STM32对AD9854的操作【悬赏问答】
nowitzkizyh 提问时间:2012-8-13 23:11 /
想通过STM32控制AD9854,产生一路正弦波和一路余弦波的程序。谢谢!
赞 收藏 评论3 发布时间:2012-8-13 23:11
3个回答
火木 回答时间:2012-8-14 18:24:38
回复:STM32对AD9854的操作【悬赏问答】
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
const uint16_t Sine12bit[32] = {2047, 2447, 2831, 3185, 3498, 3750, 3939, 4056, 4095, 4056,
                      3939, 3750, 3495, 3185, 2831, 2447, 2047, 1647, 1263, 909,
                      599, 344, 155, 38, 0, 38, 155, 344, 599, 909, 1263, 1647};
uint32_t DualSine12bit[32];
uint8_t Idx = 0;
/* Private function prototypes -----------------------------------------------*/
void RCC_Configuration(void);
void GPIO_Configuration(void);
void Delay(__IO uint32_t nCount);
/* Private functions ---------------------------------------------------------*/
  * @brief  Main program.
  * @param  None
  * @retval : None
int main(void)
  /* System Clocks Configuration */
  RCC_Configuration();
  /* Once the DAC channel is enabled, the corresponding GPIO pin is automatically
     connected to the DAC converter. In order to avoid parasitic consumption,
     the GPIO pin should be configured in analog */
  GPIO_Configuration();
  /* TIM8 Configuration */
  /* Time base configuration */
  TIM_TimeBaseStructInit(&TIM_TimeBaseStructure);
  TIM_TimeBaseStructure.TIM_Period = 0x19;
  TIM_TimeBaseStructure.TIM_Prescaler = 0x0;
  TIM_TimeBaseStructure.TIM_ClockDivision = 0x0;
  TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
  TIM_TimeBaseInit(TIM8, &TIM_TimeBaseStructure);
  /* TIM8 TRGO selection */
  TIM_SelectOutputTrigger(TIM8, TIM_TRGOSource_Update);
  /* DAC channel1 Configuration */
  DAC_InitStructure.DAC_Trigger = DAC_Trigger_T8_TRGO;
  DAC_InitStructure.DAC_WaveGeneration = DAC_WaveGeneration_None;
  DAC_InitStructure.DAC_OutputBuffer = DAC_OutputBuffer_Disable;
  DAC_Init(DAC_Channel_1, &DAC_InitStructure);
  /* DAC channel2 Configuration */
  DAC_Init(DAC_Channel_2, &DAC_InitStructure);
  /* Fill Sine32bit table */
  for (Idx= 0; Idx
zykzyk-93033 回答时间:2012-8-14 20:23:20
RE:STM32对AD9854的操作【悬赏问答】
这个例程很多的啊。找找
nowitzkizyh 回答时间:2012-8-15 22:39:28
谢谢
