BeepTimer 1.0(转载)
废鱼 提问时间:2010-8-9 17:07 /
本文内容来自:http://www.stm32circle.com/hom/index.php
Description:(说明)
BeepTimer is a countdown timer. The user controls it by tilting the whole device and by pushing the button.
The typical usage proceeds as follows:
  • Start the program.
  • Tilt the device to the left or to the right to change the time interval.
  • Push button to start the countdown. A short while after the start the screen will go off. The green LED will blink shortly every second the contdown continues.
  • You may cancel the countdown pushing the button shortly.
  • After the countdown ran through, the device begins to blink intensely with the red LED and to beep (because of a bug in Circle OS it  is possible that there will be no sound). Push the button shortly to stop the signalling and to put the countdown into original state.
  • At any point you may exit the program -- press the button and turn the device over at the same time.
The program is free for personal use; otherwise, feel free to contact the author through the forum (personal message is sufficient).
BeepTimer-1.0.zip
98.84 KB, 下载次数: 5, 下载积分: ST金币 -1
赞 收藏 评论0 发布时间:2010-8-9 17:07
