现做了一款电路板,用的芯片STM32F100R8,现以焊好电路板,用串口可以下载程序,现在问题是晶振没有启振,程序下载后也没反应,所用的程序都是实例程序编写的,现不知道该如何处理,如果有用过此IC且熟悉编程的大侠,请联系我QQ:27235729,视情况可以有偿请教!具体情况再细聊,情况紧急!非诚勿扰!
RE:现有项目求大侠指点!有偿帮助!谢谢
2、外部晶振要用8Mhz的。
3、你可以选择内部时钟作为时钟源,看看能不能工作。
外部用的是8M的,如果工作会有什么现象?
/*!< RCC system reset(for debug purpose) */
/*!< Set HSION bit */
RCC->CR |= (uint32_t)0x00000001;
/*!< Reset SW[1:0], HPRE[3:0], PPRE1[2:0], PPRE2[2:0], ADCPRE[1:0] and MCO[2:0] bits */
RCC->CFGR &= (uint32_t)0xF8FF0000;
/*!< Reset HSEON, CSSON and PLLON bits */
RCC->CR &= (uint32_t)0xFEF6FFFF;
/*!< Reset HSEBYP bit */
RCC->CR &= (uint32_t)0xFFFBFFFF;
/*!< Reset PLLSRC, PLLXTPRE, PLLMUL[3:0] and USBPRE bits */
RCC->CFGR &= (uint32_t)0xFF80FFFF;
/*!< Disable all interrupts */
RCC->CIR = 0x00000000;
/*!< Configure the System clock frequency, HCLK, PCLK2 and PCLK1 prescalers */
/*!< Configure the Flash Latency cycles and enable prefetch buffer */
//SetSysClock(); //我屏蔽了这句晶振脚就有波形了,奇怪,但LED还是没亮
}大侠能否帮我看下原因,下面是LED的程序看是否正确,
int main(void)
u32 cnt = 0x000fffff;
/* System Clocks Configuration */
RCC_Configuration();
/* Configure the GPIO ports */
GPIO_Configuration();
led_status = LED1;
while (1){
switch (led_status){
case LED1:
//GPIOB->BSRR = 0x1000E000; /* turn on LD1 */
GPIOA->BSRR = 0x00000002; //PA1,输出高电平LED就亮,低电平就灭
led_status = LED2;
break;
case LED2:
//GPIOB->BSRR = 0x2000D000; /* turn on LD2 */
GPIOA->BSRR = 0x20000000;
led_status = LED3;
break;
case LED3:
//GPIOB->BSRR = 0x4000B000; /* turn on LD3 */
led_status = LED4;
break;
case LED4:
//GPIOB->BSRR = 0x80007000; /* turn on LD4 */
led_status = LED1;
break;
while(cnt--);
cnt = 0x000fffff;
void RCC_Configuration(void)
/* Setup the microcontroller system. Initialize the Embedded Flash Interface,
initialize the PLL and update the SystemFrequency variable. */
SystemInit();
/* GPIOA clock enable */
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE);
void GPIO_Configuration(void)
/* GPIOB configuration: PB12 PB13 PB14 PB15 as led controller */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14|GPIO_Pin_15;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_OD;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_2MHz;
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;//GPIO_Mode_Out_PP,GPIO_Mode_Out_OD
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3;
GPIO_Init(GPIOC, &GPIO_InitStructure);
SYSCLK_FREQ_24MHz
