小弟是新手,最近寫了一個UART的測試程式,把RX根TX接在一起,想傳完看接收的資料正不正確,但是只有傳沒收到,請高手幫我看看程式哪邊有BUG int main(void) { /* System Clocks Configuration */ RCC_Configuration(); /* NVIC configuration */ NVIC_Configuration(); /* Configure the GPIO ports */ GPIO_Configuration(); /* Configure the UART1 ports */ UART_Configuration(); for(i=0;i |
RE:有關UART的問題,請高手幫忙解答
这个里面开启了串口时钟了没有?
回复:有關UART的問題,請高手幫忙解答
这个里面开启了串口时钟了没有?
void RCC_Configuration(void)
ErrorStatus HSEStartUpStatus;
/* RCC system reset(for debug purpose) */
RCC_DeInit();
/* Enable HSE */
RCC_HSEConfig(RCC_HSE_ON);
/* Wait till HSE is ready */
HSEStartUpStatus = RCC_WaitForHSEStartUp();
if(HSEStartUpStatus == SUCCESS)
/* Enable Prefetch Buffer */
FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);
/* Flash 2 wait state */
FLASH_SetLatency(FLASH_Latency_2);
/* HCLK = SYSCLK */
RCC_HCLKConfig(RCC_SYSCLK_Div1);
/* PCLK2 = HCLK */
RCC_PCLK2Config(RCC_HCLK_Div1);
/* PCLK1 = HCLK/2 */
RCC_PCLK1Config(RCC_HCLK_Div2);
/* PLLCLK = 8MHz * 9 = 72 MHz */
//RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9);
/* Enable PLL */
RCC_PLLCmd(ENABLE);
/* Wait till PLL is ready */
while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET)
/* Select PLL as system clock source */
RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
/* Wait till PLL is used as system clock source */
while(RCC_GetSYSCLKSource() != 0x08)
/* Enable GPIOD and USART1 clocks */
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD | RCC_APB2Periph_USART1, ENABLE);
void UART_Configuration(void)
USART_InitStructure.USART_BaudRate = 9600;
USART_InitStructure.USART_Parity = USART_Parity_No;
/* Configure USART1 */
USART_Init(USART1, &USART_InitStructure);
/* Enable the USART1 */
USART_Cmd(USART1, ENABLE);
void GPIO_Configuration(void)
/* Enable the USART2 Pins Software Remapping */
//GPIO_PinRemapConfig(GPIO_Remap_USART2, ENABLE);
/* Configure USART1 Rx (PA.10) as input floating */
/* Configure USART2 Rx (PD.06) as input floating */
//GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6;
//GPIO_Init(GPIOD, &GPIO_InitStructure);
/* Configure USART1 Tx (PA.09) as alternate function push-pull */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
/* Configure USART2 Tx (PD.05) as alternate function push-pull */
//GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5;
RCC GPIO UART_Configuration這些這樣寫應該沒錯吧,是要設中斷嗎??
用查询输出,可以不使用中断。没有开启GPIOA的时钟。
感謝~~我把RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD | RCC_APB2Periph_USART1, ENABLE);
改成RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA| RCC_APB2Periph_USART1, ENABLE);就可以了
順便問一下,我看有些範例只下RCC_APB2Periph_USART1就可以跑TX了
那我可以把他解讀成RCC_APB2Periph_USART1---->下TX的CLOCK
RCC_APB2Periph_GPIOA------->下RX的CLOCK嗎
抱歉問很基礎的問題,因為沒基礎,我又是自學的,所以ㄧ些基礎的東西都不清楚
你可能没有看到,不开启GPIOA的时钟使不能工作的。你可以看看他的GPIO配置里面是不是有开启代码。
抱歉在請問一下,我把RX TX原本連在一起解焊了
現在用RS232連接電腦,用超級終端機去模擬接收,我終端機的包率一樣是設9600
可是我接收A跟a收到的都是0X03 B跟b收到的都是0x04,請問是什麼問題
RCC那邊嗎??還是包率那邊??
2、要把ST的RX和TX断开,不然会发不出去
RCC_DeInit();
/* Enable HSE */
/* HCLK = SYSCLK */
/* PCLK2 = HCLK */
/* Enable PLL */
RCC_PLLCmd(ENABLE);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_AFIO, ENABLE);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1, ENABLE);
/* PCLK2 = HCLK */
這個是調整UART1的CLOCK不是嗎??我不管把它改成RCC_HCLK_Div2 RCC_HCLK_Div4 RCC_HCLK_Div8都沒用
還是說不是調整這個 請高手幫我解答
實在是非常菜 不知道要怎麼下手
