/* Time base configuration */ TIM_TimeBaseStructInit(&TIM_TimeBaseStructure); TIM_TimeBaseStructure.TIM_Period = newFreq-1;//0x32; TIM_TimeBaseStructure.TIM_Prescaler = 0x0; TIM_TimeBaseStructure.TIM_ClockDivision = 0x0; TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up; TIM_TimeBaseInit(TIM8, &TIM_TimeBaseStructure); /* TIM8 TRGO selection */ TIM_SelectOutputTrigger(TIM8, TIM_TRGOSource_Update); /* DAC channel1 Configuration */ DAC_InitStructure.DAC_Trigger = DAC_Trigger_T8_TRGO; DAC_InitStructure.DAC_WaveGeneration = DAC_WaveGeneration_None; DAC_InitStructure.DAC_OutputBuffer = DAC_OutputBuffer_Disable; DAC_Init(DAC_Channel_1, &DAC_InitStructure); /* DAC channel2 Configuration */ DAC_Init(DAC_Channel_2, &DAC_InitStructure); /* DMA2 channel4 configuration */ DMA_DeInit(DMA2_Channel4); DMA_InitStructure.DMA_PeripheralBaseAddr = DAC_DHR12RD_Address; DMA_InitStructure.DMA_MemoryBaseAddr = (u32)&DualSine12bit; DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralDST; //外设作为目的 DMA_InitStructure.DMA_BufferSize = BufferSize; DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable; //外设地址不变 DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable; //内存地址增加 DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Word; DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_Word; DMA_InitStructure.DMA_Mode = DMA_Mode_Circular; //循环模式 DMA_InitStructure.DMA_Priority = DMA_Priority_High; //优先级高 DMA_InitStructure.DMA_M2M = DMA_M2M_Disable; DMA_Init(DMA2_Channel4, &DMA_InitStructure); /* Enable DMA2 Channel4 */ DMA_Cmd(DMA2_Channel4, ENABLE); /* Enable DAC Channel1 */ DAC_Cmd(DAC_Channel_1, ENABLE); /* Enable DAC Channel2 */ DAC_Cmd(DAC_Channel_2, ENABLE); /* Enable DMA for DAC Channel2 */ DAC_DMACmd(DAC_Channel_1, ENABLE); /*以下为ADC触发*/ /* Time base configuration */ TIM_TimeBaseStructure.TIM_Period = BufferSize-1; TIM_TimeBaseStructure.TIM_Prescaler = 0; TIM_TimeBaseStructure.TIM_ClockDivision = 0; TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up; TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure); /* TIM2 channel2 configuration in PWM mode */ TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1; TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable; TIM_OCInitStructure.TIM_Pulse = 8; TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High; TIM_OC2Init(TIM2, &TIM_OCInitStructure); TIM_SelectMasterSlaveMode(TIM8,TIM_MasterSlaveMode_Enable);// 主从模式 TIM_SelectSlaveMode(TIM2,TIM_SlaveMode_External1); //从模式 上升沿作为计数脉冲 TIM_SelectInputTrigger(TIM2,TIM_TS_ITR1); /* Enable TIM2 outputs */ //TIM_CtrlPWMOutputs(TIM2, ENABLE); /* DMA1 Channel1 Configuration ----------------------------------------------*/ DMA_DeInit(DMA1_Channel1); DMA_InitStructure.DMA_PeripheralBaseAddr = ADC1_DR_Address; DMA_InitStructure.DMA_MemoryBaseAddr = (u32)ADC_RegularConvertedValueTab; DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC; //外设作为源 DMA_InitStructure.DMA_BufferSize = 64; DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable; DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable; DMA_InitStructure.DMA_PeripheralDataSize = DMA_MemoryDataSize_Word; DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_Word; DMA_InitStructure.DMA_Mode = DMA_Mode_Normal; DMA_InitStructure.DMA_Priority = DMA_Priority_High; DMA_InitStructure.DMA_M2M = DMA_M2M_Disable; DMA_Init(DMA1_Channel1, &DMA_InitStructure); /* Enable DMA1 channel1 */ DMA_Cmd(DMA1_Channel1, ENABLE); /* Enable DMA1 channel1 ITconfig */ DMA_ITConfig(DMA1_Channel1, DMA_IT_TC, ENABLE); /* ADC1 configuration ------------------------------------------------------*/ ADC_InitStructure.ADC_Mode = ADC_Mode_RegSimult; //ADC1 and ADC2 为同步规则模式 ADC_InitStructure.ADC_ScanConvMode = DISABLE; //单通道模式 ADC_InitStructure.ADC_ContinuousConvMode = ENABLE; //循换模式 ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_T2_CC2; ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right; ADC_InitStructure.ADC_NbrOfChannel = 1; ADC_Init(ADC1, &ADC_InitStructure); ADC_RegularChannelConfig(ADC1, ADC_Channel_12, 1, ADC_SampleTime_55Cycles5); //规则 ADC_DMACmd(ADC1, ENABLE); // /* ADC2 configuration ------------------------------------------------------*/ ADC_InitStructure.ADC_Mode = ADC_Mode_RegSimult; ADC_InitStructure.ADC_ScanConvMode = DISABLE; ADC_InitStructure.ADC_ContinuousConvMode = ENABLE; ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None; ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right; ADC_InitStructure.ADC_NbrOfChannel = 1; ADC_Init(ADC2, &ADC_InitStructure); /* ADC1/2 regular channel12/13 configuration */ ADC_RegularChannelConfig(ADC2, ADC_Channel_13, 1, ADC_SampleTime_55Cycles5); //规则 7.38us /* Enable ADC2 external trigger conversion */ ADC_ExternalTrigConvCmd(ADC2, ENABLE); /* Enable EOC interupt */ ADC_ITConfig(ADC1, ADC_IT_EOC, ENABLE); /* Enable ADC1 */ ADC_Cmd(ADC1, ENABLE); /* Enable ADC1 reset calibaration register */ ADC_ResetCalibration(ADC1); /* Check the end of ADC1 reset calibration register */ while(ADC_GetResetCalibrationStatus(ADC1)); /* Start ADC1 calibaration */ ADC_StartCalibration(ADC1); /* Check the end of ADC1 calibration */ while(ADC_GetCalibrationStatus(ADC1)); /* Enable ADC2 */ ADC_Cmd(ADC2, ENABLE); /* Enable ADC2 reset calibaration register */ ADC_ResetCalibration(ADC2); /* Check the end of ADC1 reset calibration register */ while(ADC_GetResetCalibrationStatus(ADC2)); /* Start ADC2 calibaration */ ADC_StartCalibration(ADC2); /* Check the end of ADC1 calibration */ while(ADC_GetCalibrationStatus(ADC2)); /* TIM8 enable counter */ TIM_Cmd(TIM8, ENABLE); /* TIM2 enable counter */ TIM_Cmd(TIM2, ENABLE); 程序大概是这样我通过DAC产生一个正弦波,DAC触发有定时器8完成,该正弦波一个周期打64个点,频率可调。打到第八个点的时候,启动双ADC转换,,每次转换1次操作,共采集64个数据。ADC触发有定时器2控制,设置捕获值为8。将定时器设置为主模式,定时器2设置为从模式。每次定时器8计数满是定时器2加1一次,当加到捕获值为8的时候启动ADC转换,程序不知道为什么进不了ADC中断函数,已经调了1个星期还是没有搞定。望高手帮我看看啊 |
回复:双ADC触发问题
void NVIC_Configuration(void)
/* Configure and enable ADC interrupt */
NVIC_InitStructure.NVIC_IRQChannel = ADC1_2_IRQn;
调用它,试一试
