对24C02当前地址读操作
askgod 提问时间:2010-8-17 20:49 /
大家好,想问下那个对IIC写了之后,立即读数据,读到的是下个地址里面的东西,我知道这个是因为其内部存在一个可以加一计数的地址计数器,写操作之后加入延时,再进行读操作,就可以读到当前地址里面的东西了,可以不用延时解决这个问题吗?
下面这个是我们开发板上面的程序,是延时40000后再读操作,可以正确读到地址里面的东西,去掉延时读到的下个地址里面的东西,
怎么样可以不用延时,又可以读到要求的地址里面的东西啊
#include
#include
#include "STM32_Init.h"
#include "TFT200.h"
#define LED             ( 1 APB2ENR |= (1SR1;
 //if (s & (I2C_FLAG_TIMEOUT | I2C_FLAG_PECERR | I2C_FLAG_OVR | I2C_FLAG_AF | I2C_FLAG_ARLO | I2C_FLAG_BERR | I2C_FLAG_STOPF));
    if (s & event) return s;
  return 0;
void sendStart(void) {
 I2C_GenerateSTART(I2C1, ENABLE);       // send start when bus becomes available
 waitForEvent(I2C_FLAG_SB);
 I2C1->DR = I2C_OwnAddr;          // send slave address for transmission
 waitForEvent(I2C_FLAG_ADDR);
 I2C1->SR2;            // clear event
void sendData(u8 data){
  //waitForEvent(I2C_FLAG_TXE);
  waitForEvent(I2C_FLAG_BTF);
  I2C1->DR = data;           // send byte
void sendStop(void) {
  I2C_GenerateSTOP(I2C1, ENABLE);       // send stop after current byte
u8 receiveByte(void) {
  I2C_AcknowledgeConfig(I2C1, DISABLE);     // only one byte will be read
  I2C1->DR = I2C_OwnAddr | 0x01;        // send slave address for reception
  waitForEvent(I2C_FLAG_RXNE);
  return I2C1->DR;           // receive byte
void WriteByte(u16 addr, u8 data) {
  /* Enable I2C1 acknowledgement if it is already disabled by other function */
  //I2C_AcknowledgeConfig(I2C1, ENABLE);
  //I2C_AcknowledgeConfig(I2C1, DISABLE);     // only one byte will be read
  sendStart();
  sendData( addr & 0xFF );
  sendData( data );
  sendStop();
u8 ReadByte(u16 addr) {
  sendStart();
  //sendStart();
  //sendStop();
  return receiveByte();
 |  Delay                                                   |
 |  延时 Inserts a delay time.                              |
 |  nCount: 延时时间                                        |
 |  nCount: specifies the delay time length.                |
void Delay(vu32 nCount) {
  for(; nCount != 0; nCount--);
int main (void) {
  char s[20];
  stm32_Init ();
  LCD_Init();
  LCD_Clear_Screen(Blue);
  LCD_PutString(58,20,"RC-M3 开发板",Cyan,Blue);
  I2C_Initialisation();
  LCD_PutString(70,60,"Write:0x5A",Red,Yellow);
  WriteByte(0x00, 0x5A);
  Delay(40000);        //去掉该行后读到的数据时0X01里面的数据,怎么不用延时,又可以解决问题啊
  sprintf(s, "Read:0x%2X", ReadByte(0x00)); //字符转换
  LCD_PutString(70,100,s,Red,Yellow);
  for(;;) {
    GPIOB->ODR &= ~LED;                         // switch on LED
 Delay(2000000);
    GPIOB->ODR |=  LED;                         // switch off LED
 Delay(2000000);
* Function Name  : assert_failed
* Description    : Reports the name of the source file and the source line number
*                  where the assert error has occurred.
* Input          : - file: pointer to the source file name
*                  - line: assert error line source number
* Output         : None
* Return         : None
void assert_failed(u8* file, u32 line)
  /* User can add his own implementation to report the file name and line number,
     ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  /* Infinite loop */
  while (1)
收藏 评论1 发布时间:2010-8-17 20:49
废鱼 回答时间:2010-8-18 14:47:18
RE:对24C02当前地址读操作
可以使用中断,当读取到数据以后,发送ACK给E2,然后等待下一个数据的到达。
