Fri Jun 24 19:11:10 2011: Failed to load flash loader: D:\Program Files\IAR Systems\Embedded Workbench 5.4 Kickstart\arm\config\flashloader\ST\FlashSTM32F10xxxRAM16K.out Fri Jun 24 19:11:10 2011: Failed to load flash loader: D:\Program Files\IAR Systems\Embedded Workbench 5.4 Kickstart\arm\config\flashloader\ST\FlashSTM32F10xxB.flash 这是我什么地方设置错了··编印通过了···仿真时出的错误·····我用的是IAR5.50 stlink II 仿真器 |
