关于定时器2通道2定时触发ADC1转换的程序,程序配置上好像有问题,请大家指教
LYC8686 提问时间:2011-8-3 14:29 /
*TIM2通道2作为ADC1转换的触发时钟200US转换一次--------------------------------- */
  TIM_DeInit(TIM2);                                                //重新将Timer设置为缺省值
  TIM_TimeBaseStructure.TIM_Period = 200;                          //1US*200=200US设置计数溢出大小,
  TIM_TimeBaseStructure.TIM_Prescaler = 20;                        //预分频系数为20 /20=1M(1US)
  TIM_TimeBaseStructure.TIM_ClockDivision = 0;                     //设置时钟分割
  TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;      //设置计数器模式为向上计数模式
  TIM_TimeBaseInit(TIM2,&TIM_TimeBaseStructure);                   //将配置应用到TIM2中
   //PWM设置
  TIM_OCStructInit(&TIM_OCInitStructure);                          //设置缺省值
  TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;                //PWM模式1输出(PWM2也行)
  TIM_OCInitStructure.TIM_Pulse = 15;                              //设置占空比
  TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;        //TIM输出比较极性高 (LOW也行)
  TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;    //使能输出状态
  TIM_OC2Init(TIM2, &TIM_OCInitStructure);                         //初始化TIM2的2通道
  TIM_ARRPreloadConfig(TIM2, ENABLE);                              //使能TIMx在ARR上的预装载寄存器
  TIM_OC2PreloadConfig(TIM2, TIM_OCPreload_Enable);                //使能TIMx在CCR2上的预装载寄存器
 ADC_InitStructure.ADC_Mode     = ADC_Mode_Independent;
  ADC_InitStructure.ADC_ScanConvMode   = ENABLE;
  ADC_InitStructure.ADC_ContinuousConvMode  = DISABLE;
  ADC_InitStructure.ADC_ExternalTrigConv  = ADC_ExternalTrigConv_T2_CC2;
  ADC_InitStructure.ADC_DataAlign    = ADC_DataAlign_Right;
  ADC_InitStructure.ADC_NbrOfChannel   = 9;
  ADC_Init(ADC1, &ADC_InitStructure);
  /* ADC1 Regular Channel1 Configuration                                      */
  ADC_RegularChannelConfig(ADC1, ADC_Channel_10,  1, ADC_SampleTime_41Cycles5);
  ADC_RegularChannelConfig(ADC1, ADC_Channel_11,  2, ADC_SampleTime_41Cycles5);
  ADC_RegularChannelConfig(ADC1, ADC_Channel_12,  3, ADC_SampleTime_41Cycles5);
  ADC_RegularChannelConfig(ADC1, ADC_Channel_1,   4, ADC_SampleTime_41Cycles5);
  ADC_RegularChannelConfig(ADC1, ADC_Channel_2,   5, ADC_SampleTime_41Cycles5);
  ADC_RegularChannelConfig(ADC1, ADC_Channel_1,   6, ADC_SampleTime_41Cycles5);
  ADC_RegularChannelConfig(ADC1, ADC_Channel_2,   7, ADC_SampleTime_41Cycles5);
  ADC_RegularChannelConfig(ADC1, ADC_Channel_10,  8, ADC_SampleTime_41Cycles5);
  ADC_RegularChannelConfig(ADC1, ADC_Channel_16,  9, ADC_SampleTime_239Cycles5);
  /* Enable ADC1 */
  ADC_TempSensorVrefintCmd(ENABLE);//
  ADC_Cmd(ADC1, ENABLE);
  /* Enable ADC1 reset calibaration register */
  ADC_ResetCalibration(ADC1);
  /* Check the end of ADC1 reset calibration register */
  while(ADC_GetResetCalibrationStatus(ADC1));
  /* Start ADC1 calibaration */
  ADC_StartCalibration(ADC1);
  /* Check the end of ADC1 calibration */
  while(ADC_GetCalibrationStatus(ADC1));
  ADC_DMACmd(ADC1, ENABLE);             /* Enable ADC1's DMA interface        */
  ADC_Cmd   (ADC1, ENABLE);             /* Enable ADC1                        */
  ADC_ExternalTrigConvCmd(ADC1, ENABLE);
  //ADC_SoftwareStartConvCmd(ADC1,ENABLE);/* Start ADC1 Software Conversion     */
  TIM_Cmd(TIM2,ENABLE);
  TIM_CtrlPWMOutputs(TIM2,ENABLE);                                 //设置TIM2的PWM输出为使能
程序下载后只能转换一次后就不再定时转换了,是不是上面配置有问题,(我是通过DMA传送ADC转换结果的,DMA配置经验证是对的)
收藏 评论3 发布时间:2011-8-3 14:29
3个回答
废鱼 回答时间:2011-8-3 14:57:16
RE:关于定时器2通道2定时触发ADC1转换的程序,程序配置上好像有问题,请大家指教
是不是你的定时器中断没有清除中断标志位呢?这应该是你定时器配置的问题。还有就是,你使用定时器的时候,可以不开启PWM。
LYC8686 回答时间:2011-8-3 15:12:55
不好意思,我发现问题了,上面程序配置是对的,只是我在主程序中调用出错了,我在主程序中是定时读取AD数据的,定时计数没循环递减造成只读了以便,更改后就正常了。
墨冥伟 回答时间:2013-10-24 17:53:51
回复:关于定时器2通道2定时触发ADC1转换的程序,程序配置上好像有问题,请大家指教
回复第 3 楼 于2011-08-03 15:12:55发表:
能把主程序源码发给我看一下吗 我最近做的这个和你的这个项目很像
