STM32 ADC多通道转换的列子
stm-362021 提问时间:2012-7-2 15:58 /
描述:用ADC连续采集11路模拟信号,并由DMA传输到内存。ADC配置为扫描并且连续转换模式,ADC的时钟配置为12MHZ。在每次转换结束后,由DMA循环将转换的数据传输到内存中。ADC可以连续采集N次求平均值。最后通过串口传输出最后转换的结果。
程序如下:
#include "stm32f10x.h"        //这个头文件包括STM32F10x所有外围寄存器、位、内存映射的定义
#include "eval.h"             //头文件(包括串口、按键、LED的函数声明)
#include "SysTickDelay.h"
#include "UART_INTERFACE.h"
#include
#define  N   50               //每通道采50次
#define  M  12               //为12个通道
vu16  AD_Value[N][M];   //用来存放ADC转换结果,也是DMA的目标地址
vu16  After_filter[M];    //用来存放求平均值之后的结果
int         i;
/*GPIO管脚的配置
选用ADC的通道0  1  2  8  9  10  11  12  13  14  15,分别对应的管脚为PA0  PA1  PA2  PB0  PB1  PC0  PC1  PC2  PC3  PC4  PC5
串口使用USART1其中TX为PA9,RX为PA10 */
void GPIO_Configuration(void)
        GPIO_InitTypeDef  GPIO_InitStructure;
                /* Configure USART1 Tx (PA.09) as alternate function push-pull */
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
                GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;  //因为USART1管脚是以复用的形式接到GPIO口上的,所以使用复用推挽式输出
        /* Configure USART1 Rx (PA.10) as input floating */
        //PA0/1/2 作为模拟通道输入引脚
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0| GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN;                //模拟输入引脚
        //PB0/1 作为模拟通道输入引脚
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1;
        //PC0/1/2/3/4/5 作为模拟通道输入引脚
           GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5;
        GPIO_Init(GPIOC, &GPIO_InitStructure);
/*配置系统时钟,使能各外设时钟*/
void RCC_Configuration(void)
           ErrorStatus  HSEStartUpStatus;
     RCC_DeInit();                     //RCC 系统复位
     RCC_HSEConfig(RCC_HSE_ON);      //开启HSE
     HSEStartUpStatus = RCC_WaitForHSEStartUp();  //等待HSE准备好
     if(HSEStartUpStatus == SUCCESS)
       FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable); //Enable Prefetch Buffer
       FLASH_SetLatency(FLASH_Latency_2);      //Set 2 Latency cycles
       RCC_HCLKConfig(RCC_SYSCLK_Div1);   //AHB clock  = SYSCLK
       RCC_PCLK2Config(RCC_HCLK_Div1);   //APB2 clock = HCLK
       RCC_PCLK1Config(RCC_HCLK_Div2);   //APB1 clock = HCLK/2
       RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_6); //PLLCLK = 12MHz * 6 = 72 MHz
       RCC_PLLCmd(ENABLE);          //Enable PLL
       while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET);  //Wait till PLL is ready
       RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK); //Select PLL as system clock source
       while(RCC_GetSYSCLKSource() != 0x08);   //Wait till PLL is used as system clock source
       /*使能各个外设时钟*/
       RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_GPIOB
            | RCC_APB2Periph_GPIOC |RCC_APB2Periph_ADC1 | RCC_APB2Periph_AFIO |RCC_APB2Periph_USART1, ENABLE );          //使能ADC1通道时钟,各个管脚时钟
        /* Configure ADCCLK such as ADCCLK = PCLK2/6 */
       RCC_ADCCLKConfig(RCC_PCLK2_Div6);   //72M/6=12,ADC最大时间不能超过14M
       RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE);        //使能DMA传输
/*配置ADC1*/
void ADC1_Configuration(void)
         ADC_InitTypeDef  ADC_InitStructure;
         ADC_DeInit(ADC1);  //将外设 ADC1 的全部寄存器重设为缺省值
        /* ADC1 configuration ------------------------------------------------------*/
        ADC_InitStructure.ADC_Mode = ADC_Mode_Independent;        //ADC工作模式:ADC1和ADC2工作在独立模式
        ADC_InitStructure.ADC_ScanConvMode =ENABLE;        //模数转换工作在扫描模式
           ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;        //模数转换工作在连续转换模式
        ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None;   //外部触发转换关闭
        ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;        //ADC数据右对齐
        ADC_InitStructure.ADC_NbrOfChannel = M;        //顺序进行规则转换的ADC通道的数目
        ADC_Init(ADC1, &ADC_InitStructure);        //根据ADC_InitStruct中指定的参数初始化外设ADCx的寄存器
        /* ADC1 regular channel11 configuration */
        //设置指定ADC的规则组通道,设置它们的转化顺序和采样时间
        //ADC1,ADC通道x,规则采样顺序值为y,采样时间为239.5周期
        ADC_RegularChannelConfig(ADC1, ADC_Channel_0, 1, ADC_SampleTime_239Cycles5 );
        ADC_RegularChannelConfig(ADC1, ADC_Channel_1, 2, ADC_SampleTime_239Cycles5 );
                ADC_RegularChannelConfig(ADC1, ADC_Channel_2, 3, ADC_SampleTime_239Cycles5 );
        ADC_RegularChannelConfig(ADC1, ADC_Channel_3, 4, ADC_SampleTime_239Cycles5 );
        ADC_RegularChannelConfig(ADC1, ADC_Channel_8, 5, ADC_SampleTime_239Cycles5 );
                ADC_RegularChannelConfig(ADC1, ADC_Channel_9, 6, ADC_SampleTime_239Cycles5 );
        ADC_RegularChannelConfig(ADC1, ADC_Channel_10, 7, ADC_SampleTime_239Cycles5 );
        ADC_RegularChannelConfig(ADC1, ADC_Channel_11, 8, ADC_SampleTime_239Cycles5 );
        ADC_RegularChannelConfig(ADC1, ADC_Channel_12, 9, ADC_SampleTime_239Cycles5 );
        ADC_RegularChannelConfig(ADC1, ADC_Channel_13, 10, ADC_SampleTime_239Cycles5 );
        ADC_RegularChannelConfig(ADC1, ADC_Channel_14, 11, ADC_SampleTime_239Cycles5 );
        ADC_RegularChannelConfig(ADC1, ADC_Channel_15, 12, ADC_SampleTime_239Cycles5 );
         // 开启ADC的DMA支持(要实现DMA功能,还需独立配置DMA通道等参数)
           ADC_DMACmd(ADC1, ENABLE);
         /* Enable ADC1 */
         ADC_Cmd(ADC1, ENABLE);           //使能指定的ADC1
         /* Enable ADC1 reset calibaration register */
         ADC_ResetCalibration(ADC1);          //复位指定的ADC1的校准寄存器
         /* Check the end of ADC1 reset calibration register */
         while(ADC_GetResetCalibrationStatus(ADC1));        //获取ADC1复位校准寄存器的状态,设置状态则等待
         /* Start ADC1 calibaration */
         ADC_StartCalibration(ADC1);                //开始指定ADC1的校准状态
         /* Check the end of ADC1 calibration */
         while(ADC_GetCalibrationStatus(ADC1));                //获取指定ADC1的校准程序,设置状态则等待
/*配置DMA*/
void DMA_Configuration(void)
        /* ADC1  DMA1 Channel Config */
        DMA_InitTypeDef DMA_InitStructure;
        DMA_DeInit(DMA1_Channel1);   //将DMA的通道1寄存器重设为缺省值
        DMA_InitStructure.DMA_PeripheralBaseAddr =  (u32)&ADC1->DR;  //DMA外设ADC基地址
        DMA_InitStructure.DMA_MemoryBaseAddr = (u32)&AD_Value;  //DMA内存基地址
        DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC;  //内存作为数据传输的目的地
        DMA_InitStructure.DMA_BufferSize = N*M;  //DMA通道的DMA缓存的大小
        DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;  //外设地址寄存器不变
        DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;  //内存地址寄存器递增
        DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;  //数据宽度为16位
        DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord; //数据宽度为16位
        DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;  //工作在循环缓存模式
        DMA_InitStructure.DMA_Priority = DMA_Priority_High; //DMA通道 x拥有高优先级
        DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;  //DMA通道x没有设置为内存到内存传输
        DMA_Init(DMA1_Channel1, &DMA_InitStructure);  //根据DMA_InitStruct中指定的参数初始化DMA的通道
//配置所有外设
void Init_All_Periph(void)
        RCC_Configuration();
        GPIO_Configuration();
        ADC1_Configuration();
        DMA_Configuration();
        //USART1_Configuration();
        USART_Configuration(9600);
/*获取ADC的值,将二进制换算为十进制*/
u16 GetVolt(u16 advalue)
   return (u16)(advalue * 330 / 4096);   //求的结果扩大了100倍,方便下面求出小数
/*求平均值函数*/
void filter(void)
          int  sum = 0;
        u8  count;
          for(i=0;i
赞 收藏 评论1 发布时间:2012-7-2 15:58
fxw451 回答时间:2012-7-2 17:25:12
回复:STM32 ADC多通道转换的列子
楼主要把全部资料上传上来,让大家感到好处后,大家自热而然的就买你家的产品了。服务上去了,什么都有了。
