STM32基于TIM1的比较输出
ST老少女 发布时间:2008-12-2 14:32
以下为源代码,CC1进行比较输出,模式为翻转电平.7 M7 n0 }, g9 `$ e- \0 A
# F7 {) t# f% C: H9 m" G
程序运行后,CC中断可以进去,PA.11的指示灯能闪,但PA.08的指示一直为低电平,请教一下程序哪里错了???
8 \& }% Z( ]& t2 I* b% m  n; Z+ C; W4 U9 X1 J9 B( b, ^1 Y& q
void TIM1_CC_Init(void). _" S+ r5 M5 [( ~9 M: u
{     , |8 ]% i0 A2 a) A
NVIC_InitTypeDef NVIC_InitStructure;  & D) O) T% B1 a" R+ T! P) d
GPIO_InitTypeDef GPIO_InitStructure;  ) K1 j5 `- ^* U
/ f7 L5 b( @+ A7 {" s1 w3 E
/* 使能定时器 TIM1_CC 中断 */. o! H( o5 ]8 n  k$ k4 u* p
NVIC_InitStructure.NVIC_IRQChannel = TIM1_CC_IRQChannel;( m2 d9 u  P& l, K' j5 R0 f
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;8 `2 M# y  u/ {$ N
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;
* q1 @; k3 {6 x( @5 Q2 C4 tNVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
8 L" w0 \# [9 qNVIC_Init(&NVIC_InitStructure);
! N6 [2 h4 h( g& w' c: l* A3 |; |& o
/* 配置 PA.11 为推挽输出 */; j  r1 y6 @. ^& ^  j: X
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11;
6 ^3 S* [2 d; ~4 z8 cGPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
; c1 p8 i. F! J/ `GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
: f2 r$ ]/ G% `GPIO_Init(GPIOA, &GPIO_InitStructure);
* Z/ u- ^( M8 S         6 ]0 l- C& E7 p0 f
GPIOA->BSRR = GPIO_Pin_11; // 将PA.08配置为高电平
0 {0 ~) e4 O! V8 \( {2 q' \- Y$ x% U6 t; p* l, r  A! _0 w
/* 配置 PA.08 为复用推挽输出 */
* \) a5 Y! D0 I# ]GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8;
% \3 e+ r- _: ~2 \* b; f: Q* X- ^( S8 \GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
0 r7 w' o9 g4 S, c9 i3 p1 ~" mGPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
* i  C. M3 ^1 D) O7 E4 A8 R) w' \GPIO_Init(GPIOA, &GPIO_InitStructure);
  m$ z4 \& Z9 n8 R& O  C, C5 p
8 h9 J+ q' O( @. p& ^9 R/* 预分频自动重载寄存器 */
/ w! M- t" {1 x& P2 VTIM1->ARR   = 0x2FFF;   : N) t+ U6 e; F4 w4 K: L* K( l4 c
/* PSC 预分频器:计数频率 = CK_PSC /(PSC + 1) */$ H9 n0 Q# V' \( K/ f
TIM1->PSC   = 0xFF;
! d9 h# Z0 I9 M9 }6 r$ P/* CCR1 捕获比较值寄存器 */
3 P$ F6 W$ |+ U+ j; nTIM1->CCR1  = 0xFFF;
- r* L3 J& G7 B: E/* 循环计数器的寄存器(控制更新事件) */
+ g& ^$ f& ?) @& M) V9 D7 D  RTIM1->RCR   = 0x00;   // 每次更新   % |" [7 ~0 f1 `& Z. \
/* 捕获/比较模式寄存器 */
9 p5 E# x! S7 `) x; d8 W. A* a0 MTIM1->CCMR1 = 0x30;   // CC1为输出,CCR1立即生效,输出翻转.    2 i  R. e% F% w, b, l% P+ }. b1 ?
/* 捕获/比较使能寄存器 */
7 |2 I+ i4 d# i5 \# NTIM1->CCER  = 0x03;   // 开启CC1输出,反向输出 ; v1 {9 O/ Z/ M1 C, B
/* 中断使能寄存器 */6 y! _5 ~7 N3 v7 F: F
TIM1->DIER  = 0x02;   // 使能 CC1 中断
: _$ n4 @5 o% ~* ^& U7 V/* 控制寄存器1 */% q. F6 y) o4 Q* o, ~/ t7 O' r3 w" i
TIM1->CR1   = 0x01;   // 使能计数器(向上计数)
' p! h: x# C; Y* n& z, f: J& j}
4 c2 g- b: m8 C/ Z; G& H; ^& ^   + |( U: A2 X( t+ r- C3 C
* C2 P  n2 r2 ?: \** 函数名称: TIM1_CC_IRQHandler1 f2 @# W" y; X9 `( U: ~( K  R0 N8 h
** 功能描述: CC 中断
: I* Z1 v0 q6 q: R# }** 参    数: None9 G) j; Y, r% h8 t. X# ]4 j
** 返 回 值: None       3 I/ Y( N2 t; a8 U3 E8 q& P
****************************************************************************************/8 l3 W5 W- X) A( @7 ]' ]" d; e1 W+ W
void TIM1_CC_IRQHandler(void)
, w" m; {+ |) e8 Z{
) G0 e5 O# w& G: M4 q/ r( Y- M; Dstatic uint32 counter = 0;
( V- ~- e- A5 `1 P6 o% A
  O4 E1 N! J+ h/ m7 WTIM1->SR &= ~2; // 清除中断标志(不做判断提高效率)
  o( I" @: z# G0 q  K! P
* W( F0 Y1 {0 I- s% pif(counter)
' Y4 B- s" H3 t1 I! n{
- K% ?9 w3 D  _* ~/ X: B6 B  counter = 0; / }( ^' \8 Q# h4 `# p
  GPIOA->BSRR = GPIO_Pin_11;$ e4 ?. ?3 N2 l2 i
: a  ^- Q+ C6 g6 aelse+ k) v; p& P6 e9 J: s9 ?5 n
{  & n5 s1 L. P" w2 k! W6 r5 R1 W
  counter = 1;$ y, z8 v  U/ G0 v2 n+ a
  GPIOA->BRR = GPIO_Pin_11;
: c5 m, A" ?. @2 B0 \# r}
$ M9 z1 r3 l" e+ O# D7 @: Q  F: X}
赞 收藏 评论3 发布时间:2008-12-2 14:32
3个回答
得蜜 回答时间:2008-12-2 14:33:45
RE:STM32基于TIM1的比较输出
  u, ]; Q0 n& P4 g4 [  \找到问题,没有打开主输出...% j1 |" F! ^5 H% E* V! @$ q2 h
/* 打断和死区控制器 */
0 u( _7 `$ h  a2 K9 }8 ?5 gTIM1->BDTR  = 0x8000;                // 主输出使能(MOE)        ) n2 }) ~5 x9 l/ Z; Q6 T' L
加这句就可以了.
ST老少女 回答时间:2008-12-2 14:34:52
RE:STM32基于TIM1的比较输出
谢谢
can-39743 回答时间:2012-3-30 12:34:27
RE:STM32基于TIM1的比较输出
你好,楼主,
' v  p- x) _) }3 a: E# d我刚接触到STM32F103这款芯片,同时也要使用TIM1高级时钟这个模块,主要是用来控制电机,但发现互初输出的PWM信号的占空比不正确,譬如:软件中设置的占人比为20%,但实际输出才有16%,其它的占空比都是一样,存在误差!
, ], m/ B2 S$ {+ h) p; `ps:我的PWM信号频率为20KHZ,死区时间:2us,中心对齐,下溢中断; `1 F% |4 J  ^
谢谢
