void CAN_Receive(CAN_TypeDef* CANx, uint8_t FIFONumber, CanRxMsg* RxMessage) { /* Check the parameters */ assert_param(IS_CAN_ALL_PERIPH(CANx)); assert_param(IS_CAN_FIFO(FIFONumber)); /* Get the Id */ RxMessage->IDE = (uint8_t)0x04 & CANx->sFIFOMailBox[FIFONumber].RIR; if (RxMessage->IDE == CAN_Id_Standard) { RxMessage->StdId = (uint32_t)0x000007FF & (CANx->sFIFOMailBox[FIFONumber].RIR >> 21); } else { RxMessage->ExtId = (uint32_t)0x1FFFFFFF & (CANx->sFIFOMailBox[FIFONumber].RIR >> 3); } RxMessage->RTR = (uint8_t)0x02 & CANx->sFIFOMailBox[FIFONumber].RIR; /* Get the DLC */ RxMessage->DLC = (uint8_t)0x0F & CANx->sFIFOMailBox[FIFONumber].RDTR; /* Get the FMI */ RxMessage->FMI = (uint8_t)0xFF & (CANx->sFIFOMailBox[FIFONumber].RDTR >> 8); /* Get the data field */ RxMessage->Data[0] = (uint8_t)0xFF & CANx->sFIFOMailBox[FIFONumber].RDLR; RxMessage->Data[1] = (uint8_t)0xFF & (CANx->sFIFOMailBox[FIFONumber].RDLR >> 8); RxMessage->Data[2] = (uint8_t)0xFF & (CANx->sFIFOMailBox[FIFONumber].RDLR >> 16); RxMessage->Data[3] = (uint8_t)0xFF & (CANx->sFIFOMailBox[FIFONumber].RDLR >> 24); RxMessage->Data[4] = (uint8_t)0xFF & CANx->sFIFOMailBox[FIFONumber].RDHR; RxMessage->Data[5] = (uint8_t)0xFF & (CANx->sFIFOMailBox[FIFONumber].RDHR >> 8); RxMessage->Data[6] = (uint8_t)0xFF & (CANx->sFIFOMailBox[FIFONumber].RDHR >> 16); RxMessage->Data[7] = (uint8_t)0xFF & (CANx->sFIFOMailBox[FIFONumber].RDHR >> 24); /* Release the FIFO */ /* Release FIFO0 */ if (FIFONumber == CAN_FIFO0) { CANx->RF0R |= CAN_RF0R_RFOM0; } /* Release FIFO1 */ else /* FIFONumber == CAN_FIFO1 */ { CANx->RF1R |= CAN_RF1R_RFOM1; } } 这句话 CANx->RF0R |= CAN_RF0R_RFOM0; 是释放邮箱,接收数据是放在邮箱中的,并没有读取,那这样不是把数据给释放掉了,这样理解对不对? ![]() |
RE:can接收函数最后释放邮箱,数据岂不是没保存?
RxMessage->StdId ,这里把ID取走了。
回复:can接收函数最后释放邮箱,数据岂不是没保存?
RxMessage->Data[0] ,这里把数据读取走了。
那邮箱和RxMessage什么关系?
那邮箱和RxMessage什么关系?
FIFO是用来存放数据的,当读取走数据以后,这里就释放掉,给后面的数据使用。这个你可以搜索一下FIFO的工作方式。
接受邮箱,FIFO是sram还是寄存器?对这个没理解透彻?
