求助求助!!!关于pwm波的!!!求指导。。。。真心求。。。
z6115913 提问时间:2011-12-11 10:48 /
/*这个是我自己写的四个通道的代码,我想通过通道2来控制PA7的led渐亮和渐暗,不过不知道为什么不行,跪求各位达人帮我看看,当然是有空的话。。。*/
#include "stm32f10x.h"
   #include
   #include
TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
TIM_OCInitTypeDef TIM_OCInitStructure;
uint16_t CCR1_Val = 300;
uint16_t CCR2_Val = 0;
uint16_t CCR3_Val = 750;
uint16_t CCR4_Val = 0;
uint16_t PrescalerValue = 0;
//void RCC_Configuration(void);                 //时钟配置
//void GPIO_Configuration(void);             //管脚配置
void Delay (__IO uint32_t nCount);         //延时函数
int main(void)
   uint16_t dir=1;
RCC_open();
//GPIO_Configuration();
GPIO_open();
PrescalerValue = (uint16_t) (SystemCoreClock / 24000000) - 1;
TIM_TimeBaseStructure.TIM_Period = 900;                                  //周期
//TIM_TimeBaseStructure.TIM_P.rescaler = PrescalerValue;              //分频
TIM_TimeBaseStructure.TIM_Prescaler = PrescalerValue;
TIM_TimeBaseStructure.TIM_ClockDivision = 0;                             //时钟分割
TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;                //计数模式,向上计数
TIM_TimeBaseInit(TIM3, &TIM_TimeBaseStructure);                    //初始TIM3
/*************************** 通道1 ********************************/
TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM2;    //PWM2
TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;   //PWM功能使能
TIM_OCInitStructure.TIM_Pulse = CCR1_Val;                            //写比较值(占空比
TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_Low;   //置高
TIM_OC1Init(TIM3, &TIM_OCInitStructure);                          //选择1通道
TIM_OC1PreloadConfig(TIM3, TIM_OCPreload_Enable);                                 //一通道使能
/****************************** 通道2 ******************************/
/*PWM1 Mode configuration: Channel2 */
TIM_OCInitStructure.TIM_Pulse = CCR2_Val;
//TIM_OCInitStructure.TIM_OCNPolarity = TIM_OCNPolarity_High;
TIM_OC2Init(TIM3, &TIM_OCInitStructure);
TIM_OC2PreloadConfig(TIM3, TIM_OCPreload_Enable);
/******************************* 通道3 *********************************/
/* PWM1 Mode configuration: Channel3 */
TIM_OCInitStructure.TIM_Pulse = CCR3_Val;
TIM_OC3Init(TIM3, &TIM_OCInitStructure);
TIM_OC3PreloadConfig(TIM3, TIM_OCPreload_Enable);
/****************************** 通道4 *********************************/
/* PWM1 Mode configuration: Channel4 */
TIM_OCInitStructure.TIM_Pulse = CCR4_Val;
TIM_OC4Init(TIM3, &TIM_OCInitStructure);
TIM_OC4PreloadConfig(TIM3, TIM_OCPreload_Enable);
TIM_ARRPreloadConfig(TIM3, ENABLE);                        //
TIM_Cmd(TIM3, ENABLE);                                          //使能计数
while (1)
/*CCR3_Val++;
if(CCR3_Val==1000)CCR3_Val=0;
TIM_SetCompare3(TIM3,CCR3_Val);                         //占空比调节
Delay(0xFfff);
if(dir)
        CCR2_Val++;
else
        CCR2_Val--;
if(CCR2_Val>300)
        dir=0;
if(CCR2_Val==0)
        dir=1;
TIM_SetCompare3(TIM3,CCR2_Val);
Delay(0xFfff);                //为什么要延时这么久?
/*************************** 时钟配置 *******************************/
/*void RCC_Configuration(void)
RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3, ENABLE);             //T3时钟使能
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOB |
                         RCC_APB2Periph_GPIOC | RCC_APB2Periph_AFIO, ENABLE);
               //管脚时钟
/************************** 管脚配置 ******************************/
/*void GPIO_Configuration(void)
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7;
GPIO_InitStructure.GPIO_Pin = 0x7fff;
/************************** 延时函数 ******************************/
        for(; nCount != 0; nCount--);
//子函数
#include
void GPIO_open(void)
        GPIO_InitTypeDef GPIO_opening;
        GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable ,ENABLE);
        /*GPIO_opening.GPIO_Pin = 0xffff;
        GPIO_opening.GPIO_Mode = GPIO_Mode_Out_PP;
        GPIO_opening.GPIO_Speed = GPIO_Speed_50MHz;
        GPIO_Init(GPIOB,&GPIO_opening);
        GPIO_opening.GPIO_Pin=GPIO_Pin_7|GPIO_Pin_6;
        GPIO_opening.GPIO_Mode = GPIO_Mode_AF_PP;
        GPIO_Init(GPIOA,&GPIO_opening);
#include
void RCC_open(void)
//        RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO,ENABLE);
RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3,ENABLE);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO, ENABLE);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA,ENABLE);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB,ENABLE);
//RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO,ENABLE);
赞 收藏 评论2 发布时间:2011-12-11 10:48
baoli01 回答时间:2011-12-14 11:45:19
RE:求助求助!!!关于pwm波的!!!求指导。。。。真心求。。。
我也是初学STM32,楼主的RCC是不是没有配置好,void RCC_Configuration(void)里要把时钟都配置好打开。
shiyiyue-317236 回答时间:2011-12-14 12:55:37
32位的我还没搞,不过8位的已经快弄好了,你最好通读一下TIM3的寄存器及其相关设置,我想还是你的寄存器没设置到位,在8位里有一个TIM1_BKR寄存器,要把这个寄存器的第7位置1才会有输出,你看一下有没有类似的设置。
