ST I2C 的例子怎么不能用啊  关闭
guanjianguo 提问时间:2008-12-17 21:48 /
  I2C_GenerateSTART(I2C1, ENABLE);
  /* Test on I2C1 EV5 and clear it */
  while(!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_MODE_SELECT));
 大多数时候死在循环那里啦,
Example2.rar
314.23 KB, 下载次数: 25, 下载积分: ST金币 -1
赞 收藏 评论4 发布时间:2008-12-17 21:48
4个回答
得蜜 回答时间:2008-12-18 09:59:11
RE:ST I2C 的例子怎么不能用啊
附件里面是什么?
私奔 回答时间:2008-12-18 11:39:23
RE:ST I2C 的例子怎么不能用啊
void I2C_RTC_ByteWrite(u8 pBuffer, u16 WriteAddr)
  u8 aH,bL;
  /* Send START condition */
  /* Test on EV5 and clear it */
  /* Send RTC address for write */
  I2C_Send7bitAddress(I2C1, RTC_ADDRESS, I2C_Direction_Transmitter);
  /* Test on EV6 and clear it */
   while(!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_TRANSMITTER_MODE_SELECTED));
  bL = WriteAddr & 0x00ff;   //高8位地址
  aH = WriteAddr >> 8;                 //低8位地址
  /* Send the RTC's 高8位地址 */
  I2C_SendData(I2C1, aH);
  /* Test on EV8 and clear it */
  while(! I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_BYTE_TRANSMITTED));
  /* Send the RTC's 低8位地址 */
  I2C_SendData(I2C1, bL);
  /* Send the current byte */
  I2C_SendData(I2C1, pBuffer);
  while (!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_BYTE_TRANSMITTED));
  /* Send STOP condition */
  I2C_GenerateSTOP(I2C1, ENABLE);
牛人说这样是好的。说你是否从机没有返回。
我代为转述下。
萧星-96138 回答时间:2008-12-18 11:44:11
可以做如下修改,把I2C_EE_WaitEepromStandbyState放在前面...
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
#define I2C_PageSize           16
/* Private function prototypes -----------------------------------------------*/
static void I2C_EE_WaitEepromStandbyState(CPU_INT08U ucAddr);
/* Private functions ---------------------------------------------------------*/
* Function Name  : I2C_EE_WaitEepromStandbyState
* Description    : Wait for EEPROM Standby state
* Input          : None
* Output         : None
* Return         : None
  vu16 SR1_Tmp = 0;
  do
    /* Read I2C1 SR1 register */
    SR1_Tmp = I2C_ReadRegister(I2C1, I2C_Register_SR1);
    /* Send EEPROM address for write */
    I2C_Send7bitAddress(I2C1, ucAddr, I2C_Direction_Transmitter);
  }while(!(I2C_ReadRegister(I2C1, I2C_Register_SR1) & I2C_FLAG_ADDR));
  /* Clear AF flag */
  I2C_ClearFlag(I2C1, I2C_FLAG_AF);
* Function Name  : I2C_EE_BufferWrite
* Description    : Writes buffer of data to the I2C EEPROM.
* Input          : - pBuffer : pointer to the buffer  containing the data to be
*                    written to the EEPROM.
*                  - WriteAddr : EEPROM's internal address to write to.
*                  - NumByteToWrite : number of bytes to write to the EEPROM.
* Output         : None
* Return         : None
void I2C_EE_BufferWrite(CPU_INT08U ucDeviceAddr,CPU_INT16U WriteAddr, CPU_INT08U* pBuffer, u16 NumByteToWrite)
  CPU_INT08U NumOfPage = 0, NumOfSingle = 0, Addr = 0, count = 0;
  Addr = WriteAddr % I2C_PageSize;
  count = I2C_PageSize - Addr;
  NumOfPage =  NumByteToWrite / I2C_PageSize;
  NumOfSingle = NumByteToWrite % I2C_PageSize;
  /* If WriteAddr is I2C_PageSize aligned  */
  if(Addr == 0)
    /* If NumByteToWrite < I2C_PageSize */
    if(NumOfPage == 0)
      I2C_EE_PageWrite(ucDeviceAddr,WriteAddr,pBuffer,  NumOfSingle);
    /* If NumByteToWrite > I2C_PageSize */
    else
      while(NumOfPage--)
        I2C_EE_PageWrite(ucDeviceAddr,WriteAddr, pBuffer, I2C_PageSize);
        I2C_EE_WaitEepromStandbyState(ucDeviceAddr);
        WriteAddr +=  I2C_PageSize;
        pBuffer += I2C_PageSize;
      if(NumOfSingle!=0)
  /* If WriteAddr is not I2C_PageSize aligned  */
  else
    if(NumOfPage== 0)
      I2C_EE_PageWrite(ucDeviceAddr,WriteAddr, pBuffer, NumOfSingle);
    else
      NumByteToWrite -= count;
      if(count != 0)
        I2C_EE_PageWrite(ucDeviceAddr, WriteAddr,pBuffer, count);
        WriteAddr += count;
        pBuffer += count;
      while(NumOfPage--)
        I2C_EE_PageWrite(ucDeviceAddr, WriteAddr, pBuffer,I2C_PageSize);
      if(NumOfSingle != 0)
* Function Name  : I2C_EE_ByteWrite
* Description    : Writes one byte to the I2C EEPROM.
* Output         : None
* Return         : None
void I2C_EE_ByteWrite(CPU_INT08U ucDeviceAddr,CPU_INT16U WriteAddr,CPU_INT08U* pBuffer)
  /* Send STRAT condition */
  I2C_Send7bitAddress(I2C1, ucDeviceAddr, I2C_Direction_Transmitter);
  /* Send the EEPROM's internal address to write to */
  I2C_SendData(I2C1, (WriteAddr&0xff00)>>8);
  I2C_SendData(I2C1, WriteAddr&0xff );
  /* Send the byte to be written */
  I2C_SendData(I2C1, *pBuffer);
  while(!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_BYTE_TRANSMITTED));
* Function Name  : I2C_EE_PageWrite
* Description    : Writes more than one byte to the EEPROM with a single WRITE
*                  cycle. The number of byte can't exceed the EEPROM page size.
* Output         : None
* Return         : None
void I2C_EE_PageWrite(CPU_INT08U ucDeviceAddr,CPU_INT16U WriteAddr, CPU_INT08U* pBuffer, CPU_INT08U NumByteToWrite)
  /* While there is data to be written */
  while(NumByteToWrite--)
    /* Point to the next byte to be written */
    pBuffer++;
* Function Name  : I2C_EE_BufferRead
* Description    : Reads a block of data from the EEPROM.
* Input          : - pBuffer : pointer to the buffer that receives the data read
*                    from the EEPROM.
*                  - ReadAddr : EEPROM's internal address to read from.
*                  - NumByteToRead : number of bytes to read from the EEPROM.
* Output         : None
* Return         : None
void I2C_EE_BufferRead(CPU_INT08U ucDeviceAddr,CPU_INT16U ReadAddr,CPU_INT08U* pBuffer,  u16 NumByteToRead)
  /* In the case of a single data transfer disable ACK before reading the data */
  if(NumByteToRead==1)
    I2C_AcknowledgeConfig(I2C1, DISABLE);
  /* Clear EV6 by setting again the PE bit */
  I2C_Cmd(I2C1, ENABLE);
  I2C_SendData(I2C1, (ReadAddr&0xff00)>>8);
  I2C_SendData(I2C1, (ReadAddr&0xff));
  /* Send STRAT condition a second time */
  /* Send EEPROM address for read */
  I2C_Send7bitAddress(I2C1, ucDeviceAddr, I2C_Direction_Receiver);
  while(!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_RECEIVER_MODE_SELECTED));
  /* While there is data to be read */
  while(NumByteToRead)
    /* Test on EV7 and clear it */
    if(I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_BYTE_RECEIVED))
      if(NumByteToRead == 2)
        /* Disable Acknowledgement */
      if(NumByteToRead == 1)
        /* Send STOP Condition */
      /* Read a byte from the EEPROM */
      *pBuffer = I2C_ReceiveData(I2C1);
      /* Point to the next location where the byte read will be saved */
      pBuffer++;
      /* Decrement the read bytes counter */
      NumByteToRead--;
  /* Enable Acknowledgement to be ready for another reception */
  I2C_AcknowledgeConfig(I2C1, ENABLE);
火雷达 回答时间:2011-11-19 14:14:09
回复:ST I2C 的例子怎么不能用啊
硬件的I2C好像是有点问题的,最好用软件模拟I2C
