STM32 DMA控制SPI1不成功
hexuanjian 提问时间:2011-2-21 14:01 /
意图:用定时器控制DMA的通道3,通过SPI1去做LED屏的显示刷新(LED是串行接口)。但目前SPI始终不出数据来,时钟有。
代码如下:
       Configures DMA & SPI1
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
/* Extern variables ----------------------------------------------------------*/
extern UINT8 DisplayCells;
extern UINT8 DisplayBufferA[4][160];
/* Private function prototypes -----------------------------------------------*/
/* Private functions ---------------------------------------------------------*/
* Function Name  : ConfigureDMA
* Description    : is used for displaying
* Input          : None.
* Return         : None.
 void ConfigureDMA(void)
  UINT32  DestBaseAddr;
  SPI_InitTypeDef  SPI_InitStructure;
  DMA_InitTypeDef  DMA_InitStructure;
 DestBaseAddr = (UINT32)&SPI1->DR;
 SPI_DeInit(SPI1);                   //set default
 SPI_Cmd(SPI1, DISABLE);
 SPI_InitStructure.SPI_Direction   = SPI_Direction_1Line_Tx;   //SPI_Direction_2Lines_FullDuplex;
 SPI_InitStructure.SPI_Mode     = SPI_Mode_Master;
 SPI_InitStructure.SPI_DataSize    = SPI_DataSize_8b;
 SPI_InitStructure.SPI_CPOL     = SPI_CPOL_High;     //SPI Clock Polarity(时钟悬空时高)
 SPI_InitStructure.SPI_NSS    = SPI_NSS_Soft;
 SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_2;
 SPI_InitStructure.SPI_FirstBit   = SPI_FirstBit_MSB;
 SPI_Init(SPI1, &SPI_InitStructure);           //choose SPI1
 //SPI_CalculateCRC()
 SPI1->CR1 &= (u16)0xDFFF;               // Disable CRC
 SPI_Cmd(SPI1, ENABLE);
// SPI_SendData(SPI1,0x5a);
  DMA_DeInit(DMA_Channel3);             //DMA channel 3 configuration for display text
 DMA_InitStructure.DMA_PeripheralBaseAddr= DestBaseAddr;
 DMA_InitStructure.DMA_MemoryBaseAddr  = (UINT32)DisplayBufferA;
 DMA_InitStructure.DMA_DIR    = DMA_DIR_PeripheralDST;   //Memory to Peripheral
 DMA_InitStructure.DMA_BufferSize  = 16 * DisplayCells;
 DMA_InitStructure.DMA_PeripheralInc  = DMA_PeripheralInc_Disable;
 DMA_InitStructure.DMA_MemoryInc   = DMA_MemoryInc_Enable;
 DMA_InitStructure.DMA_PeripheralDataSize= DMA_PeripheralDataSize_Byte;
 DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_Byte;
 DMA_InitStructure.DMA_Mode    = DMA_Mode_Normal;     //single times mode
 DMA_InitStructure.DMA_Priority   = DMA_Priority_High;
 DMA_InitStructure.DMA_M2M    = DMA_M2M_Disable;
 DMA_Init(DMA_Channel3, &DMA_InitStructure);
 SPI_DMACmd(SPI1, SPI_DMAReq_Tx, ENABLE);
 DMA_ITConfig(DMA_Channel3, DMA_IT_TC, ENABLE);        //DMA_Channel3 Transfer complete interrupt mask
 DMA_Cmd(DMA_Channel3, ENABLE);              //DMA_Channel3 Transfer enable
/****************************** end(DMA Configures)***************************/
我是入门小弟,忘大家多多指点
赞 收藏 评论9 发布时间:2011-2-21 14:01
9个回答
废鱼 回答时间:2011-2-21 14:58:02
RE:STM32 DMA控制SPI1不成功
你可以用示波器先监听一下,输出波形是否真确。这里只看到你配置的部分,不知道你是如何使用的。
hexuanjian 回答时间:2011-2-21 15:06:59
回复:STM32 DMA控制SPI1不成功
谢谢你的回复,我是通过示波器看的,没输出 ,发送完中断也北触发,相关的中断服务函数和I/O口的配置如下:
 RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);
 GPIO_InitStructure.GPIO_Pin   = GPIO_Pin_5 | GPIO_Pin_6 | GPIO_Pin_7 ; //choose config pint
 GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;  //port speed is 50Mhz
 GPIO_InitStructure.GPIO_Mode  = GPIO_Mode_AF_PP;  //push-pull output mode
 GPIO_Init(GPIOA, &GPIO_InitStructure);     //initialization GPIOB
* Function Name  : ConfigureSPI1
* Input          : None.
* Return         : None.
void ConfigureSPI1( void )
 SPI_InitStructure.SPI_Direction   = SPI_Direction_2Lines_FullDuplex;
 SPI_CalculateCRC(SPI1, DISABLE);           // Disable CRC   SPI1->CR1 &= (u16)0xDFFF; SPI_Cmd(SPI1, ENABLE);
* Input          : None.
* Return         : None.
  UINT32 DestBaseAddr = (UINT32)&SPI1->DR;;
 DMA_InitStructure.DMA_M2M    = DMA_M2M_Enable;
* Function Name : DMAChannel3_IRQHandler
* Description   : This function handles DMA Stream 3 interrupt request.
* Input         : None
* Return        : None
* Created By : 何宣见(hexuanjian2005@126.com)
* Created date : 2011.02.11
void DMAChannel3_IRQHandler(void)
   DMA_ClearFlag( DMA_FLAG_TC3);
   DMA_ClearITPendingBit( DMA_FLAG_TC3 );
   DMA_Cmd(DMA_Channel3,DISABLE);
废鱼 回答时间:2011-2-21 16:41:37
你配置了以后,要先用SPI发送一下数据,看看波形是否真确。你只是配置完成了,但是没有通过SPI写数据。
hexuanjian 回答时间:2011-2-21 21:20:47
谢谢啊,我是写了的啊,用SPI_SendData写是可以的,波形正确,但是在定时器中断中通过DMA输出的时候就只有时钟没数据啊
hexuanjian 回答时间:2011-2-22 01:17:51
回复第 5 楼 hexuanjian于2011-02-21 13:20:47发表:
谢谢各位好心人,我是写了的啊,用SPI_SendData写是可以的,波形正确,但是在定时器中断中通过DMA输出的时候就只有时钟没数据啊,具体代码是:
* Function Name : TIM3_IRQHandler
* Description   : This function handles TIM3 global interrupt request.
* Input         : None
* Return        : None
void TIM3_IRQHandler(void)
  TIM_ClearFlag(TIM3, TIM_FLAG_Update);
 TIM_ClearITPendingBit(TIM3,TIM_FLAG_Update);
 ConfigureDMA();
这样是不是就循环启动了DMA控制的SPI传输了?望大家指点!
另外这个传输完中断也没来,是不是SPI传输没有启动成功?
* Input         : None
* Return        : None
    /*判断是否是dma1 channel3 发送完成中断*/
    if(DMA_GetITStatus(DMA_FLAG_TC3)==SET)
        DMA_ClearITPendingBit(DMA_FLAG_TC3);/*清dma1 channel4中断标志*/
废鱼 回答时间:2011-2-22 08:48:04
你没有开启DMA中断。如果想使用中断,还需要配置中断开启。
hexuanjian 回答时间:2011-2-22 09:41:42
谢谢你,但是我是开启中断了的啊,相应中断配置如下:
 NVIC_PriorityGroupConfig(NVIC_PriorityGroup_3);
/***********************************DMAx************************************/
 NVIC_InitStructure.NVIC_IRQChannel = DMAChannel3_IRQChannel;
    NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 2;
究竟是为什么?高步,明白哦!望大家帮我看下啊!还有就是DMA配置中的存储器到存储器现也开启了( DMA_InitStructure.DMA_M2M    = DMA_M2M_Enable;),但是不能触发DMA开始SPI传输
hexuanjian 回答时间:2011-2-22 21:23:41
希望哪位高手指点下啊,这个问题一直纠缠着
废鱼 回答时间:2011-3-8 22:20:33
你用仿真器加断点,看看能不能进去。
