTab_FLASH, 0x2000);
  // 配置优先级分组,无抢占式优先级
  NVIC_PriorityGroupConfig(NVIC_PriorityGroup_0);
  // 配置USART1中断优先级
  NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn;
  // 配置USART2中断优先级
  NVIC_InitStructure.NVIC_IRQChannel = USART2_IRQn;
  NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;
  // 配置USART3中断优先级
  NVIC_InitStructure.NVIC_IRQChannel = USART3_IRQn;
  NVIC_InitStructure.NVIC_IRQChannelSubPriority = 2;
  // 2010-05-26, zhangxingjuan
  NVIC_InitStructure.NVIC_IRQChannel = EXTI15_10_IRQn;  //中断通道
  NVIC_InitStructure.NVIC_IRQChannelSubPriority = 3;    //次优先级
  NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;       //通道中断使能
  NVIC_Init(&NVIC_InitStructure);                       //初始化中断
串口配置
void USART123_Init(void)
    GPIO_InitTypeDef GPIO_InitStructure;      // GPIO 初始化结构体
USART_InitTypeDef USART_InitStructure;      // USART 初始化结构体
//***********Configure USART1 Tx Pin*********
GPIO_InitStructure.GPIO_Pin = GPIO_Tx1PIN;
//***********Configure USART2 Tx Pin********
    GPIO_InitStructure.GPIO_Pin = GPIO_Tx2PIN;
//***********Configure USART3 Tx Pin*********
    GPIO_InitStructure.GPIO_Pin = GPIO_Tx3PIN;
   //***********Configure USART1 Rx Pin*********
    GPIO_InitStructure.GPIO_Pin = GPIO_Rx1PIN;
//***********Configure USART2 Rx Pin*********
    GPIO_InitStructure.GPIO_Pin = GPIO_Rx2PIN;
//***********Configure USART3 Rx Pin*********
    GPIO_InitStructure.GPIO_Pin = GPIO_Rx3PIN;
    //********USART1 configure para*********
USART_InitStructure.USART_BaudRate = 2400;
USART_InitStructure.USART_WordLength = USART_WordLength_9b;
USART_InitStructure.USART_Parity = USART_Parity_Even;
    USART_Init(USART1,&USART_InitStructure);
/********USART2 configure para*********/
    USART_Init(USART2,&USART_InitStructure);
/********USART3 configure para**********/
    USART_Init(USART3,&USART_InitStructure);
// 使能USART1、2、3的接收中断
    USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);
USART_ITConfig(USART2, USART_IT_RXNE, ENABLE);
USART_ITConfig(USART3, USART_IT_RXNE, ENABLE);
// 使能USART1、2、3
USART_Cmd(USART1, ENABLE);
USART_Cmd(USART2, ENABLE);
USART_Cmd(USART3, ENABLE);
  * @描述:配置系统中断
  * @入口参数: 无
  // 配置优先级分组,无抢占式优先级
  // 配置USART1中断优先级
  // 配置USART2中断优先级
  // 配置USART3中断优先级
以上代码,串口发送数据没问题;但当接收数据时,无法进入USART中断(串口助手监视,是有数据的);研究了半天那个英文编程手册,也没找的出路;望大虾解救。。。。。小弟刚接触STM的片子
赞 收藏 评论3 发布时间:2010-5-29 22:58
3个回答
gene719-190105 回答时间:2010-5-29 23:00:29
RE:为什么我stm串口中断不响应?
,题目貌似写的不完整
suyugangabcd 回答时间:2010-5-30 15:45:04
RE:为什么我stm串口中断不响应?
建议你先检查硬件电路,用示波器看串口接收脚上是否有数据,有时候可能会由于虚焊之类的原因引起,如果是RS485的话,检查一下485芯片的接收使能(RE)是否打开
gene719-190105 回答时间:2010-5-30 19:54:01
RE:为什么我stm串口中断不响应?
多谢楼上,问题今天已解决;确实是硬件问题!
