兄弟用ST LIB3.40的库, SMT32F103RET6. DAC+DMA的例子,不知道为什么就是不对. 没有波形出来............. 请问这是为什么啊?????????????? 请大家指点一二.................. 00001 /** 00002 ****************************************************************************** 00003 * @file DAC/OneChannelDMA_Escalator/main.c 00004 * @author MCD Application Team 00005 * @version V3.4.0 00006 * @date 10/15/2010 00007 * @brief Main program body. 00008 ****************************************************************************** 00009 * @copy 00010 * 00011 * THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS 00012 * WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE 00013 * TIME. AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY 00014 * DIRECT, INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING 00015 * FROM THE CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE 00016 * CODING INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS. 00017 * 00018 * © COPYRIGHT 2010 STMicroelectronics 00019 */ 00020 00021 /* Includes ------------------------------------------------------------------*/ 00022 #include "[url=mk MSITStore:F:\StudyST\STM32\stm32f10x_stdperiph_lib3.40\STM32F10x_StdPeriph_Lib_V3.4.0\stm32f10x_stdperiph_lib_um.chm::/stm32f10x_8h.html]stm32f10x.h[/url]"00023 00024 /** @addtogroup STM32F10x_StdPeriph_Examples 00025 * @{ 00026 */ 00027 00028 /** @addtogroup DAC_OneChannelDMA_Escalator 00029 * @{ 00030 */ 00031 00032 /* Private typedef -----------------------------------------------------------*/ 00033 /* Private define ------------------------------------------------------------*/ [url=mk MSITStore:F:\StudyST\STM32\stm32f10x_stdperiph_lib3.40\STM32F10x_StdPeriph_Lib_V3.4.0\stm32f10x_stdperiph_lib_um.chm::/group__DAC__OneChannelDMA__Escalator.html#ga4e2356d33008f4f2f62ea7192a837b20]00034[/url] #define DAC_DHR8R1_Address 0x4000741000035 00036 /* Init Structure definition */ [url=mk MSITStore:F:\StudyST\STM32\stm32f10x_stdperiph_lib3.40\STM32F10x_StdPeriph_Lib_V3.4.0\stm32f10x_stdperiph_lib_um.chm::/group__DAC__OneChannelDMA__Escalator.html#ga9f54bfd3711229dd98a67fd037b07be1]00037[/url] [url=mk MSITStore:F:\StudyST\STM32\stm32f10x_stdperiph_lib3.40\STM32F10x_StdPeriph_Lib_V3.4.0\stm32f10x_stdperiph_lib_um.chm::/structDAC__InitTypeDef.html]DAC_InitTypeDef[/url] [url=mk MSITStore:F:\StudyST\STM32\stm32f10x_stdperiph_lib3.40\STM32F10x_StdPeriph_Lib_V3.4.0\stm32f10x_stdperiph_lib_um.chm::/group__DAC__DualModeDMA__SineWave.html#ga9f54bfd3711229dd98a67fd037b07be1]DAC_InitStructure[/url];[url=mk MSITStore:F:\StudyST\STM32\stm32f10x_stdperiph_lib3.40\STM32F10x_StdPeriph_Lib_V3.4.0\stm32f10x_stdperiph_lib_um.chm::/group__DAC__OneChannelDMA__Escalator.html#gae0d08750e73250f6a9953cd0724658a3]00038[/url] [url=mk MSITStore:F:\StudyST\STM32\stm32f10x_stdperiph_lib3.40\STM32F10x_StdPeriph_Lib_V3.4.0\stm32f10x_stdperiph_lib_um.chm::/structDMA__InitTypeDef.html]DMA_InitTypeDef[/url] [url=mk MSITStore:F:\StudyST\STM32\stm32f10x_stdperiph_lib3.40\STM32F10x_StdPeriph_Lib_V3.4.0\stm32f10x_stdperiph_lib_um.chm::/group__ADC__3ADCs__DMA.html#gae0d08750e73250f6a9953cd0724658a3]DMA_InitStructure[/url];00039 00040 /* Private macro -------------------------------------------------------------*/ 00041 /* Private variables ---------------------------------------------------------*/ [url=mk MSITStore:F:\StudyST\STM32\stm32f10x_stdperiph_lib3.40\STM32F10x_StdPeriph_Lib_V3.4.0\stm32f10x_stdperiph_lib_um.chm::/group__DAC__OneChannelDMA__Escalator.html#ga588f3c9b10d203056c55e23e7c6d7ea4]00042[/url] const uint8_t [url=mk MSITStore:F:\StudyST\STM32\stm32f10x_stdperiph_lib3.40\STM32F10x_StdPeriph_Lib_V3.4.0\stm32f10x_stdperiph_lib_um.chm::/group__DAC__OneChannelDMA__Escalator.html#ga588f3c9b10d203056c55e23e7c6d7ea4]Escalator8bit[/url][6] = {0x0, 0x33, 0x66, 0x99, 0xCC, 0xFF};00043 00044 /* Private function prototypes -----------------------------------------------*/ 00045 void RCC_Configuration(void); 00046 void GPIO_Configuration(void); 00047 void Delay(__IO uint32_t nCount); 00048 00049 /* Private functions ---------------------------------------------------------*/ 00050 00051 /** 00052 * @brief Main program. 00053 * @param None 00054 * @retval None 00055 */ 00056 int main(void) 00057 { 00058 /*!< At this stage the microcontroller clock setting is already configured, 00059 this is done through SystemInit() function which is called from startup 00060 file (startup_stm32f10x_xx.s) before to branch to application main. 00061 To reconfigure the default setting of SystemInit() function, refer to 00062 system_stm32f10x.c file 00063 */ 00064 00065 /* System Clocks Configuration */ 00066 RCC_Configuration(); 00067 00068 /* Once the DAC channel is enabled, the corresponding GPIO pin is automatically 00069 connected to the DAC converter. In order to avoid parasitic consumption, 00070 the GPIO pin should be configured in analog */ 00071 GPIO_Configuration(); 00072 00073 /* TIM6 Configuration */ 00074 TIM_PrescalerConfig(TIM6, 0xF, TIM_PSCReloadMode_Update); 00075 TIM_SetAutoreload(TIM6, 0xFF); 00076 /* TIM6 TRGO selection */ 00077 TIM_SelectOutputTrigger(TIM6, TIM_TRGOSource_Update); 00078 00079 /* DAC channel1 Configuration */ 00080 DAC_InitStructure.DAC_Trigger = DAC_Trigger_T6_TRGO; 00081 DAC_InitStructure.DAC_WaveGeneration = DAC_WaveGeneration_None; 00082 DAC_InitStructure.DAC_OutputBuffer = DAC_OutputBuffer_Disable; 00083 DAC_Init(DAC_Channel_1, &DAC_InitStructure); 00084 00085 #if !defined STM32F10X_LD_VL && !defined STM32F10X_MD_VL 00086 /* DMA2 channel3 configuration */ 00087 DMA_DeInit(DMA2_Channel3); 00088 #else 00089 /* DMA1 channel3 configuration */ 00090 DMA_DeInit(DMA1_Channel3); 00091 #endif 00092 00093 DMA_InitStructure.DMA_PeripheralBaseAddr = DAC_DHR8R1_Address; 00094 DMA_InitStructure.DMA_MemoryBaseAddr = (uint32_t)&Escalator8bit; 00095 DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralDST; 00096 DMA_InitStructure.DMA_BufferSize = 6; 00097 DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable; 00098 DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable; 00099 DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Byte; 00100 DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_Byte; 00101 DMA_InitStructure.DMA_Mode = DMA_Mode_Circular; 00102 DMA_InitStructure.DMA_Priority = DMA_Priority_High; 00103 DMA_InitStructure.DMA_M2M = DMA_M2M_Disable; 00104 00105 #if !defined STM32F10X_LD_VL && !defined STM32F10X_MD_VL 00106 DMA_Init(DMA2_Channel3, &DMA_InitStructure); 00107 /* Enable DMA2 Channel3 */ 00108 DMA_Cmd(DMA2_Channel3, ENABLE); 00109 #else 00110 DMA_Init(DMA1_Channel3, &DMA_InitStructure); 00111 /* Enable DMA1 Channel3 */ 00112 DMA_Cmd( |
RE:ST的例子为什么不对啊!!??
RE:ST的例子为什么不对啊!!??
但是我发现RCC相关位都是正确的。
还DMA我都看了,也没有错啊。。。
真是不知道,ST这个样没有测试过吗??
