stm32控制PC卡问题!!!!
楼兰故主 提问时间:2010-9-29 12:03 /
我使用的STM32F103ZCT6 芯片,PC卡使用的CAM(条件接收卡,8位PC卡兼容),硬件接线:
              FSMC                 PC 卡
              A0--A13            A0--A13
              D0--D7             D0--D7
              NEC4_1             CE1
              NIOIS16(接地)     --
              NREG                 NREG
              NIORD                NIORD
              NIOWR               NIOWR
              NOE                   NOE
              NWE                  NWE
              CD                     CD
软件:使用的固件库中提供的结构,初始化如下
        void PCCARD_IO_Init(void)
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_All&&(!GPIO_Pin_6);
 GPIO_InitStructure.GPIO_Mode =GPIO_Mode_AF_PP;
 GPIO_Init(GPIOD, &GPIO_InitStructure);
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6;//NWAIT
 GPIO_InitStructure.GPIO_Mode =GPIO_Mode_IPU;//GPIO_Mode_IPU;
 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_All;
 GPIO_InitStructure.GPIO_Mode =GPIO_Mode_AF_PP;//GPIO_Mode_AF_PP;
 GPIO_Init(GPIOE, &GPIO_InitStructure);
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_All&&(!(GPIO_Pin_9|GPIO_Pin_11));
 GPIO_Init(GPIOF, &GPIO_InitStructure);
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;//CD1
 GPIO_InitStructure.GPIO_Mode =GPIO_Mode_IPU;//GPIO_Mode_AF_PP;
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11;//NIOS16
 GPIO_InitStructure.GPIO_Mode =GPIO_Mode_IN_FLOATING;//GPIO_Mode_AF_PP;
 GPIO_Init(GPIOG, &GPIO_InitStructure);
        GPIO_InitStructure.GPIO_Pin =GPIO_Pin_12; //CD2#
 GPIO_InitStructure.GPIO_Mode =GPIO_Mode_IPU;//;
 GPIO_InitStructure.GPIO_Pin =GPIO_Pin_10|GPIO_Pin_9; //RDX1 TXD1
 GPIO_InitStructure.GPIO_Mode =GPIO_Mode_AF_PP;//;
 GPIO_InitStructure.GPIO_Pin =GPIO_Pin_8; //OE1
 GPIO_InitStructure.GPIO_Mode =GPIO_Mode_Out_PP;//;
 /*OE2,OE3,OE4,OE5*/
 GPIO_InitStructure.GPIO_Pin =GPIO_Pin_6|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9;
 GPIO_Init(GPIOC, &GPIO_InitStructure);
 /*PRESET,CAM_PWR*/
 GPIO_InitStructure.GPIO_Pin =GPIO_Pin_15|GPIO_Pin_14;
 /*I2C_SMBA1,RXD3/SDL,TXD3/SDA*/
 GPIO_InitStructure.GPIO_Pin =GPIO_Pin_10|GPIO_Pin_11|GPIO_Pin_12;
void PCCARD_FSMCConfig(void)
 FSMC_PCCARDInitTypeDef FSMC_PCCARDInitStructure;
 FSMC_NAND_PCCARDTimingInitTypeDef p;
 p.FSMC_SetupTime = 3;
 p.FSMC_WaitSetupTime = 3;
 p.FSMC_HoldSetupTime = 3;
 p.FSMC_HiZSetupTime = 0;
 //FSMC_PCCARDInitStructure.FSMC_Bank = ;
 FSMC_PCCARDInitStructure.FSMC_Waitfeature = FSMC_Waitfeature_Disable; //禁止等待
 FSMC_PCCARDInitStructure.FSMC_AddressLowMapping = FSMC_AddressLowMapping_Direct;//低地址直接映射
        FSMC_PCCARDInitStructure.FSMC_PWID = FSMC_MemoryDataWidth_16b;//数据宽度16位,STM32只能16位访问
        FSMC_PCCARDInitStructure.FSMC_PTYP = FSMC_MemoryType_PCCARD;//卡类型为PCCARD
       FSMC_PCCARDInitStructure.FSMC_TCLRSetupTime = 0x0;
 FSMC_PCCARDInitStructure.FSMC_TARSetupTime = 0x0;
 FSMC_PCCARDInitStructure.FSMC_CommonSpaceTimingStruct = &p;
 FSMC_PCCARDInitStructure.FSMC_AttributeSpaceTimingStruct = &p;
 FSMC_PCCARDInitStructure.FSMC_IOSpaceTimingStruct = &p;
 FSMC_PCCARDInit(&FSMC_PCCARDInitStructure);
 FSMC_PCCARDCmd(ENABLE);
2、我的测试程序如下:
#define PCCARD_reg_base   0x98000000
#define PCCARD_io_base   0x9c000000
RCC_Configuration();
 NVIC_Configuration();
PCCARD_IO_Init();
PCCARD_FSMCConfig();
Delay(300);
 GPIO_SetBits(RESET_PORT, RESET);//对卡reset
 Delay(300);
 GPIO_ResetBits(RESET_PORT, RESET);
 *(u16*)(PCCARD_io_base ) = N;//这句可运行,但控制线,地址,数据线状态不对
  *(u16*)(PCCARD_reg_base ) = N;//此句运行后,程序就进入FaultISR中去了。
 N = *(u16*)(PCCARD_io_base );
 N = *(u16*)(PCCARD_reg_base );
请各位高手帮我看看,是什么原因?还有一事请教,PC卡的读写模式(IO模式(IOWR,IORD),属性模式(OE,WR),)是使用不同的地址,STM32就能产生不同的读写控制信号吗?
赞 收藏 评论1 发布时间:2010-9-29 12:03
GeorgePCB 回答时间:2011-9-20 12:06:39
回复:stm32控制PC卡问题!!!!
我用NCE4_2控制PCCARD,也是遇到同样问题,NCE4_2,NWE,NOE都没有电平变化
#define Bank_PCCARD_ADDR     Bank4_PCCARD_ADDR
#define Bank4_PCCARD_ADDR    ((uint32_t)0x90000000)
void PCCARD_Init(void)
  FSMC_PCCARDInitTypeDef FSMC_PCCADRInitStructure;
  FSMC_PCCADRInitStructure;.FSMC_Waitfeature = FSMC_Waitfeature_Disable; //禁止等待
  FSMC_PCCADRInitStructure;.FSMC_TCLRSetupTime = 0x0;
  FSMC_PCCADRInitStructure;e.FSMC_TARSetupTime = 0x0;
  FSMC_PCCADRInitStructure;e.FSMC_CommonSpaceTimingStruct = &p;
  FSMC_PCCADRInitStructure;.FSMC_AttributeSpaceTimingStruct = &p;
  FSMC_PCCADRInitStructure;.FSMC_IOSpaceTimingStruct = &p;
  FSMC_PCCARDInit(&FSMC_CPLDInitStructure);
void PCCARD_WriteReg(uint16_t PCCARD_Reg, uint16_t PCCARD_RegValue)
  /* Write 16-bit Index, then Write Reg */
  *(__IO uint16_t *)(Bank4_PCCARD_ADDR)  = PCCARD_Reg;
  /* Write 16-bit Reg */
  *(__IO uint16_t *)(Bank4_PCCARD_ADDR) = PCCARD_RegValue;
在主程序中调用 PCCARD_WriteReg(0x0008,0x0000);之前已经做好管脚配置和时钟开启的工作了。
使用示波器监控NCE4_2和NWE的波形, 管脚配置和时钟开启后,NCE4_2和NWE都是高电平,这是正常的。但是执行PCCARD_WriteReg(0x08,0x0000)时,NCE4_2和NWE都没有电平变化,请问哪位大侠能指教是何原因呢?是否是
#define Bank4_PCCARD_ADDR    ((uint32_t)0x90000000) 的地址不正确?
谢谢!
