STM32笔记(四)DMA、USART的演示
私奔 发布时间:2009-1-4 14:30
赞 收藏 评论44 发布时间:2009-1-4 14:30
44个回答
birdcq 回答时间:2011-5-13 14:35:18
RE:STM32笔记(四)DMA、USART的演示
好东西 下来看看 l
cocoasuny 回答时间:2011-11-4 14:15:28
谢谢,第一次使用DMA!
yfwang555 回答时间:2011-12-11 11:25:59
回复:STM32笔记(四)DMA、USART的演示
hfgggggggggggggggggggggggggggggkjttttttttttttttttttttttttttttttttttttttttttttttty
piaopiao123 回答时间:2011-12-20 09:28:40
各位大虾,帮忙看看,我的DMA串口可以发送,但是不能接收,请问可能会是什么问题呢?谢谢!
3 C- {# h6 }, L; A, v: z#define TxBufferSize  16
/ O& s% I0 b$ X  _* y#define RxBufferSize  16, S3 M  h. ?' g( x4 m" I: S9 `
uint8_t TxBuffer[TxBufferSize] = {0x00,0x01,0x02,0x03,0x04,0x05,0x06,0x07,0x08,0x09,0x0A,0x0B,0x0C,0x0D,0x0E,0x0F};
) D( U- {1 q, B/ S% \9 ^uint8_t RxBuffer[RxBufferSize];
  u+ Y) t. e1 o0 O7 q  Qvoid DMA_Configuration(void)
; C9 J6 p) p9 A{5 J# p2 j0 [# e: {* j
DMA_InitTypeDef DMA_InitStructure;. V% k! Q- E. X
DMA_DeInit(DMA1_Channel7);  8 K+ x" S6 x1 \5 E! x  H& R
DMA_InitStructure.DMA_PeripheralBaseAddr = 0x40004404;
. U$ o/ x6 G9 w# r0 F+ l7 K, o DMA_InitStructure.DMA_MemoryBaseAddr = (uint32_t)TxBuffer;) ?  @) k1 a9 _+ P4 q8 O
DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralDST;# h, |) e5 C, V2 V1 [
DMA_InitStructure.DMA_BufferSize = TxBufferSize;, P3 j" @( @1 j9 k
DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;0 Y4 R( ?4 c9 w8 x- f9 ~
DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
) R. s( s+ L$ a: @ DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Byte;. q# E; C; _( Z2 {, K: r; b& e' T
DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_Byte;
; b; _+ E3 ]$ h+ L6 ]% q! t DMA_InitStructure.DMA_Mode = DMA_Mode_Normal;2 c3 v, I9 T' W
DMA_InitStructure.DMA_Priority = DMA_Priority_VeryHigh;- p. b5 X7 f9 F; L, b& g
DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
3 S; Y! k$ u+ a. H DMA_Init(DMA1_Channel7, &DMA_InitStructure);, N3 l  d5 Z( {& K1 v
DMA_DeInit(DMA1_Channel6);
7 T; @6 y. g% i5 I6 A2 P DMA_InitStructure.DMA_PeripheralBaseAddr = 0x40004404;9 H' m2 e$ g4 f  e. V. F* \
DMA_InitStructure.DMA_MemoryBaseAddr = (uint32_t)RxBuffer;" r+ S! @& e  j! q9 o; q  r" y
DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC;
' Z4 T4 H% J' [  q) l DMA_InitStructure.DMA_BufferSize = RxBufferSize;, S6 t" l, w' r
DMA_Init(DMA1_Channel6, &DMA_InitStructure);- m( x" \# ~9 s7 M' v9 v/ P: U' A
}& E7 X7 v% E( x% u; L7 c/ V
void USART_Configuration(void)
/ z9 x5 w* l& q; v8 E  P7 }" {: W" n{
" Y# ]0 x" q" y/ {. ]9 A* T: d  d7 G USART_InitTypeDef USART_InitStructure;
. i/ A( h# v4 p4 j. M+ e USART_DeInit(USART2);4 z* r& G9 M0 d* L: |$ N# X
USART_InitStructure.USART_BaudRate = 115200;! ]" D  D, V, x2 Q7 [
USART_InitStructure.USART_WordLength = USART_WordLength_8b;4 C  S- z2 p$ L4 u2 j) r2 I
% ]8 S+ G% D! l0 } USART_InitStructure.USART_Parity = USART_Parity_No ;
/ _" @9 c" p% h USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;- r, D3 a/ L' C' \( N3 N
USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;) I) Q6 C/ z5 y3 z! s# `, W
USART_Init(USART2,&USART_InitStructure);1 c% [9 K. K' {2 w8 @' z
}: s$ y+ V( v/ |) }
void GPIO_Board_Init(void); U' @( g$ n. G' f
{7 S. o: ^- O% n7 U+ k6 w) G* H# F$ b
  GPIO_InitTypeDef GPIO_InitStructure;. _, l1 I8 D  }
  /* DMA1 Periph clock enable */
4 N/ g- s7 C& C5 t  RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE);' s; z& O2 p8 X- u* w
  /* GPIO Periph clock enable */
/ k/ h: D9 x! S8 f  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOB | RCC_APB2Periph_GPIOC | RCC_APB2Periph_AFIO , ENABLE);
1 ~0 u# Y, Y# i) z  RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART2 , ENABLE);- e& R: k% n1 I4 f0 a
  /* Configure GPIOA  Out mode */* o; `& W0 Y7 n" s
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1 | GPIO_Pin_8 | GPIO_Pin_11 | GPIO_Pin_12;
- [1 i: i$ ~* E  D6 Y2 ]( A  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
3 ~: Y- x+ v$ a$ d  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;) ~3 L% s: w; x
8 ^4 Z$ V/ S" S# d, K  /* Configure GPIOB  Out mode */* Z3 M2 K+ _, I" V: \- J/ M
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_2 | GPIO_Pin_5 | GPIO_Pin_6;
: L- {) q  U+ C  ?6 |: Y: z  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
. g) D: T3 K4 L2 D  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;1 l# U4 L$ V# y1 ]% O, a1 K
  GPIO_Init(GPIOB, &GPIO_InitStructure);: |+ C! x8 W% O6 z/ H
  /* Configure GPIOC  Out mode */* q+ M6 I2 P9 e2 q  |: `& }2 ]. W
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_All;" F4 A% u) L8 }. e, l& ~+ Y, }
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;4 `: U3 |6 F) k" z
) Z. |, a; r' t) L0 ^  GPIO_Init(GPIOC, &GPIO_InitStructure);
: c0 @& V* L: E3 R" R3 M  /* Configure USART2 Rx as input floating */0 K: h% T. F; {7 V
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3;% \8 m' f, O9 g" K# @, }" s' P
$ }, e2 R7 D% x$ _  GPIO_Init(GPIOA, &GPIO_InitStructure);
9 c( K* P6 F! i6 ]+ X+ V  /* Configure USART2 Tx as alternate function push-pull */5 w  C. S3 l* S
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;+ Q8 `: {# U/ k. m
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;& n; N+ N4 `% e
; i. e+ N6 L  v- T+ @% W: C9 ~  GPIO_Init(GPIOA, &GPIO_InitStructure);
# I: K$ T- D% A' m" |- I}5 b, Q4 m4 {9 r% u- k! `
int main(void)7 @4 U' z8 x3 [2 p5 @! @
{9 T  U2 E, K1 |+ e: G  I/ q
while(1)
) {( U" T/ a$ Q) s- J{2 H: j& g" W# q" |- q8 A5 s. p, q+ e
if(DMA_GetFlagStatus(DMA1_FLAG_TC6) == SET)8 Y' q+ j6 O& F( r& j3 V* |
    {% `) c9 A# r& N
         DMA_ClearFlag(DMA1_FLAG_TC6);# K6 ^: U3 c- Z% S* g8 _; t1 v
     DMA_Cmd(DMA1_Channel6, DISABLE);
0 a$ P9 ]- z+ a' \) z! |$ i2 h! m# m2 D     DMA_SetCurrDataCounter(DMA1_Channel6,RxBufferSize);
8 a. D0 N$ @1 O* A* n         GPIO_SetBits(GPIOC,GPIO_Pin_8);
3 Y3 h$ L3 f& [. V     delay(500);
/ l+ V# o/ V* T; H9 A3 A     GPIO_ResetBits(GPIOC,GPIO_Pin_8 );6 ^; F$ L  ^* X( L
     delay(500);
5 C* p- p7 T6 U6 C   }9 s4 S4 `. {+ ~4 `. g1 y8 q$ a
else
! F$ G# K5 I1 i0 [: C+ A {
& A. D7 `2 L' kGPIO_SetBits(GPIOC,GPIO_Pin_9);
5 T3 i% E3 [* l0 @. Y) H/ b     delay(500);
. e! Q5 b- x* c5 ?4 X$ M, J5 G     GPIO_ResetBits(GPIOC,GPIO_Pin_9 );- |, F7 h1 j" ^$ X! j3 `% s+ H3 N
     delay(500);
6 x; T( _6 D) E' `! F}
2 t* H! G+ ?9 R}. K) i. i, t" v- k+ `
anyway76 回答时间:2011-12-23 11:09:42
正在接触STM32,多谢分享
njlhp123 回答时间:2011-12-23 18:35:09
回复第 3 楼 于2009-01-05 04:18:28发表:
原帖由私奔于2009-01-04 14:30发表:
* p1 J% q/ K1 U  这里有个小小的例子,来演示DMA模块与系统程序并行工作。
. k% G. i0 j7 |  用串口以低波特率发送一个10K的数据,花费近10s时间,此时按照以往方法,CPU要不断等待数据发送、送数据;或者送数据、进中断、送数据,处理起来比较消耗时间。
0 y) e+ L3 @$ n3 H  使用了DMA功能以后,用户程序中只需配置好DMA,开启传输后,再也不需要操心,10K数据完成后会有标志位或中断产生,期间可以做任何想做的事,非常方便。
# Q0 G: n$ `6 R7 c4 t5 v2 f4 r: y9 F. Z2 A  这个是相应的代码例子,基于STM32F103VBT6
' C1 U- `) Z2 _
" D( l: H/ @4 E( P- j, C1 M/ a
& g3 k) l4 G0 L/ p1 ~' i- P& w' [/******************************************************************************! @: \8 f# d& l2 F( A$ c
* 本文件实现串口发送功能(通过重构putchar函数,调用printf;或者USART_SendData()% S. f8 U) F" u: g
* 这里是一个用串口实现大量数据传输的例子,使用了DMA模块进行内存到USART的传输
1 y! b  b1 j/ _/ N3 B; x! p* 每当USART的发送缓冲区空时,USART模块产生一个DMA事件,
3 m0 H6 ~6 o" l0 ?1 X* 此时DMA模块响应该事件,自动从预先定义好的发送缓冲区中拿出下一个字节送给USART  v, o9 q0 w4 v4 T: p
* 整个过程无需用户程序干预,用户只需启动DMA传输传输即可
: d$ `' p$ T! r* 在仿真器调试时,可以在数据传输过程中暂停运行,此时DMA模块并没有停止' ~5 q) C) N$ I, G% T1 x
* 串口依然发送,表明DMA传输是一个独立的过程。* a% I& {3 T% ]
* 同时开启接收中断,在串口中断中将数据存入缓冲区,在main主循环中处理
; @% f+ j9 G2 p) V* 作者:jjldc(九九)& H, w  J2 |- |# i5 e  K/ S! U& g
* 代码硬件基于万利199元的EK-STM32F开发板,CPU=STM32F103VBT6; H2 ?* E+ D" @  M! v8 k1 M6 y
*******************************************************************************/% d5 m6 B& Y. d% |0 V8 Z; F5 b+ E
+ x! S4 S' a+ ]% ]/* Includes ------------------------------------------------------------------*/. G1 j/ A# V# h5 V: }
#include "stm32f10x_lib.h"
& w/ P& j. W, a: O#include "stdio.h"
% x0 T) O1 ]+ F6 S1 F# s8 E2 J! r: A) ~) h) c+ Z! \
/* Private typedef -----------------------------------------------------------*/
6 M3 `+ y3 f0 l2 C# Z+ ~/* Private define ------------------------------------------------------------*/! G8 l/ X; Z& M8 ~
#define USART1_DR_Base  0x40013804
1 p- T- `6 q6 c
# ]; d! x9 _  L8 u$ _+ M0 t( l/* Private macro -------------------------------------------------------------*/
1 o3 i$ ]! `# T! Y3 {7 V* x/* Private variables ---------------------------------------------------------*/! Y8 w% J  ^# U# D4 I  b6 F
#define SENDBUFF_SIZE   102409 s, B2 [& s. H* x/ l' J0 q
vu8 SendBuff[SENDBUFF_SIZE];
; |6 w' y1 L4 E3 k, |) `vu8 RecvBuff[10];
3 o- v. y  o+ l' ^vu8 recv_ptr;
9 u  f4 o$ B0 U! V/ D& t' L5 o( X! |# Y9 Y
/* Private function prototypes -----------------------------------------------*/5 v0 b. l7 z0 W0 R( b! S5 Y% C) Q
void RCC_Configuration(void);/ n& V8 `+ Y- a" a8 ]- r+ l7 i2 `2 j+ N- }
void GPIO_Configuration(void);9 T5 v$ Q! j3 c
void NVIC_Configuration(void);
# f/ ?  ^7 @- _0 w# J  wvoid DMA_Configuration(void);& @) @/ h9 o/ F% {" G; x
void USART1_Configuration(void);/ D$ U! Q. V6 k, h+ @" S& R2 {7 p
% D8 A6 g: t$ f1 d
int fputc(int ch, FILE *f);3 [8 s0 x' B. b8 C6 i8 u
void Delay(void);7 l+ X/ W7 Y; k
; J7 L  m; [. Z( z$ ^
/* Private functions ---------------------------------------------------------*/. c% J) p' s1 t; g
' x- I. o0 K# A1 ?* t: c0 _3 u* Function Name  : main
5 N5 j% X; R' W" ]  {) y" ~9 n* Description    : Main program.
, X& m! B4 X4 _) S. @- _8 k* Input          : None
& g! U3 u  L8 c" `8 _' o; S* Output         : None8 o. H$ m' ~. U- T
* Return         : None
5 y7 D0 @: X4 b*******************************************************************************/
: E! t' F: N; g9 ~- qint main(void)
3 x) m! C% C0 @( b& J% [5 B0 \{- a8 G3 I) l3 W8 O
    u16 i;5 |4 y2 T+ p9 r* G
#ifdef DEBUG
0 U" Y- _% S" A# t    debug();
; y: ]. S( s0 {5 m3 A* F4 N, e#endif
8 q7 t2 N! U# E+ w+ A    recv_ptr = 0;
- y0 D+ p- i7 s6 b0 ?8 [; l
8 ?" V$ J* U4 l    RCC_Configuration();
7 r7 V; h6 U3 j    GPIO_Configuration();- G, I4 p, I8 x* x8 c4 j- V) r, I
    NVIC_Configuration();
0 ^( c: A7 m0 @( V& V0 F    DMA_Configuration();
& u% ~9 o3 s' o: T0 y6 J    USART1_Configuration();7 c/ ^( R( J; ~$ Z/ ~* v4 p
    / }7 t* q9 A0 z$ V
    printf("\r\nSystem Start...\r\n");2 ], c: o3 [( h& a8 _
    printf("Initialling SendBuff... \r\n");
5 o" |7 ~9 _5 V9 W9 ^9 z    for(i=0;i    {# L. p! z  M# j. `# x; K
        SendBuff = i&0xff;3 Y$ u) T- C7 C
    }+ u( y1 I/ u8 D. Z' n
    printf("Initial success!\r\nWaiting for transmission...\r\n");
5 ~# s, z1 o% {- f' l* a+ j    //发送去数据已经准备好,按下按键即开始传输
8 ]) r3 _+ z. P5 `/ |4 Z. A    while(GPIO_ReadInputDataBit(GPIOD, GPIO_Pin_3));
$ r* t5 Z% w" k$ z" |. F% _$ q( r    $ m2 o8 X9 h0 O3 v  k4 d  X1 j
    printf("Start DMA transmission!\r\n");
4 @$ n9 k5 R0 l! O    : {3 ]4 K2 H% z8 @) |
    //这里是开始DMA传输前的一些准备工作,将USART1模块设置成DMA方式工作
0 T+ F6 a0 Y' t$ N+ ^1 I    USART_DMACmd(USART1, USART_DMAReq_Tx, ENABLE);" A. {4 J  J& f1 a5 L
    //开始一次DMA传输!0 P! ^) C$ g: O. c
    DMA_Cmd(DMA1_Channel4, ENABLE);
7 r8 I$ q1 t8 }' H1 S6 H+ l    5 M- \8 F3 t8 K' V) T4 o
    //等待DMA传输完成,此时我们来做另外一些事,点灯$ ~( s) e. Q6 R4 [0 f& i
    //实际应用中,传输数据期间,可以执行另外的任务
: |' w1 h# E7 E  Q    while(DMA_GetFlagStatus(DMA1_FLAG_TC4) == RESET)
( _5 D/ _+ Y. U9 O1 g1 a& q    {2 _" u/ D) u! E$ Q% i$ d
        LED_1_REV;      //LED翻转9 F( O8 J  e2 Q) ~8 Y( W
        Delay();        //浪费时间
9 z3 a/ Y- N9 `- h: [2 \    }
5 ^  C/ ^1 z  Y( @+ {3 Y    //DMA传输结束后,自动关闭了DMA通道,而无需手动关闭
! f# r: R- _2 f2 p$ _, G/ k# `7 G    //下面的语句被注释
; z6 k4 `1 L# ^1 U3 X( h5 O2 x# U( J    //DMA_Cmd(DMA1_Channel4, DISABLE);
5 V* \( C+ ~7 o! N" F" O8 X' H    ! @/ ]8 a& T3 P7 C" C( G* A
    printf("\r\nDMA transmission successful!\r\n");
& S/ u9 F* g; }- x0 `! e9 J/ p; c2 e" j/ G, t
9 h8 z5 ^4 x* X3 Z    /* Infinite loop */
% x( g# f1 {9 h# _; f  A  U! j) \    while (1)
7 A/ s+ D2 [4 y0 l$ u/ m$ z' ]    {1 @: O; q( s3 H% ]0 v$ k
; t! {# Y! O9 s% |0 |! M* A}
# _/ [* r( q4 m0 M6 K6 ?7 r
3 H$ d( ~/ }( c5 v2 H$ |/*******************************************************************************
/ M5 j9 A4 k( X$ s# \& o3 A9 [( Q* Function Name  : 重定义系统putchar函数int fputc(int ch, FILE *f)
' A0 Y$ n  H  V! H* Description    : 串口发一个字节
3 Z9 v$ r1 G+ J. V( f5 I6 x* Input          : int ch, FILE *f
& t0 P% Z  w; z- G2 p. {2 N* Output         :
& V5 O5 o* h! N& Q% f3 J* O0 X! |* Return         : int ch
) p9 m' `! o/ T; H* 这个是使用printf的关键8 i$ C  \+ |- ^! P
*******************************************************************************/" v' m" ~8 j) V9 }( h0 M
+ W$ p- }- G2 q9 `{# g2 R% Y. s0 a+ I$ A# l
    //USART_SendData(USART1, (u8) ch);
0 L6 o: M- W5 j$ S9 H0 V' q    USART1->DR = (u8) ch;
0 r$ Q; s$ O' X% Z      p6 A2 ^1 |# K
    /* Loop until the end of transmission */' e4 p/ x, h% w! b& ~7 Q9 `( M
    while(USART_GetFlagStatus(USART1, USART_FLAG_TXE) == RESET)
) |* T6 N; e, n! V4 E+ {    {( N; z7 `+ Q, T; ^
    }6 d2 F6 r: ~4 x4 o  q
9 {6 K- y' v8 @9 b) k8 H0 p$ a4 s    return ch;
% b2 H* l4 m7 i. T" A: ~& h; Q}5 U4 r% i8 Z& }# f# M1 m
; m  ^* o& r. R% @  D* p: T& o7 |
/*******************************************************************************) M3 X9 Y3 P0 L1 t( f; N) ^
* Function Name  : Delay
9 U' y) Z3 c" K/ x  c% |* Description    : 延时函数
% ]  g( @, v& X* a8 x# J* Input          : None7 ?) d( [( O3 B( v( h  r2 B. Z
* Output         : None1 }# A" h0 t$ a3 H( z' H3 g
* Return         : None
1 `# J! k& _8 G& `/ L" ^' ?*******************************************************************************/! U9 X% g* y: ^2 v, W$ u
void Delay(void)
& D; m- Y9 c1 p; i/ y) A% S{0 r8 w% k4 c5 z$ ^# \! `
    u32 i;
2 \# }5 H' ]+ t/ s6 A! }9 s% b    for(i=0;i外设/ v  L9 |; J: ?3 K' Y
    //每次传输位:8bit9 u9 W  e% [1 m1 N+ \5 s6 _; E
    //传输大小DMA_BufferSize=SENDBUFF_SIZE
5 g- i1 K( Y( M* U+ C* {1 V% k    //地址自增模式:外设地址不增,内存地址自增1
1 q/ C7 ], W: J& ?  f    //DMA模式:一次传输,非循环2 ]& Y7 C1 B/ C' S! D* n5 k% g
    //优先级:中- U& _8 r9 w/ G5 F
    DMA_DeInit(DMA1_Channel4);
7 O; z2 H: c+ \    DMA_InitStructure.DMA_PeripheralBaseAddr = USART1_DR_Base;! k% N# R& x* t5 m" C9 K
    DMA_InitStructure.DMA_MemoryBaseAddr = (u32)SendBuff;0 j# M, n; }$ T' ?6 T
    DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralDST;  m3 N- |( @9 T; z% p" k* h. [
    DMA_InitStructure.DMA_BufferSize = SENDBUFF_SIZE;
  [) K- I4 g  U* v3 |8 ~    DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
2 }& L' Q% B7 R  l- l( x    DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
" v8 C- d% B; u. S$ g( P( {    DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Byte;! A3 a& X* N4 ]1 Q) P& Z
    DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_Byte;+ c8 B2 w# }+ S; G/ \$ ~3 m
    DMA_InitStructure.DMA_Mode = DMA_Mode_Normal;+ _/ \& i1 F/ K- T! L+ @
    DMA_InitStructure.DMA_Priority = DMA_Priority_Medium;
" A4 k1 d7 P6 r) Z% B+ H* W( v% o! Z    DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
, i" l! B+ u* G5 r) ?    DMA_Init(DMA1_Channel4, &DMA_InitStructure);2 B) K* ?) t- D& U% @5 C
/ B6 s$ A. p; l6 Q! i8 C3 @+ A# _谢谢分享
zhixiangyuhui 回答时间:2012-3-6 22:34:06
棒~
lxllf520-225827 回答时间:2012-3-16 20:56:10
在哪里下载??
你好-364167 回答时间:2012-8-16 19:55:58
不错呀 就是要学 这个程序呀
longzhaocy 回答时间:2012-12-19 16:45:33
不错,正需要,谢谢共享。。
jensenhero 回答时间:2012-12-24 15:50:32
不知道为什么,编译没有通过,貌似还得修改
jensenhero 回答时间:2012-12-24 15:50:35
suhetao-306309 回答时间:2013-4-9 21:10:54
学习了。感谢楼主的无私奉献
liaodata 回答时间:2013-9-9 19:36:31
 我需要参考之 写在f4上~~
Rodriguez 回答时间:2013-9-16 16:26:24
好同志啊,有没有F0的对应例程啊
123
