请教 这个错误 是怎么回事
guanjianguo 提问时间:2009-2-6 13:43 /
Building configuration: LX-29 - Debug
Updating build tree...
main2.c
iccarm.exe F:\C_ARM\lx29\gpio\project\application\main2.c -D VECT_TAB_FLASH -o F:\C_ARM\lx29\gpio\project\Debug\
Obj\ -z6 --no_unroll --no_inline --no_tbaa --no_scheduling --debug --cpu_mode thumb --endian little --cpu cortex-M3
--stack_align 4 -e --fpu None --dlib_config C:\Program Files\Embedded Workbench 4.0 Evaluation\ARM\LIB\dl7mptnnl8n.h
-I F:\C_ARM\lx29\gpio\project\application\ -I F:\C_ARM\lx29\gpio\project\..\library\inc\ -I C:\Program Files\Embedded
Workbench 4.0 Evaluation\ARM\INC\
   IAR ARM ANSI C/C++ Compiler V4.42A/W32 EVALUATION
   Copyright 1999-2005 IAR Systems. All rights reserved.
 1 338 bytes of CODE  memory (+ 692 bytes shared)
    12 bytes of CONST memory
 3 122 bytes of DATA  memory
Errors: none
Warnings: none
Linking
xlink.exe F:\C_ARM\lx29\gpio\project\Debug\Obj\ATT7022C_SPI.r79 F:\C_ARM\lx29\gpio\project\Debug\Obj\
ATT7022C_compute_b.r79 F:\C_ARM\lx29\gpio\project\Debug\Obj\ATT7022C_xb.r79 F:\C_ARM\lx29\gpio\project\Debug\
Obj\FM24C16_1C.r79 F:\C_ARM\lx29\gpio\project\Debug\Obj\ISL12022M_1C.r79 F:\C_ARM\lx29\gpio\project\Debug\Obj\
ISL12022M_function.r79 F:\C_ARM\lx29\gpio\project\Debug\Obj\LCD_xs_function1.r79 F:\C_ARM\lx29\gpio\project\
Debug\Obj\LCD_xs_function11.r79 F:\C_ARM\lx29\gpio\project\Debug\Obj\LCD_xs_function2.r79 F:\C_ARM\lx29\gpio\
project\Debug\Obj\LCD_xs_function3.r79 F:\C_ARM\lx29\gpio\project\Debug\Obj\LCD_xs_function4.r79 F:\C_ARM\lx29\
gpio\project\Debug\Obj\LCD_xs_function5.r79 F:\C_ARM\lx29\gpio\project\Debug\Obj\LCD_xs_hard.r79 F:\C_ARM\lx29\
gpio\project\Debug\Obj\LCD_zk_GPIO.r79 F:\C_ARM\lx29\gpio\project\Debug\Obj\USART_function.r79 F:\C_ARM\lx29\
gpio\project\Debug\Obj\cortexm3_macro.r79 F:\C_ARM\lx29\gpio\project\Debug\Obj\data_set.r79 F:\C_ARM\lx29\gpio\
project\Debug\Obj\data_set_check.r79 F:\C_ARM\lx29\gpio\project\Debug\Obj\jy_E.r79 F:\C_ARM\lx29\gpio\project\Debug\
Obj\jy_E1.r79 F:\C_ARM\lx29\gpio\project\Debug\Obj\jy_E2.r79 F:\C_ARM\lx29\gpio\project\Debug\Obj\jy_E3.r79 F:\
C_ARM\lx29\gpio\project\Debug\Obj\main2.r79 F:\C_ARM\lx29\gpio\project\Debug\Obj\set_clear_e.r79 F:\C_ARM\lx29\
gpio\project\Debug\Obj\set_data1.r79 F:\C_ARM\lx29\gpio\project\Debug\Obj\set_data2.r79 F:\C_ARM\lx29\gpio\project\
Debug\Obj\set_t1.r79 F:\C_ARM\lx29\gpio\project\Debug\Obj\set_t2.r79 F:\C_ARM\lx29\gpio\project\Debug\Obj\set_t3.r79
F:\C_ARM\lx29\gpio\project\Debug\Obj\set_t4.r79 F:\C_ARM\lx29\gpio\project\Debug\Obj\set_t5.r79 F:\C_ARM\lx29\gpio\
project\Debug\Obj\stm32f10x_exti.r79 F:\C_ARM\lx29\gpio\project\Debug\Obj\stm32f10x_flash.r79 F:\C_ARM\lx29\gpio\
project\Debug\Obj\stm32f10x_gpio.r79 F:\C_ARM\lx29\gpio\project\Debug\Obj\stm32f10x_i2c.r79 F:\C_ARM\lx29\gpio\
project\Debug\Obj\stm32f10x_it.r79 F:\C_ARM\lx29\gpio\project\Debug\Obj\stm32f10x_iwdg.r79 F:\C_ARM\lx29\gpio\
project\Debug\Obj\stm32f10x_lib.r79 F:\C_ARM\lx29\gpio\project\Debug\Obj\stm32f10x_nvic.r79 F:\C_ARM\lx29\gpio\
project\Debug\Obj\stm32f10x_rcc.r79 F:\C_ARM\lx29\gpio\project\Debug\Obj\stm32f10x_spi.r79 F:\C_ARM\lx29\gpio\
project\Debug\Obj\stm32f10x_systick.r79 F:\C_ARM\lx29\gpio\project\Debug\Obj\stm32f10x_tim.r79 F:\C_ARM\lx29\gpio\
project\Debug\Obj\stm32f10x_usart.r79 F:\C_ARM\lx29\gpio\project\Debug\Obj\stm32f10x_vector.r79 F:\C_ARM\lx29\gpio\
project\Debug\Obj\stm32f10x_wwdg.r79 -o F:\C_ARM\lx29\gpio\project\Debug\Exe\LX-29.d79 -l F:\C_ARM\lx29\gpio\
project\Debug\List\LX-29.map -xms -IF:\C_ARM\lx29\gpio\project\EWARM\lnkarm_flash.xcl\ -f C:\Program Files\
Embedded Workbench 4.0 Evaluation\ARM\config\lnkarm.xcl -rt C:\Program Files\Embedded Workbench 4.0 Evaluation\
ARM\LIB\dl7mptnnl8n.r79 -Osimple-code=F:\C_ARM\lx29\gpio\project\Debug\Exe\LX-29.sim -s __program_start
     IAR Universal Linker V4.60I/386
     Copyright 1987-2007 IAR Systems. All rights reserved.
Error[e16]: Segment INTVEC (size: 0xec align: 0x2) is too long for segment definition. At least 0xac more bytes needed.
The problem occurred while processing the segment placement command "-Z(CODE)INTVEC=00-3F", where at the
moment of placement the available memory ranges were "CODE:0-3f"
   Reserved ranges relevant to this placement:
   0-3f                 INTVEC
Total number of errors: 1
Total number of warnings: 0
赞 收藏 评论3 发布时间:2009-2-6 13:43
3个回答
萧星-96138 回答时间:2009-2-6 14:14:50
RE:请教 这个错误 是怎么回事
options--linker---config 里面的xcl文件 路径自己找一下
guanjianguo 回答时间:2009-2-6 14:37:58
RE:请教 这个错误 是怎么回事
谢谢2楼, 好了
  我将文件夹换了个位置, options--linker---config 里面的xcl文件 路径不对了,指向了IAR的目录下的xcl文件了.
whb565938 回答时间:2011-3-11 11:40:36
回复:请教 这个错误 是怎么回事
我感觉文件有冲突
