最近在学习 DCMI接口 通过DMA将DCMI接口中的数据传送到内存中的一个数组中,DCMI 和 DMA都有自己的中断入口,DCMI有行同步中断 和帧同步中断,这两个中断都可以自动进入,但DMA2的传送完毕中断就是进不去,我知道DCMI中有个函数可以置位CAPTURE位,这个位可以通知DMA起动传送,我置为了可DMA2的中断就是没响应!我用的是MDK,有知道的朋友能否指点一下!
回复:DCMI 接口DMA 传送数据问题【悬赏问答】
DMA_ITConfig(DMA2_Stream1,DMA_IT_TC,ENABLE);//传送完成中断
DMA_Init(DMA2_Stream1, &DMA_InitStructure);
NVIC_InitStructure.NVIC_IRQChannel = DMA2_Stream1_IRQn;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 2;
另外我这边也是用的fsmc驱动tft 遇到了问题 就是图像数据 传不完整
RE:DCMI 接口DMA 传送数据问题【悬赏问答】
DCMI_InitTypeDef DCMI_InitStructure;
DMA_InitTypeDef DMA_InitStructure;
//使能DAMI 的GPIO时钟
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA | RCC_AHB1Periph_GPIOB |
RCC_AHB1Periph_GPIOC, ENABLE);
//使能DCMI时钟
RCC_AHB2PeriphClockCmd(RCC_AHB2Periph_DCMI, ENABLE);
//连接DCMI管脚到AF13功能
GPIO_PinAFConfig(GPIOA, GPIO_PinSource4, GPIO_AF_DCMI);
GPIO_PinAFConfig(GPIOA, GPIO_PinSource6, GPIO_AF_DCMI);
GPIO_PinAFConfig(GPIOB, GPIO_PinSource6, GPIO_AF_DCMI);
GPIO_PinAFConfig(GPIOB, GPIO_PinSource7, GPIO_AF_DCMI);
GPIO_PinAFConfig(GPIOB, GPIO_PinSource8, GPIO_AF_DCMI);
GPIO_PinAFConfig(GPIOB, GPIO_PinSource9, GPIO_AF_DCMI);
GPIO_PinAFConfig(GPIOC, GPIO_PinSource6, GPIO_AF_DCMI);
GPIO_PinAFConfig(GPIOC, GPIO_PinSource7, GPIO_AF_DCMI);
GPIO_PinAFConfig(GPIOC, GPIO_PinSource8, GPIO_AF_DCMI);
GPIO_PinAFConfig(GPIOC, GPIO_PinSource9, GPIO_AF_DCMI);
GPIO_PinAFConfig(GPIOC, GPIO_PinSource11, GPIO_AF_DCMI);
// DCMI GPIO 配置
// D0..D4(PC6/7/8/9/11)
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6 | GPIO_Pin_7 |
GPIO_Pin_8 | GPIO_Pin_9 | GPIO_Pin_11;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz;
GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP ;
GPIO_Init(GPIOC, &GPIO_InitStructure);
// D5..D7(PB6/8/9), VSYNC(PB7)
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6 | GPIO_Pin_7 | GPIO_Pin_8 | GPIO_Pin_9;
// PCLK(PA6) HSYNC(PA4)
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4 | GPIO_Pin_6;
// DCMI 配置
DCMI_InitStructure.DCMI_CaptureMode = DCMI_CaptureMode_Continuous;
DCMI_InitStructure.DCMI_SynchroMode = DCMI_SynchroMode_Hardware;
DCMI_InitStructure.DCMI_PCKPolarity = DCMI_PCKPolarity_Falling;
DCMI_InitStructure.DCMI_VSPolarity = DCMI_VSPolarity_High;
DCMI_InitStructure.DCMI_HSPolarity = DCMI_HSPolarity_High;
DCMI_InitStructure.DCMI_CaptureRate = DCMI_CaptureRate_All_Frame;
DCMI_InitStructure.DCMI_ExtendedDataMode = DCMI_ExtendedDataMode_8b;
DCMI_Init(&DCMI_InitStructure);
// 配置 DMA2 传输数据从DCMI 到 LCD
// 使能 DMA2 时钟
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_DMA2, ENABLE);
//DMA2 Stream1 配置
DMA_DeInit(DMA2_Stream1);
DMA_InitStructure.DMA_Channel = DMA_Channel_1;
DMA_InitStructure.DMA_PeripheralBaseAddr = DCMI_DR_ADDRESS;
DMA_InitStructure.DMA_Memory0BaseAddr = FSMC_LCD_ADDRESS;
DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralToMemory;
DMA_InitStructure.DMA_BufferSize = 1;
DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Disable;
DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Word;
DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;
DMA_InitStructure.DMA_Priority = DMA_Priority_High;
DMA_InitStructure.DMA_FIFOMode = DMA_FIFOMode_Enable;
DMA_InitStructure.DMA_FIFOThreshold = DMA_FIFOThreshold_Full;
DMA_InitStructure.DMA_MemoryBurst = DMA_MemoryBurst_Single;
DMA_InitStructure.DMA_PeripheralBurst = DMA_PeripheralBurst_Single;
你看下这个配置,这是DCMI驱动ov7670的配置
//DMA2 Stream1 配置
我想问下,STM32的DCMI接口进行DMA传输非得这样配置吗?可不可以用DMA1或者另外的通道?我用另外的通道一直行不通
NVIC_PriorityGroupConfig(NVIC_PriorityGroup_1);
在DMA初始化完成之后把这几句加上,相应的部分要修改。你在试试
