问: 程序如下,可以采集脉冲信号,但是IC2Value = TIM_GetCapture1(TIM5);值不稳定,请教各位论坛技术支持,是不是硬件哪块还需要设置?软件我用去极值滤波算法之后的效果也不是很好,主要是硬件寄存器里面的数本身就不稳定。 int main(void) { RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM5, ENABLE); /* GPIOA clock enable */ RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE) NVIC_InitTypeDef NVIC_InitStructure; /* Enable the TIM5 global Interrupt */ NVIC_InitStructure.NVIC_IRQChannel = TIM5_IRQn; NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0; NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1; NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; NVIC_Init(&NVIC_InitStructure); GPIO_InitTypeDef GPIO_InitStructure; /* TIM5 channel 1 pin (PA.00) configuration */ GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_Init(GPIOA, &GPIO_InitStructure); TIM_ICInitTypeDef TIM_ICInitStructure; TIM_ICInitStructure.TIM_Channel = TIM_Channel_1; TIM_ICInitStructure.TIM_ICPolarity = TIM_ICPolarity_Rising; TIM_ICInitStructure.TIM_ICSelection = TIM_ICSelection_DirectTI; TIM_ICInitStructure.TIM_ICPrescaler = TIM_ICPSC_DIV1; TIM_ICInitStructure.TIM_ICFilter = 0x0; TIM_PWMIConfig(TIM5, &TIM_ICInitStructure); /* Select the TIM5 Input Trigger: TI1FP1 */ TIM_SelectInputTrigger(TIM5, TIM_TS_TI1FP1); /* Select the slave Mode: Reset Mode */ TIM_SelectSlaveMode(TIM5, TIM_SlaveMode_Reset); /* Enable the Master/Slave Mode */ TIM_SelectMasterSlaveMode(TIM5, TIM_MasterSlaveMode_Enable); /* TIM enable counter */ TIM_Cmd(TIM5, ENABLE); /* Enable the CC1 Interrupt Request */ TIM_ITConfig(TIM5, TIM_IT_CC1, ENABLE); while (1); } void TIM5_IRQHandler(void) { /* Clear TIM5 Capture compare interrupt pending bit */ TIM_ClearITPendingBit(TIM5, TIM_IT_CC1); /* Get the Input Capture value */ IC2Value = TIM_GetCapture1(TIM5); if (IC2Value != 0) { /* Duty cycle computation */ DutyCycle = (TIM_GetCapture2(TIM5) * 100) / IC2Value; /* Frequency computation */ Frequency = SystemCoreClock / IC2Value; } else { DutyCycle = 0; Frequency = 0; } } |
