    | 我调了有一段时间了  这是我从51程序改过来的 希望高手指正 问题出在哪里 #include "NRF905.H" #include "STM32Lib\\stm32f10x.h" #include "stm32f10x_spi.h" #include "SPI.h" #include "rcc.h" //---------------------------------------------------发送数据缓冲区------------------------------------------------- u8 TxRxBuf[32]= { 0x04,0x02,0x03,0x4,0x05,0x06,0x07,0x08, 0x09,0x10,0x11,0x12,0x13,0x14,0x15,0x16, 0x17,0x18,0x19,0x20,0x21,0x22,0x23,0x24, 0x25,0x26,0x27,0x28,0x29,0x30,0x31,0xff, }; u8 TxAddress[4]={TX_ADDR_Byte0,TX_ADDR_Byte1,TX_ADDR_Byte2,TX_ADDR_Byte3}; u8 RFConf[11]={0x00,0x4c,0x0c,0x44 ,0x20,0x20, 0xCC,0xCC,0xCC,0xCC,0x58}; u8 RxBuf[32]; u8 receive[32]; //uchar tf; void SpiInit(void) { Set_CSN; // Spi disable } /*******************************************************************************************/ //function InitIO(); 初始化IO /*******************************************************************************************/ void nRF905Init(void) { SpiInit(); Clr_DR ; // Init DR for input Clr_AM; // Init AM for input Clr_CD ; // Init CD for input Set_PWR_UP_DDR; // nRF905 power on //SysTickDelay(4); //1毫秒延时 Clr_TRX_CE_DDR; // Set nRF905 in standby mode Clr_TX_EN_DDR; // set radio in Rx mode } void Config905(void) { u16 i; Clr_CSN; // Spi enable for write a spi command //SPI_SendByte(WC); // Write config command写放配置命令 for (i=0;i |
回复:求stm32驱动nrf905程序
