stm32L系列如何配置SPI?【悬赏问答】
indream123 提问时间:2012-8-9 13:50 /
如题,最近在调试stm32L系列单片机的SPI,对于配置有点头大,如何配置spi的端口状态?我尝试了好多,好像都不工作!
在此向各位求助,如何配置SPI的状态?
赞 收藏 评论3 发布时间:2012-8-9 13:50
3个回答
yjwpm 回答时间:2012-8-9 13:53:39
RE:stm32L系列如何配置SPI?
看来楼主没有仔细的看官方提供文档呀.看看官方的配置....
  * @file    SPI/SPI_TwoBoards/DataExchangeDMA/main.c
  * @author  MCD Application Team
  * @version V1.1.1
  * @date    13-April-2012
  * @brief   Main program body
  * @attention
  * © COPYRIGHT 2012 STMicroelectronics
  * Licensed under MCD-ST Liberty SW License Agreement V2, (the "License");
  * You may not use this file except in compliance with the License.
  * You may obtain a copy of the License at:
  *        http://www.st.com/software_license_agreement_liberty_v2
  * Unless required by applicable law or agreed to in writing, software
  * distributed under the License is distributed on an "AS IS" BASIS,
  * WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
  * See the License for the specific language governing permissions and
  * limitations under the License.
/* Includes ------------------------------------------------------------------*/
#include "main.h"
/** @addtogroup STM32L1xx_StdPeriph_Examples
/** @addtogroup SPI_DataExchangeDMA
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
SPI_InitTypeDef  SPI_InitStructure;
DMA_InitTypeDef  DMA_InitStructure;
TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
TIM_OCInitTypeDef  TIM_OCInitStructure;
uint8_t TxBuffer[] = "SPI DMA Example: Communication between two SPI using DMA";
uint8_t RxBuffer [RXBUFFERSIZE];
__IO JOYState_TypeDef PressedButton  = JOY_NONE;
__IO uint32_t CommandTransmitted = 0x00;
__IO uint32_t CommandReceived = 0x00;
__IO uint16_t NumberOfByte = 0x00;
__IO uint16_t PrescalerValue = 0;
__IO uint32_t TimeOut = 0x0;
/* Private function prototypes -----------------------------------------------*/
static void SPI_Config(void);
static void SysTickConfig(void);
static void TimeOut_UserCallback(void);
static TestStatus Buffercmp(uint8_t* pBuffer1, uint8_t* pBuffer2, uint16_t BufferLength);
#ifdef SPI_MASTER
static void TIM_Config(void);
static JOYState_TypeDef Read_Joystick(void);
static void Fill_Buffer(uint8_t *pBuffer, uint16_t BufferLength);
#endif
/* Private functions ---------------------------------------------------------*/
  * @param  None
  * @retval None
int main(void)
  /*!< At this stage the microcontroller clock setting is already configured,
       this is done through SystemInit() function which is called from startup
       file (startup_stm32l1xx_xx.s) before to branch to application main.
       To reconfigure the default setting of SystemInit() function, refer to
       system_stm32l1xx.c file
  /* SPI configuration ------------------------------------------------------*/
  SPI_Config();
  /* SysTick configuration ---------------------------------------------------*/
  SysTickConfig();
  /* Initialize LEDs mounted on STM32L152-EVAL board */
  STM_EVAL_LEDInit(LED1);
  STM_EVAL_LEDInit(LED2);
  STM_EVAL_LEDInit(LED3);
  STM_EVAL_LEDInit(LED4);
  /* Master board configuration ------------------------------------------------*/
#ifdef SPI_MASTER
  /* Initialize push-buttons mounted on STM32L152-EVAL board */
  STM_EVAL_PBInit(BUTTON_RIGHT, BUTTON_MODE_GPIO);
  STM_EVAL_PBInit(BUTTON_LEFT, BUTTON_MODE_GPIO);
  STM_EVAL_PBInit(BUTTON_UP, BUTTON_MODE_GPIO);
  STM_EVAL_PBInit(BUTTON_DOWN, BUTTON_MODE_GPIO);
  STM_EVAL_PBInit(BUTTON_SEL, BUTTON_MODE_GPIO);
  /* Initializes the SPI communication */
  SPI_InitStructure.SPI_Mode = SPI_Mode_Master;
  SPI_Init(SPIx, &SPI_InitStructure);
  /* TIM configuration ------------------------------------------------------*/
  TIM_Config();
  /* Enable the SPI peripheral */
  SPI_Cmd(SPIx, ENABLE);
  /* Enable NSS output for master mode */
  SPI_SSOutputCmd(SPIx, ENABLE);
  /* TIM Capture Compare DMA Request enable */
  TIM_DMACmd(TIMx, TIMx_DMA_CHANNEL, ENABLE);
  while (1)
    /* DMA channel Rx of SPI Configuration */
    DMA_InitStructure.DMA_BufferSize = (uint16_t)1;
    DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t)SPIx_DR_ADDRESS;
    DMA_InitStructure.DMA_MemoryBaseAddr = (uint32_t) &CommandReceived;
    DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC;
    DMA_InitStructure.DMA_Priority = DMA_Priority_High;
    DMA_Init(SPIx_RX_DMA_CHANNEL, &DMA_InitStructure);
    /* DMA TIM trigger channel Configuration */
    DMA_InitStructure.DMA_MemoryBaseAddr = (uint32_t) &CommandTransmitted;
    DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralDST;
    DMA_InitStructure.DMA_Priority = DMA_Priority_Low;
    DMA_Init(TIMx_CHANNEL_DMA_CHANNEL, &DMA_InitStructure);
    /* Enable the SPI Rx DMA request */
    SPI_I2S_DMACmd(SPIx, SPI_I2S_DMAReq_Rx, ENABLE);
    /* Clear the RxBuffer */
    Fill_Buffer(RxBuffer, TXBUFFERSIZE);
    PressedButton = Read_Joystick();
    while (PressedButton == JOY_NONE)
    switch (PressedButton)
      /* JOY_RIGHT button pressed */
      case JOY_RIGHT:
        CommandTransmitted = CMD_RIGHT;
        NumberOfByte = CMD_RIGHT_SIZE;
        break;
      /* JOY_LEFT button pressed */
      case JOY_LEFT:
        CommandTransmitted = CMD_LEFT;
        NumberOfByte = CMD_LEFT_SIZE;
        break;
      /* JOY_UP button pressed */
      case JOY_UP:
        CommandTransmitted = CMD_UP;
        NumberOfByte = CMD_UP_SIZE;
        break;
      /* JOY_DOWN button pressed */
      case JOY_DOWN:
        CommandTransmitted = CMD_DOWN;
        NumberOfByte = CMD_DOWN_SIZE;
        break;
      /* JOY_SEL button pressed */
      case JOY_SEL:
        CommandTransmitted = CMD_SEL;
        NumberOfByte = CMD_SEL_SIZE;
        break;
      default:
        break;
    /* Enable the DMA channel */
    DMA_Cmd(SPIx_RX_DMA_CHANNEL, ENABLE);
    /* Enable DMA1 TIM Trigger Channel */
    DMA_Cmd(TIMx_CHANNEL_DMA_CHANNEL, ENABLE);
    /* TIM enable counter */
    TIM_Cmd(TIMx, ENABLE);
    /* Wait the SPI DMA Rx transfer complete or time out*/
    TimeOut = USER_TIMEOUT;
    while ((DMA_GetFlagStatus(SPIx_RX_DMA_FLAG_TC) == RESET)&&(TimeOut != 0x00))
    if(TimeOut == 0)
       TimeOut_UserCallback();
    /* The BSY flag can be monitored to ensure that the SPI communication is complete.
       This is required to avoid corrupting the last transmission before disabling
       the SPI or entering the Stop mode. The software must first wait until TXE=1
       and then until BSY=0.*/
    while ((SPI_GetFlagStatus(SPIx, SPI_I2S_FLAG_TXE) == RESET)&&(TimeOut != 0x00))
    if(TimeOut == 0)
    while ((SPI_GetFlagStatus(SPIx, SPI_I2S_FLAG_BSY) == SET)&&(TimeOut != 0x00))
    if(TimeOut == 0)
    /* Clear DMA1 global flags*/
    DMA_ClearFlag(TIMx_CHANNEL_DMA_FLAG_GL);
    DMA_ClearFlag(SPIx_RX_DMA_FLAG_GL);
    /* disable the DMA channels */
    DMA_Cmd(SPIx_RX_DMA_CHANNEL, DISABLE);
    DMA_Cmd(TIMx_CHANNEL_DMA_CHANNEL, DISABLE);
    /* disable the SPI Rx DMA request */
    SPI_I2S_DMACmd(SPIx, SPI_I2S_DMAReq_Rx, DISABLE);
    /* TIM disable counter */
    TIM_Cmd(TIMx, DISABLE);
    if (CommandReceived == CMD_ACK)
      DMA_InitStructure.DMA_BufferSize = (uint16_t)NumberOfByte;
      DMA_InitStructure.DMA_MemoryBaseAddr = (uint32_t)RxBuffer;
      /* DMA channel Tx of SPI Configuration */
      DMA_InitStructure.DMA_MemoryBaseAddr = (uint32_t)TxBuffer;
      /* Wait the SPI Rx DMA transfer complete or time out */
      if(TimeOut == 0)
      if(TimeOut == 0)
      if(TimeOut == 0)
      /* Clear DMA1 global flags */
      /* Disable the DMA channels */
      /* Disable the SPI Rx and Tx DMA requests */
      switch (NumberOfByte)
        /* CMD_RIGHT command received */
        case CMD_RIGHT_SIZE:
          if ((Buffercmp(TxBuffer, RxBuffer, CMD_RIGHT_SIZE) != FAILED) && (CommandReceived == CMD_ACK))
            /* Turn ON LED2 and LED3 */
            STM_EVAL_LEDOn(LED2);
            STM_EVAL_LEDOn(LED3);
            /* Turn OFF LED4 */
            STM_EVAL_LEDOff(LED4);
          break;
        /* CMD_LEFT command received */
        case CMD_LEFT_SIZE:
          if ((Buffercmp(TxBuffer, RxBuffer, CMD_LEFT_SIZE) != FAILED) && (CommandReceived == CMD_ACK))
            /* Turn ON LED4 */
            STM_EVAL_LEDOn(LED4);
            /* Turn OFF LED2 and LED3 */
            STM_EVAL_LEDOff(LED2);
            STM_EVAL_LEDOff(LED3);
          break;
        /* CMD_UP command received */
        case CMD_UP_SIZE:
          if ((Buffercmp(TxBuffer, RxBuffer, CMD_UP_SIZE) != FAILED) && (CommandReceived == CMD_ACK))
            /* Turn ON LED2 */
            /* Turn OFF LED3 and LED4 */
          break;
        /* CMD_DOWN command received */
        case CMD_DOWN_SIZE:
          if ((Buffercmp(TxBuffer, RxBuffer, CMD_DOWN_SIZE) != FAILED) && (CommandReceived == CMD_ACK))
            /* Turn ON LED3 */
            /* Turn OFF LED2 and LED4 */
          break;
        /* CMD_SEL command received */
        case CMD_SEL_SIZE:
          if ((Buffercmp(TxBuffer, RxBuffer, CMD_SEL_SIZE) != FAILED) && (CommandReceived == CMD_ACK))
            /* Turn ON LED2, LED3 and LED4 */
          break;
        default:
          break;
#endif /* SPI_MASTER */
  /* Slave board configuration -----------------------------------------------*/
#ifdef SPI_SLAVE
  SPI_I2S_DeInit(SPIx);
  SPI_InitStructure.SPI_Mode = SPI_Mode_Slave;
  CommandTransmitted = CMD_ACK;
  /* Infinite Loop */
  while (1)
    DMA_InitStructure.DMA_BufferSize = 1;
    DMA_Init(SPIx_TX_DMA_CHANNEL, &DMA_InitStructure);
    /* Enable the SPI Rx and Tx DMA requests */
    SPI_I2S_DMACmd(SPIx, SPI_I2S_DMAReq_Tx, ENABLE);
    /* Enable the DMA channels */
    DMA_Cmd(SPIx_TX_DMA_CHANNEL, ENABLE);
    /* Wait the SPI DMA transfers complete or time out */
    while (DMA_GetFlagStatus(SPIx_RX_DMA_FLAG_TC) == RESET)
    while ((DMA_GetFlagStatus(SPIx_TX_DMA_FLAG_TC) == RESET)&&(TimeOut != 0x00))
    if(TimeOut == 0)
    if(TimeOut == 0)
    if(TimeOut == 0)
    DMA_ClearFlag(SPIx_TX_DMA_FLAG_GL);
    DMA_Cmd(SPIx_TX_DMA_CHANNEL, DISABLE);
    /* Disable the SPI peripheral */
    SPI_Cmd(SPIx, DISABLE);
    SPI_I2S_DMACmd(SPIx, SPI_I2S_DMAReq_Tx, DISABLE);
    switch (CommandReceived)
      case CMD_RIGHT:
        break;
      case CMD_LEFT:
        break;
      case CMD_UP:
        break;
      case CMD_DOWN:
        break;
      case CMD_SEL:
        break;
      default:
        break;
    DMA_InitStructure.DMA_BufferSize = NumberOfByte;
    if(TimeOut == 0)
    if(TimeOut == 0)
    if(TimeOut == 0)
        if (Buffercmp(TxBuffer, RxBuffer, CMD_RIGHT_SIZE) != FAILED)
          /* Turn OFF LED4 */
        break;
      case CMD_LEFT_SIZE:
        if (Buffercmp(TxBuffer, RxBuffer, CMD_LEFT_SIZE) != FAILED)
          /* Turn ON LED4 */
        break;
      case CMD_UP_SIZE:
        if (Buffercmp(TxBuffer, RxBuffer, CMD_UP_SIZE) != FAILED)
          /* Turn ON LED2 */
        break;
      case CMD_DOWN_SIZE:
        if (Buffercmp(TxBuffer, RxBuffer, CMD_DOWN_SIZE) != FAILED)
          /* Turn ON LED3 */
        break;
      case CMD_SEL_SIZE:
        if (Buffercmp(TxBuffer, RxBuffer, CMD_SEL_SIZE) != FAILED)
        break;
      default:
        break;
#endif /* SPI_SLAVE */
  * @brief  Configures the SPI Peripheral.
  * @param  None
  * @retval None
  RCC_APB2PeriphClockCmd(SPIx_CLK, ENABLE);
  /* Enable the DMA peripheral */
  RCC_AHBPeriphClockCmd(DMAx_CLK, ENABLE);
  /* Enable the TIM peripheral */
  RCC_APB1PeriphClockCmd(TIMx_CLK, ENABLE);
  /* Enable SCK, MOSI, MISO and NSS GPIO clocks */
  RCC_AHBPeriphClockCmd(SPIx_SCK_GPIO_CLK | SPIx_MISO_GPIO_CLK | SPIx_MOSI_GPIO_CLK |
                        SPIx_NSS_GPIO_CLK , ENABLE);
  /* Enable TIM DMA trigger clock */
  RCC_AHBPeriphClockCmd(TIMx_TRIGGER_GPIO_CLK, ENABLE);
  /* SPI pin mappings */
  GPIO_PinAFConfig(SPIx_SCK_GPIO_PORT, SPIx_SCK_SOURCE, SPIx_SCK_AF);
  GPIO_PinAFConfig(SPIx_MOSI_GPIO_PORT, SPIx_MOSI_SOURCE, SPIx_MOSI_AF);
  GPIO_PinAFConfig(SPIx_MISO_GPIO_PORT, SPIx_MISO_SOURCE, SPIx_MISO_AF);
  GPIO_PinAFConfig(SPIx_NSS_GPIO_PORT, SPIx_NSS_SOURCE, SPIx_NSS_AF);
  /* TIM capture compare pin mapping */
  GPIO_PinAFConfig(TIMx_TRIGGER_GPIO_PORT, TIMx_TRIGGER_SOURCE, TIMx_TRIGGER_AF);
  GPIO_InitStructure.GPIO_PuPd  = GPIO_PuPd_DOWN;
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_40MHz;
  /* SPI SCK pin configuration */
  GPIO_InitStructure.GPIO_Pin = SPIx_SCK_PIN;
  GPIO_Init(SPIx_SCK_GPIO_PORT, &GPIO_InitStructure);
  /* SPI  MOSI pin configuration */
  GPIO_InitStructure.GPIO_Pin =  SPIx_MOSI_PIN;
  GPIO_Init(SPIx_MOSI_GPIO_PORT, &GPIO_InitStructure);
  /* SPI MISO pin configuration */
  GPIO_InitStructure.GPIO_Pin = SPIx_MISO_PIN;
  GPIO_Init(SPIx_MISO_GPIO_PORT, &GPIO_InitStructure);
  /* SPI NSS pin configuration */
  GPIO_InitStructure.GPIO_Pin = SPIx_NSS_PIN;
  GPIO_Init(SPIx_NSS_GPIO_PORT, &GPIO_InitStructure);
  /* Configure the TIM channelx capture compare as DMA Trigger */
  GPIO_InitStructure.GPIO_Pin =  TIMx_TRIGGER_PIN;
  GPIO_Init(TIMx_TRIGGER_GPIO_PORT, &GPIO_InitStructure);
  /* SPI configuration -------------------------------------------------------*/
  SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex;
  SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b;
  SPI_InitStructure.SPI_CPOL = SPI_CPOL_Low;
  SPI_InitStructure.SPI_CPHA = SPI_CPHA_1Edge;
  SPI_InitStructure.SPI_NSS = SPI_NSS_Hard;
  SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_2;
  SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;
  SPI_InitStructure.SPI_CRCPolynomial = 7;
  /* DMA Configuration -------------------------------------------------------*/
  DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Byte;
  DMA_InitStructure.DMA_MemoryDataSize =  DMA_MemoryDataSize_Byte;
  DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
  DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
  DMA_InitStructure.DMA_Mode = DMA_Mode_Normal;
  DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
* @brief  Basic management of the timeout situation.
* @param  None.
* @retval None.
  /* User can add his own implementation to manage TimeOut Communication failure */
  /* Block communication and all processes */
  while (1)
  * @brief  Configure a SysTick Base time to 10 ms.
  * @param  None
  * @retval None
  /* Setup SysTick Timer for 10ms interrupts  */
  if (SysTick_Config(SystemCoreClock / 100))
    /* Capture error */
    while (1);
  /* Configure the SysTick handler priority */
  NVIC_SetPriority(SysTick_IRQn, 0x0);
  * @brief  Compares two buffers.
  * @param  pBuffer1, pBuffer2: buffers to be compared.
  * @param  BufferLength: buffer's length
  * @retval PASSED: pBuffer1 identical to pBuffer2
  *         FAILED: pBuffer1 differs from pBuffer2
  while (BufferLength--)
    if (*pBuffer1 != *pBuffer2)
      return FAILED;
    pBuffer1++;
    pBuffer2++;
  return PASSED;
#ifdef SPI_MASTER
  * @brief  Configures the TIM Peripheral.
  * @param  None
  * @retval None
  TIM2 Configuration: generate 1 PWM signals with 50% duty cycle.
    The TIM2CLK frequency is set to SystemCoreClock (Hz), to get TIM2 counter
    clock at 32 MHz the Prescaler is computed as following:
     - Prescaler = (TIM2CLK / TIM2 counter clock) - 1
    SystemCoreClock is set to 32 MHz for Ultra Low Power Medium-density devices.
    The TIM2 is running at 4 KHz: TIM2 Frequency = TIM2 counter clock/(TIM2_ARR + 1)
                                                  = 32 MHz / (TIM2_ARR +1) = 4 KHz
                                                 ==> TIM2_ARR + 1 = 8000
    TIM2 Channel2 duty cycle = (TIM2_CCR4/ TIM2_ARR)* 100 = 50%
    ==> TIM2_CCR4 = TIM2_ARR/2 = 4000
  /* Compute the prescaler value */
  PrescalerValue = (uint16_t) (SystemCoreClock / 32000000) - 1;
  /* Time base configuration */
  TIM_TimeBaseStructure.TIM_Period = TIM_ARR;
  TIM_TimeBaseStructure.TIM_Prescaler = PrescalerValue;
  TIM_TimeBaseStructure.TIM_ClockDivision = 0;
  TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
  TIM_TimeBaseInit(TIMx, &TIM_TimeBaseStructure);
  /* TIM PWM1 Mode configuration: Channel */
  TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;
  TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
  TIM_OCInitStructure.TIM_Pulse = TIM_CCR;
  TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;
  TIMx_CHANNEL_INIT(TIMx, &TIM_OCInitStructure);
* @brief  Reads key from evaluationboard.
* @param  None
* @retval Return JOY_RIGHT, JOY_LEFT, JOY_SEL, JOY_UP, JOY_DOWN or JOY_NONE
  /* "JOY_RIGHT" key is pressed */
  if (!STM_EVAL_PBGetState(BUTTON_RIGHT))
    while (STM_EVAL_PBGetState(BUTTON_RIGHT) == RESET)
    return JOY_RIGHT;
  /* "JOY_LEFT" key is pressed */
  if (!STM_EVAL_PBGetState(BUTTON_LEFT))
    while (STM_EVAL_PBGetState(BUTTON_LEFT) == RESET)
    return JOY_LEFT;
  /* "JOY_UP" key is pressed */
  if (!STM_EVAL_PBGetState(BUTTON_UP))
    while (STM_EVAL_PBGetState(BUTTON_UP) == RESET)
    return JOY_UP;
  /* "JOY_DOWN" key is pressed */
  if (!STM_EVAL_PBGetState(BUTTON_DOWN))
    while (STM_EVAL_PBGetState(BUTTON_DOWN) == RESET)
    return JOY_DOWN;
  /* "JOY_SEL" key is pressed */
  if (!STM_EVAL_PBGetState(BUTTON_SEL))
    while (STM_EVAL_PBGetState(BUTTON_SEL) == RESET)
    return JOY_SEL;
  /* No key is pressed */
  else
    return JOY_NONE;
  * @brief  Fills buffer.
  * @param  pBuffer: pointer on the Buffer to fill
  * @param  BufferLength: size of the buffer to fill
  * @retval None
  uint16_t index = 0;
  /* Put in global buffer same values */
  for (index = 0; index < BufferLength; index++ )
    pBuffer[index] = 0x00;
#endif
#ifdef  USE_FULL_ASSERT
  * @brief  Reports the name of the source file and the source line number
  *         where the assert_param error has occurred.
  * @param  file: pointer to the source file name
  * @param  line: assert_param error line source number
  * @retval None
void assert_failed(uint8_t* file, uint32_t line)
  /* User can add his own implementation to report the file name and line number,
     ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  /* Infinite loop */
  while (1)
#endif
/************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
火木 回答时间:2012-8-9 17:33:15
回复:stm32L系列如何配置SPI?
学习啦,好强大
liuqs-359554 回答时间:2012-8-18 11:04:26
RE:stm32L系列如何配置SPI?【悬赏问答】
你试试通过了程序验证你就明白SPI咋配置了,几乎所有的内部带SPI的MCU配置都是差不多的,有几个主要参数,设置本器件为主机或者从机,SPI时钟(主机需要,从机被动接受),时钟极性和时钟相位(这两个不好理解,仔细看看SPI协议有帮助),不过不理解也没事,反正就4种情况,总有一个是对的,还有发送和接收函数,就是看是否发完了,是否接收到了,再者进中断!
建议先试试两个MCU用SPI通信,先从一个主一个从开始,这个弄好了,最起码可以加深理解SPI!
