STM8L152开发板的LCD显示
zz19890629 提问时间:2011-10-10 15:47 /
我是个新手,把例程烧录进去了,但板子就是没有反应。。。
这个是例程
我该如何调试,请高手指教
  * @file    LCD/LCD_SegmentsDrive/main.c
  * @author  MCD Application Team
  * @version V1.5.0
  * @date    13-May-2011
  * @brief   Main program body
  * @attention
  * THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
  * WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE
  * TIME. AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY
  * DIRECT, INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING
  * FROM THE CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE
  * CODING INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
  * © COPYRIGHT 2011 STMicroelectronics
/* Includes ------------------------------------------------------------------*/
#include "stm8l15x.h"
#ifdef USE_STM8L1526_EVAL
#include "stm8l1526_eval_glass_lcd.h"
#elif defined USE_STM8L1528_EVAL
#include "stm8l1528_eval_glass_lcd.h"
#endif /* STM8L1526_EVAL */
/** @addtogroup STM8L15x_StdPeriph_Examples
  * @addtogroup LCD_SegmentsDrive
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
#define SCROLL_SPEED  100 /* Low value gives higher speed */
#define SCROLL_NUM    5
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
uint8_t LCD_String[7] = " STM8L ";
/* Private function prototypes -----------------------------------------------*/
#ifdef USE_STM8L1528_EVAL
void LCD_GLASS_DisplaySTM(void);
#endif /* USE_STM8L1528_EVAL */
void Delay(uint32_t nCount);
/* Private functions ---------------------------------------------------------*/
  * @brief  Main program.
  * @param  None
  * @retval None
void main(void)
  /* Configures the LCD GLASS relative GPIO port IOs and LCD peripheral */
  LCD_GLASS_Init();
  /* Enable RTC clock */
  CLK_PeripheralClockConfig(CLK_Peripheral_RTC, ENABLE);
  /* Configures the RTC */
  RTC_WakeUpClockConfig(RTC_WakeUpClock_CK_SPRE_16bits);
  RTC_ITConfig(RTC_IT_WUT, ENABLE);
  /* Enable general Interrupt*/
  enableInterrupts();
  /* Set Matrix Pixels ON to display STM on the LCD Glass */
  LCD_GLASS_DisplaySTM();
  /* Enable the dispaly for the ST Logo */
  LCD_GLASS_DisplayLogo(ENABLE);
  /* Configure the LCD Battery Level High */
  LCD_GLASS_BatteryLevelConfig(BATTERYLEVEL_FULL);
  /* Configure the LCD ArrowDirection */
  LCD_GLASS_ArrowConfig(ARROWDIRECTION_UP);
  LCD_GLASS_ArrowConfig(ARROWDIRECTION_DOWN);
  LCD_GLASS_ArrowConfig(ARROWDIRECTION_LEFT);
  LCD_GLASS_ArrowConfig(ARROWDIRECTION_RIGHT);
  /* Configure the LCD Temperature level */
  LCD_GLASS_TemperatureConfig(TEMPERATURELEVEL_1);
  LCD_GLASS_TemperatureConfig(TEMPERATURELEVEL_2);
  LCD_GLASS_TemperatureConfig(TEMPERATURELEVEL_3);
  LCD_GLASS_TemperatureConfig(TEMPERATURELEVEL_4);
  LCD_GLASS_TemperatureConfig(TEMPERATURELEVEL_5);
  LCD_GLASS_TemperatureConfig(TEMPERATURELEVEL_6);
  /* Configure the LCD ValueUnit */
  LCD_GLASS_ValueUnitConfig(VALUEUNIT_MILLIAMPERE);
  LCD_GLASS_ValueUnitConfig(VALUEUNIT_MICROAMPERE);
  LCD_GLASS_ValueUnitConfig(VALUEUNIT_NANOAMPERE);
  /* Configure the LCD sign */
  LCD_GLASS_SignCmd(SIGN_POSITIVE, ENABLE);
  LCD_GLASS_SignCmd(SIGN_NEGATIVE, ENABLE);
  while (1)
    /*Display " STM8L " string on LCD glass in scrolling mode*/
    LCD_GLASS_ScrollString(LCD_String, SCROLL_NUM, SCROLL_SPEED);
    /* Configures the LCD Blink mode*/
    LCD_BlinkConfig(LCD_BlinkMode_AllSEG_AllCOM, LCD_BlinkFrequency_Div64);
    /* Display "  HALT " string on LCD glass before entering in Halt mode*/
    LCD_GLASS_DisplayString("LP MODE");
    /* Waiting Delay */
    Delay(0x7FFF);
    LCD_BlinkConfig(LCD_BlinkMode_Off, LCD_BlinkFrequency_Div64);
    /* RTC will wake-up from halt every 20second*/
    RTC_SetWakeUpCounter(10);
    RTC_WakeUpCmd(ENABLE);
    /* Display "LP MODE" string on LCD glass before entering in Halt mode*/
    LCD_GLASS_DisplayString(" HALT  ");
    /* Enter Halt mode*/
    halt();
    RTC_WakeUpCmd(DISABLE);
  * @brief  Set all Pixel in the Matrix ON
  * @param  None
  * @retval None
  /*Set Pixels On */
  LCD_GLASS_WriteMatrixPixel(PIXELROW_1, PIXELCOLUMN_1);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_1, PIXELCOLUMN_2);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_1, PIXELCOLUMN_3);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_1, PIXELCOLUMN_4);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_1, PIXELCOLUMN_5);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_1, PIXELCOLUMN_6);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_1, PIXELCOLUMN_7);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_1, PIXELCOLUMN_8);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_1, PIXELCOLUMN_9);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_1, PIXELCOLUMN_10);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_1, PIXELCOLUMN_11);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_1, PIXELCOLUMN_12);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_1, PIXELCOLUMN_13);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_1, PIXELCOLUMN_14);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_1, PIXELCOLUMN_15);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_1, PIXELCOLUMN_16);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_1, PIXELCOLUMN_17);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_1, PIXELCOLUMN_18);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_1, PIXELCOLUMN_19);
  /*Set Row2 Pixels On */
  LCD_GLASS_WriteMatrixPixel(PIXELROW_2, PIXELCOLUMN_1);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_2, PIXELCOLUMN_2);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_2, PIXELCOLUMN_3);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_2, PIXELCOLUMN_11);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_2, PIXELCOLUMN_14);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_2, PIXELCOLUMN_15);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_2, PIXELCOLUMN_16);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_2, PIXELCOLUMN_19);
  /*Set Row3 Pixels On */
  LCD_GLASS_WriteMatrixPixel(PIXELROW_3, PIXELCOLUMN_1);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_3, PIXELCOLUMN_2);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_3, PIXELCOLUMN_4);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_3, PIXELCOLUMN_5);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_3, PIXELCOLUMN_6);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_3, PIXELCOLUMN_7);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_3, PIXELCOLUMN_9);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_3, PIXELCOLUMN_10);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_3, PIXELCOLUMN_11);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_3, PIXELCOLUMN_13);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_3, PIXELCOLUMN_15);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_3, PIXELCOLUMN_17);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_3, PIXELCOLUMN_19);
  /*Set Row4 Pixels On */
  LCD_GLASS_WriteMatrixPixel(PIXELROW_4, PIXELCOLUMN_1);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_4, PIXELCOLUMN_2);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_4, PIXELCOLUMN_4);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_4, PIXELCOLUMN_5);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_4, PIXELCOLUMN_6);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_4, PIXELCOLUMN_7);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_4, PIXELCOLUMN_9);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_4, PIXELCOLUMN_10);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_4, PIXELCOLUMN_11);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_4, PIXELCOLUMN_13);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_4, PIXELCOLUMN_15);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_4, PIXELCOLUMN_17);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_4, PIXELCOLUMN_19);
  /*Set Row5 Pixels On */
  LCD_GLASS_WriteMatrixPixel(PIXELROW_5, PIXELCOLUMN_1);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_5, PIXELCOLUMN_2);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_5, PIXELCOLUMN_3);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_5, PIXELCOLUMN_6);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_5, PIXELCOLUMN_7);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_5, PIXELCOLUMN_9);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_5, PIXELCOLUMN_10);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_5, PIXELCOLUMN_11);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_5, PIXELCOLUMN_13);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_5, PIXELCOLUMN_14);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_5, PIXELCOLUMN_16);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_5, PIXELCOLUMN_17);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_5, PIXELCOLUMN_19);
  /*Set Row6 Pixels On */
  LCD_GLASS_WriteMatrixPixel(PIXELROW_6, PIXELCOLUMN_1);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_6, PIXELCOLUMN_2);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_6, PIXELCOLUMN_3);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_6, PIXELCOLUMN_4);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_6, PIXELCOLUMN_5);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_6, PIXELCOLUMN_7);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_6, PIXELCOLUMN_9);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_6, PIXELCOLUMN_10);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_6, PIXELCOLUMN_11);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_6, PIXELCOLUMN_13);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_6, PIXELCOLUMN_14);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_6, PIXELCOLUMN_15);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_6, PIXELCOLUMN_16);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_6, PIXELCOLUMN_17);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_6, PIXELCOLUMN_19);
  /*Set Row7 Pixels On */
  LCD_GLASS_WriteMatrixPixel(PIXELROW_7, PIXELCOLUMN_1);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_7, PIXELCOLUMN_2);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_7, PIXELCOLUMN_3);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_7, PIXELCOLUMN_4);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_7, PIXELCOLUMN_5);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_7, PIXELCOLUMN_7);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_7, PIXELCOLUMN_9);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_7, PIXELCOLUMN_10);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_7, PIXELCOLUMN_11);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_7, PIXELCOLUMN_13);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_7, PIXELCOLUMN_14);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_7, PIXELCOLUMN_15);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_7, PIXELCOLUMN_16);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_7, PIXELCOLUMN_17);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_7, PIXELCOLUMN_19);
  /*Set Row8 Pixels On */
  LCD_GLASS_WriteMatrixPixel(PIXELROW_8, PIXELCOLUMN_1);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_8, PIXELCOLUMN_2);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_8, PIXELCOLUMN_3);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_8, PIXELCOLUMN_4);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_8, PIXELCOLUMN_5);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_8, PIXELCOLUMN_7);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_8, PIXELCOLUMN_9);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_8, PIXELCOLUMN_10);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_8, PIXELCOLUMN_11);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_8, PIXELCOLUMN_13);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_8, PIXELCOLUMN_14);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_8, PIXELCOLUMN_15);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_8, PIXELCOLUMN_16);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_8, PIXELCOLUMN_17);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_8, PIXELCOLUMN_19);
  /*Set All Row9 Pixels On */
  LCD_GLASS_WriteMatrixPixel(PIXELROW_9, PIXELCOLUMN_1);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_9, PIXELCOLUMN_6);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_9, PIXELCOLUMN_7);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_9, PIXELCOLUMN_9);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_9, PIXELCOLUMN_10);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_9, PIXELCOLUMN_11);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_9, PIXELCOLUMN_13);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_9, PIXELCOLUMN_14);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_9, PIXELCOLUMN_15);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_9, PIXELCOLUMN_16);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_9, PIXELCOLUMN_17);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_9, PIXELCOLUMN_19);
  /*Set All Row10 Pixels On */
  LCD_GLASS_WriteMatrixPixel(PIXELROW_10, PIXELCOLUMN_1);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_10, PIXELCOLUMN_2);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_10, PIXELCOLUMN_3);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_10, PIXELCOLUMN_4);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_10, PIXELCOLUMN_5);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_10, PIXELCOLUMN_6);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_10, PIXELCOLUMN_7);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_10, PIXELCOLUMN_8);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_10, PIXELCOLUMN_9);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_10, PIXELCOLUMN_10);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_10, PIXELCOLUMN_11);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_10, PIXELCOLUMN_12);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_10, PIXELCOLUMN_13);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_10, PIXELCOLUMN_14);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_10, PIXELCOLUMN_15);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_10, PIXELCOLUMN_16);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_10, PIXELCOLUMN_17);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_10, PIXELCOLUMN_18);
  LCD_GLASS_WriteMatrixPixel(PIXELROW_10, PIXELCOLUMN_19);
  * @brief Delay.
  * @param[in] nCount
  * @retval None
  /* Decrement nCount value */
  while (nCount != 0)
    nCount--;
#ifdef  USE_FULL_ASSERT
  * @brief  Reports the name of the source file and the source line number
  *   where the assert_param error has occurred.
  * @param  file: pointer to the source file name
  * @param  line: assert_param error line source number
  * @retval None
void assert_failed(uint8_t* file, uint32_t line)
  /* User can add his own implementation to report the file name and line number,
     ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  /* Infinite loop */
  while (1)
#endif
/******************* (C) COPYRIGHT 2011 STMicroelectronics *****END OF FILE****/
赞 收藏 评论6 发布时间:2011-10-10 15:47
6个回答
zz19890629 回答时间:2011-10-10 15:50:02
回复:STM8L152开发板的LCD显示
下图是我加载的文件,还需要什么吗
hudiqi 回答时间:2012-1-24 14:00:07
看看!谢楼主哈!
woshigeshagua 回答时间:2012-4-16 23:03:05
拿走了!
一一-409357 回答时间:2013-1-7 10:42:36
RE:STM8L152开发板的LCD显示
看看!谢楼主哈!
潇湘 回答时间:2013-3-5 22:59:07
真的吗
潇湘 回答时间:2013-3-5 23:00:43
我靠 ,这是什么东西啊,还以为是STM8L152驱动段式lcd的资料呢
