这个是STM32的PWM输出模式,STM32的TIM1模块是增强型的定时器模块,天生就是为电机控制而生,可以产生3组6路PWM,同时每组2路PWM为互补,并可以带有死区,可以用来驱动H桥。: B$ C- k% Z% ? 下面的代码,是利用TIM1模块的1、2通道产生一共4路PWM的代码例子,类似代码也可以参考ST的固件库中相应example% p% z( {4 ~* b6 I! V C语言: TIM1模块产生PWM,带死区 //Step1.开启TIM和相应端口时钟 //启动GPIO RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOB | \; R$ I r$ k& q$ _4 F RCC_APB2Periph_GPIOC | RCC_APB2Periph_GPIOD,\ ENABLE); //启动AFIO( R5 Q2 B9 ]9 R% V6 S* B6 H' f0 C RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO, ENABLE);$ n. n" s7 g4 b" d; j: |" q //启动TIM1 RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1, ENABLE); //Step2. GPIO做相应设置,为AF输出 //PA.8/9口设置为TIM1的OC1输出口 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8 | GPIO_Pin_9;- R7 A' h. o6 L; C GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;9 H; |) \; H" D" |1 u ] GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;& H0 [/ I0 \! L. U: R# u; v. S GPIO_Init(GPIOA, &GPIO_InitStructure);" B" {0 V9 g) D! f5 ^6 s E' u . L0 u+ s* ]. W S/ A1 R- I //PB.13/14口设置为TIM1_CH1N和TIM1_CH2N输出口6 I+ ^5 j r4 O) {! N" R$ O GPIO_InitStructure.GPIO_Pin = GPIO_Pin_13 | GPIO_Pin_14; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;2 N0 t9 ]: |7 i( }+ r& w GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_Init(GPIOB, &GPIO_InitStructure);2 }8 m$ v# C; l2 ~- d //Step3. TIM模块初始化9 S& B% R. k1 b* E void TIM_Configuration(void) { TIM_TimeBaseInitTypeDef TIM_BaseInitStructure; TIM_OCInitTypeDef TIM_OCInitStructure; TIM_BDTRInitTypeDef TIM_BDTRInitStructure;1 o) \( u I; _" c) R //TIM1基本计数器设置(设置PWM频率)# H3 m. O. k" m% Y- G5 D! G3 O6 u0 P //频率=TIM1_CLK/(ARR+1)/ f* k( r: V x& | |, `: m TIM_BaseInitStructure.TIM_Period = 1000-1;1 N1 m$ R0 f0 p/ C" v TIM_BaseInitStructure.TIM_Prescaler = 72-1;: x2 ?5 U h7 j( K) t TIM_BaseInitStructure.TIM_ClockDivision = 0;. O: D* l* e* K1 U+ U+ r4 T/ Q TIM_BaseInitStructure.TIM_CounterMode = TIM_CounterMode_Up; TIM_BaseInitStructure.TIM_RepetitionCounter = 0; TIM_TimeBaseInit(TIM1, &TIM_BaseInitStructure);: w1 M7 x/ ^* x4 }0 x //启用ARR的影子寄存器(直到产生更新事件才更改设置)5 I* p, I; e+ {( [2 g9 \. r TIM_ARRPreloadConfig(TIM1, ENABLE); 3 k( p- @7 C5 t. u7 y2 ^, z+ s , x2 V: a/ A; l: k% { //TIM1_OC1模块设置(设置1通道占空比). C( n( g; C" {3 c A; w' ` TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1; TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable; TIM_OCInitStructure.TIM_OutputNState = TIM_OutputNState_Enable;- N' L5 J/ Y: {& R TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High; TIM_OCInitStructure.TIM_OCNPolarity = TIM_OCNPolarity_High;8 @7 v# o9 f) d9 o3 m TIM_OCInitStructure.TIM_Pulse = 120; TIM_OC1Init(TIM1, &TIM_OCInitStructure); //启用CCR1寄存器的影子寄存器(直到产生更新事件才更改设置) TIM_OC1PreloadConfig(TIM1, TIM_OCPreload_Enable); //TIM2_OC2模块设置(设置2通道占空比)7 S& u: C2 c: `; H TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;4 _# W+ C# s* ]# B# H. x TIM_OCInitStructure.TIM_OutputNState = TIM_OutputNState_Enable;$ _6 W' i |5 \ TIM_OCInitStructure.TIM_Pulse = 680;; S8 S" d* }: \$ k# d5 U TIM_OC2Init(TIM1, &TIM_OCInitStructure); //启用CCR2寄存器的影子寄存器(直到产生更新事件才更改设置) TIM_OC2PreloadConfig(TIM1, TIM_OCPreload_Enable); //死区设置" M( ^/ u8 ^7 m1 y) Z TIM_BDTRInitStructure.TIM_OSSRState = TIM_OSSRState_Enable;' f. R! K& I# ` TIM_BDTRInitStructure.TIM_OSSIState = TIM_OSSIState_Enable; TIM_BDTRInitStructure.TIM_LOCKLevel = TIM_LOCKLevel_OFF; TIM_BDTRInitStructure.TIM_DeadTime = 0x90; //这里调整死区大小0-0xff) K5 s9 a) i4 q0 C$ Q TIM_BDTRInitStructure.TIM_Break = TIM_Break_Disable;- M7 Y, L7 s: `( X TIM_BDTRInitStructure.TIM_BreakPolarity = TIM_BreakPolarity_High;4 w3 x: z8 _; Z6 X TIM_BDTRInitStructure.TIM_AutomaticOutput = TIM_AutomaticOutput_Enable;- H0 P! |/ W9 B. ^0 \ TIM_BDTRConfig(TIM1, &TIM_BDTRInitStructure); //TIM1开启/ s) b9 g6 d# Y TIM_Cmd(TIM1, ENABLE);0 b2 P4 N8 ]% d! x //TIM1_OC通道输出PWM(一定要加)8 M' Y& m1 X* |2 L+ C TIM_CtrlPWMOutputs(TIM1, ENABLE); }7 c- @! b2 z8 [6 [ - p3 p$ \4 R2 C: l) w) W3 g - d0 i8 W/ K; l. N3 y: F# ? 其实,PWM模块还可以有很多花样可以玩,比方在异常时(如CPU时钟有问题),可以紧急关闭输出,以免发生电路烧毁等严重事故。 |
RE:STM32笔记(二)TIM模块产生PWM
那 我 不早是 发明家了 。。。。
回复:STM32笔记(二)TIM模块产生PWM
