奇怪,为什么Ad只在初始化的时候起动一次以后,再也没起动呢
lb_zhong 提问时间:2010-11-8 14:04 /
/******************** (C) COPYRIGHT 2008 STMicroelectronics ********************
* File Name          : main.c
* Author             : MCD Application Team
* Version            : V2.0.3
* Date               : 09/22/2008
* Description        : Main program body
/* Includes ------------------------------------------------------------------*/
#include "stm32f10x_lib.h"
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
#define ADC1_DR_Address    ((u32)0x4001244C)
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
ADC_InitTypeDef           ADC_InitStructure;
DMA_InitTypeDef           DMA_InitStructure;
TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
TIM_OCInitTypeDef  TIM_OCInitStructure;
TIM_ICInitTypeDef  TIM_ICInitStructure;
vu16 ADC_RegularConvertedValueTab[32];
ErrorStatus HSEStartUpStatus;
/* Private function prototypes -----------------------------------------------*/
void RCC_Configuration(void);
void GPIO_Configuration(void);
void NVIC_Configuration(void);
void ADC_Sample_Frequency_Set(u32 Frequency)
TIM_Cmd(TIM2, DISABLE);//先停止TIM2时钟,以准备下面的设置
TIM2 配置: 产生TIM2_CC2时钟控制信号用于控制ADC采样
TIM2CLK = 72 MHz
TIM2 ARR Register = 35 => TIM3 Frequency = (TIM3 counter clock/(ARR + 1))/2
TIM2 Frequency = 1000 KHz.
/* Time base configuration */
TIM_TimeBaseStructure.TIM_Period = 35; //APR寄存器
TIM_TimeBaseStructure.TIM_Prescaler = 1000000/Frequency-1; //预分频值,用来调整频率,分频系数=1000khz/(prescaler+1)
TIM_TimeBaseStructure.TIM_ClockDivision = 0;
TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure);
/* TIM_OCMode_Toggle Mode configuration: Channel2 */
TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_Timing;//TIM_OCMode_Toggle;
//TIM_OCInitStructure.TIM_Channel = TIM_Channel_2;
TIM_OCInitStructure.TIM_Pulse = 35;
TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_Low;
TIM_OC2Init(TIM2, &TIM_OCInitStructure);
TIM_OC2PreloadConfig(TIM2, TIM_OCPreload_Enable);
TIM_ARRPreloadConfig(TIM2, ENABLE);
/* TIM2 enable counter */
TIM_Cmd(TIM2, ENABLE);
int main(void)
#ifdef DEBUG
  debug();
#endif
  /* System clocks configuration ---------------------------------------------*/
  RCC_Configuration();
  /* NVIC configuration ------------------------------------------------------*/
  NVIC_Configuration();
  /* GPIO configuration ------------------------------------------------------*/
  GPIO_Configuration();
  /* DMA1 Channel1 Configuration ----------------------------------------------*/
  DMA_DeInit(DMA1_Channel1);
  DMA_InitStructure.DMA_PeripheralBaseAddr = ADC1_DR_Address;
  DMA_InitStructure.DMA_MemoryBaseAddr = (u32)ADC_RegularConvertedValueTab;
  DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC;
  DMA_InitStructure.DMA_BufferSize = 32;
  DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
  DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
  DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
  DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
  DMA_InitStructure.DMA_Mode = DMA_Mode_Normal;
  DMA_InitStructure.DMA_Priority = DMA_Priority_High;
  DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
  DMA_Init(DMA1_Channel1, &DMA_InitStructure);
  /* Enable DMA1 channel1 */
  DMA_Cmd(DMA1_Channel1, ENABLE);
  /* ADC1 configuration ------------------------------------------------------*/
  ADC_InitStructure.ADC_Mode = ADC_Mode_Independent;
  ADC_InitStructure.ADC_ScanConvMode = DISABLE;
  ADC_InitStructure.ADC_ContinuousConvMode = DISABLE;
  ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_T2_CC2;
  ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;
  ADC_InitStructure.ADC_NbrOfChannel = 1;
  ADC_Init(ADC1, &ADC_InitStructure);
  /* ADC1 regular channel14 configuration */
  ADC_RegularChannelConfig(ADC1, ADC_Channel_1, 1, ADC_SampleTime_13Cycles5);
  /* Set injected sequencer length */
  //ADC_InjectedSequencerLengthConfig(ADC1, 1);
  /* ADC1 injected channel Configuration */
  //ADC_InjectedChannelConfig(ADC1, ADC_Channel_11, 1, ADC_SampleTime_71Cycles5);
  /* ADC1 injected external trigger configuration */
  //ADC_ExternalTrigInjectedConvConfig(ADC1, ADC_ExternalTrigInjecConv_None);
  /* Enable automatic injected conversion start after regular one */
  //ADC_AutoInjectedConvCmd(ADC1, ENABLE);
  /* Enable ADC1 DMA */
  ADC_DMACmd(ADC1, ENABLE);
  /* Enable ADC1 external trigger */
  ADC_ExternalTrigConvCmd(ADC1, ENABLE);
  /* Enable JEOC interupt */
  //ADC_ITConfig(ADC1, ADC_IT_JEOC, ENABLE);
  /* Enable ADC1 */
  ADC_Cmd(ADC1, ENABLE);
  /* Enable ADC1 reset calibaration register */
  ADC_ResetCalibration(ADC1);
  /* Check the end of ADC1 reset calibration register */
  while(ADC_GetResetCalibrationStatus(ADC1));
  /* Start ADC1 calibaration */
  ADC_StartCalibration(ADC1);
  /* Check the end of ADC1 calibration */
  while(ADC_GetCalibrationStatus(ADC1));
  ADC_ExternalTrigConvCmd( ADC1, ENABLE);
  /* Test on channel1 transfer complete flag */
//  while(!DMA_GetFlagStatus(DMA1_FLAG_TC1));
  /* Clear channel1 transfer complete flag */
 // DMA_ClearFlag(DMA1_FLAG_TC1);
 ADC_Sample_Frequency_Set(5);
   TIM_DeInit(TIM2); //TIM2初始化
  TIM_TimeBaseStructure.TIM_Period = 0x4AF;  //72M的一秒
  TIM_TimeBaseStructure.TIM_Prescaler = 0xEA5F; //72M/ea5f=4af
  TIM_TimeBaseStructure.TIM_ClockDivision = 0x0;
  TIM_OCInitStructure.TIM_Pulse = 0x0;
  TIM_PrescalerConfig(TIM2, 0xEA5F, TIM_PSCReloadMode_Immediate);
  TIM_ClearFlag(TIM2, TIM_FLAG_Update);
  TIM_ICInitStructure.TIM_Channel = TIM_Channel_2;
  TIM_ICInit(TIM2, &TIM_ICInitStructure);
  /* Enable TIM2 Update interrupt */
  //TIM_ITConfig(TIM2, TIM_IT_Update, ENABLE);
    /* Configure one bit for preemption priority */
  NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);
  /* Enable the TIM2 Interrupt */
  NVIC_InitStructure.NVIC_IRQChannel = TIM2_IRQChannel;
  while (1)
  /* RCC system reset(for debug purpose) */
  RCC_DeInit();
  /* Enable HSE */
  RCC_HSEConfig(RCC_HSE_ON);
  /* Wait till HSE is ready */
  HSEStartUpStatus = RCC_WaitForHSEStartUp();
  if(HSEStartUpStatus == SUCCESS)
    /* Enable Prefetch Buffer */
    FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);
    /* Flash 2 wait state */
    FLASH_SetLatency(FLASH_Latency_2);
    /* HCLK = SYSCLK */
    RCC_HCLKConfig(RCC_SYSCLK_Div1);
    /* PCLK2 = HCLK */
    RCC_PCLK2Config(RCC_HCLK_Div1);
    /* PCLK1 = HCLK/2 */
    RCC_PCLK1Config(RCC_HCLK_Div2);
    /* ADCCLK = PCLK2/4 */
    RCC_ADCCLKConfig(RCC_PCLK2_Div4);
    /* PLLCLK = 8MHz * 7 = 56 MHz */
    RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_7);
    /* Enable PLL */
    RCC_PLLCmd(ENABLE);
    /* Wait till PLL is ready */
    while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET)
    /* Select PLL as system clock source */
    RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
    /* Wait till PLL is used as system clock source */
    while(RCC_GetSYSCLKSource() != 0x08)
/* Enable peripheral clocks --------------------------------------------------*/
  /* Enable DMA1 clock */
  RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE);
  /* Enable GPIOA, GPIOC, ADC1 and TIM1 clock */
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA |
                         RCC_APB2Periph_ADC1|RCC_APB2Periph_GPIOB , ENABLE);
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE);
  /* Configure TIM1_CH1 (PA8) as alternate function push-pull */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1;
  /* Configure PC.01 and PC.04 (ADC Channel11 and Channel14) as analog input */
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN;
  /* Configure PC.06, PC.07, PC.08 as output push-pull */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12 | GPIO_Pin_13 | GPIO_Pin_14;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
 //NVIC_InitTypeDef NVIC_InitStructure;
#ifdef  VECT_TAB_RAM
  /* Set the Vector Table base location at 0x20000000 */
  NVIC_SetVectorTable(NVIC_VectTab_RAM, 0x0);
#else  /* VECT_TAB_FLASH  */
  /* Set the Vector Table base location at 0x08000000 */
  NVIC_SetVectorTable(NVIC_VectTab_FLASH, 0x0);
#endif
  /* Enable ADC1_2 IRQChannel */
  /*NVIC_InitStructure.NVIC_IRQChannel = ADC1_2_IRQChannel;
  NVIC_Init(&NVIC_InitStructure); */
#ifdef  DEBUG
void assert_failed(u8* file, u32 line)
  /* User can add his own implementation to report the file name and line number,
     ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  /* Infinite loop */
  while (1)
#endif
/******************* (C) COPYRIGHT 2008 STMicroelectronics *****END OF FILE****/
赞 收藏 评论3 发布时间:2010-11-8 14:04
3个回答
lb_zhong 回答时间:2010-11-8 14:09:19
RE:奇怪,为什么Ad只在初始化的时候起动一次以后,再也没起动呢
用的时TIM2-CC2定时触发起动
lb_zhong 回答时间:2010-11-8 15:29:08
晕倒,dma修改为DMA_Mode_Circular能够正常运行了
废鱼 回答时间:2010-11-8 15:40:07
DMA需要循环采集,不然只会采集一次。谢谢共享。
