DAC问题求助,没信号输出【悬赏问答】
bkc 提问时间:2012-7-5 10:36 /
小弟初学者,问板上大侠。我在用DAC做信号输出,三角波可以正常输出,现在在用DMA做正弦信号输出。网上找的一份例程,几经修改,才经过编译没有错误,但就是示波器检测不到信号。哪位好心人帮着看下呗。
/* Includes ------------------------------------------------------------------*/
#include "stm32f10x_lib.h"
#include
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
#define DAC1_DHR8R1_Address      0x40007408
/* Init Structure definition */
DAC_InitTypeDef            DAC_InitStructure;
DMA_InitTypeDef            DMA_InitStructure;
TIM_TimeBaseInitTypeDef    TIM_TimeBaseStructure;
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
ErrorStatus HSEStartUpStatus;
u16 Sine12bit[32] = {2047, 2447, 2831, 3185, 3498, 3750, 3939, 4056, 4095, 4056,
                      3939, 3750, 3495, 3185, 2831, 2447, 2047, 1647, 1263, 909,
                      599, 344, 155, 38, 0, 38, 155, 344, 599, 909, 1263, 1647};
u32 DualSine12bit[32];
u8 Idx = 0;
/* Private function prototypes -----------------------------------------------*/
void RCC_Configuration(void);
void GPIO_Configuration(void);
void NVIC_Configuration(void);
/* Private functions ---------------------------------------------------------*/
* Function Name  : main
* Description    : Main program.
* Input          : None
* Output         : None
* Return         : None
int main(void)
#ifdef DEBUG
  debug();
#endif
   /* GPIO configuration */
  GPIO_Configuration();
  /* System Clocks Configuration */
  RCC_Configuration();
  /* NVIC Configuration */
  NVIC_Configuration();
  /* TIM2 Configuration */
  /* Time base configuration */
  TIM_TimeBaseStructInit(&TIM_TimeBaseStructure);
  TIM_TimeBaseStructure.TIM_Period = 0x19;
  TIM_TimeBaseStructure.TIM_Prescaler = 0x00;
  TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1;
  TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
  TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure);
  /* TIM8 TRGO selection */
  TIM_SelectOutputTrigger(TIM2, TIM_TRGOSource_Update);
  /* DAC channel1 Configuration */
  DAC_InitStructure.DAC_Trigger = DAC_Trigger_T2_TRGO;
  DAC_InitStructure.DAC_WaveGeneration = DAC_WaveGeneration_None;
  DAC_InitStructure.DAC_OutputBuffer = DAC_OutputBuffer_Enable;
  DAC_Init(DAC_Channel_1, &DAC_InitStructure);
  /* Fill Sine32bit table */
  for (Idx= 0; Idx
赞 收藏 评论18 发布时间:2012-7-5 10:36
18个回答
bkc 回答时间:2012-7-5 10:39:26
回复:DAC问题求助,没信号输出
开发板,STM32F107VCT6
liyonghong_bj 回答时间:2012-7-5 13:48:40
RE:DAC问题求助,没信号输出
配置为模拟通道在试试
bkc 回答时间:2012-7-5 14:27:05
回复:DAC问题求助,没信号输出
回复第 3 楼 于2012-07-05 13:48:40发表:
配置为模拟通道在试试
刚试了下,还是没效果。。。
liyonghong_bj 回答时间:2012-7-5 14:32:32
RE:DAC问题求助,没信号输出
你在程序运行时,看看DAC数据寄存器的值对不对,可能DMA配置有问题,word
bkc 回答时间:2012-7-5 15:36:11
回复:DAC问题求助,没信号输出
回复第 5 楼 于2012-07-05 14:32:32发表:
DMA_PeripheralDataSize,DMA_MemoryDataSize配置成byte和half_word都试了一下,没有什么效果。
另外弱问,怎样在程序运行时,查看DAC数据寄存器的值呀?新手,谅解,谢谢,是串口输出,还是特殊的软件工具?
yjwpm 回答时间:2012-7-12 15:32:08
RE:DAC问题求助,没信号输出【悬赏问答】
你仔细检查一下你的DMA配置项,看看是不是哪里没有设置对,看一下地址引用的地方是不是有问题。
航天航海 回答时间:2012-7-12 15:42:05
很有可能是DMA配置项的问题,顺便看看DAC数据寄存器的值对不对。
xiaodc88 回答时间:2012-7-12 19:10:16
肯定是DMA设置不对,仔细查查。我试过可以哈
cx032302 回答时间:2012-7-13 09:49:07
试下这段代码
void DAC_Configuration(void)
       DAC_InitTypeDef DAC_InitStruct;
        RCC_APB1PeriphClockCmd(RCC_APB1Periph_DAC, ENABLE);
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);
        /* Configure DAC channe1 outputs pins */
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN;
        DAC_DeInit();
        DAC_Cmd(DAC_Channel_1,ENABLE); //
    //DAC_Cmd(DAC_Channel_2, ENABLE);
        DAC_StructInit(&DAC_InitStruct);//将DAC_Struct的值设为默认
        DAC_InitStruct.DAC_Trigger=DAC_Trigger_Software;//由软件触发
        DAC_InitStruct.DAC_WaveGeneration=DAC_WaveGeneration_None;//关闭波形生成
        DAC_InitStruct.DAC_LFSRUnmask_TriangleAmplitude=DAC_TriangleAmplitude_4095;
        DAC_InitStruct.DAC_OutputBuffer=DAC_OutputBuffer_Enable;//使能DAC通道缓存
        DAC_Init(DAC_Channel_1,&DAC_InitStruct);
    /* Enable DAC Channel1 */
        DAC_Cmd(DAC_Channel_1, ENABLE);
        DAC_SetChannel1Data(DAC_Align_12b_R,0x000);//12位右对齐,
        DAC_DualSoftwareTriggerCmd(ENABLE);//使能软件触发,更新DAC的值
starcool 回答时间:2012-7-13 11:57:09
你是用DAC作正弦输出的么。是用于控制的吗?如果是,不妨试试用查正弦表的方法,简单,而且可靠些。
bkc 回答时间:2012-7-14 08:11:42
回复:DAC问题求助,没信号输出【悬赏问答】
回复第 10 楼 于2012-07-13 09:49:07发表:
试下这段代码
DAC_DeInit();
你这个是三角波吧,三角波我试过,是对的
bkc 回答时间:2012-7-14 08:15:30
回复第 9 楼 于2012-07-12 19:10:16发表:
u8 Idx = 0;
for (Idx= 0; Idx
bkc 回答时间:2012-7-14 08:16:53
回复第 11 楼 于2012-07-13 11:57:09发表:
确实是做正弦输出,查正弦表就是这个方法吧
bkc 回答时间:2012-7-14 08:17:51
回复第 8 楼 于2012-07-12 15:42:05发表:
求教您是怎样配置的,能否借鉴一下?非常感谢
12下一页
