stm32 Usart DMA中断,无法进去DMA中断函数,求解?? 【悬赏问答】
Hust-400285 提问时间:2012-11-9 11:02 /
使用usart2, 对应的DMA中断是RX_DMA DMA1_CHN6,TX_DMA DMA1_CHN7
现在的问题是,数据的收发都是可以的,通过DMA的BUF和电脑的串口调试工具连接,能够正常收发。
但是,始终无法进去中断处理函数(DMA1_Channel6_IRQHandler, DMA1_Channel7_IRQHandler)。
求高手指点,我现在用的库是V3.5????
附主要代码:
//-----------初始化
UsartApiConfigRCC();
    UsartApiConfigNVIC();
    UsartApiConfigGPIO();
    UsartApiConfigDMA();
    UsartApiConfigInit();
    /* Enable USARTy DMA TX request */
  USART_DMACmd(USARTz, USART_DMAReq_Tx, ENABLE);
  /* Enable USARTz DMA TX request */
  USART_DMACmd(USARTz, USART_DMAReq_Rx, ENABLE);
  /* Enable USARTy */
  USART_Cmd(USARTz, ENABLE);
  /* Enable USARTy DMA TX Channel */
  DMA_Cmd(DMA_CHN_RX, ENABLE);
static void UsartApiConfigNVIC()
    /* Configure the NVIC Preemption Priority Bits */
    NVIC_PriorityGroupConfig(NVIC_PriorityGroup_0);
    /* Enable the USARTy Interrupt */
    NVIC_InitStructure.NVIC_IRQChannel = USARTy_IRQn;
    /* Enable the USARTz Interrupt */
    NVIC_InitStructure.NVIC_IRQChannel = USARTz_IRQn;
    NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;
    NVIC_InitStructure.NVIC_IRQChannel = DMA1_Channel6_IRQn;
    NVIC_InitStructure.NVIC_IRQChannel = DMA1_Channel7_IRQn;
static void UsartApiConfigDMA()
    DMA_InitTypeDef DMA_InitStructure;
    //DMA_InitTypeDef DMA_InitStructure;
    /* USARTz_Tx_DMA_Channel (triggered by USARTz Tx event) Config */
    DMA_DeInit(DMA_CHN_RX);
    DMA_InitStructure.DMA_PeripheralBaseAddr = (u32)&USARTz->DR;//USARTz_DR_Base;
    DMA_InitStructure.DMA_MemoryBaseAddr = (uint32_t)g_sDmaRxBuf;
    DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC;//接受方向
    DMA_InitStructure.DMA_BufferSize = sizeof(g_sDmaRxBuf);
    DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
    DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
    DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Byte;
    DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_Byte;
    DMA_InitStructure.DMA_Mode = DMA_Mode_Normal;
    DMA_InitStructure.DMA_Priority = DMA_Priority_VeryHigh;
    DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
    DMA_Init(DMA_CHN_RX, &DMA_InitStructure);
    DMA_ITConfig(DMA_CHN_RX, DMA_IT_TC, ENABLE);
//-------------中断函数
void DMA1_Channel6_IRQHandler(void)// DMA Rx Interrupt (Usart2)
    STM_EVAL_LEDToggle(LED2);
void DMA1_Channel7_IRQHandler(void)// DMA Tx Interrupt (Usart2)
    g_iUsartSendFlag = E_FLAG_OFF;
    DMA_Cmd(DMA_CHN_TX, DISABLE);
    UsartJudgeDataToSend();
//----------STARTup
                DCD     DMA1_Channel1_IRQHandler  ; DMA1 Channel 1
                DCD     DMA1_Channel2_IRQHandler  ; DMA1 Channel 2
                DCD     DMA1_Channel3_IRQHandler  ; DMA1 Channel 3
                DCD     DMA1_Channel4_IRQHandler  ; DMA1 Channel 4
                DCD     DMA1_Channel5_IRQHandler  ; DMA1 Channel 5
                DCD     DMA1_Channel6_IRQHandler  ; DMA1 Channel 6
                DCD     DMA1_Channel7_IRQHandler  ; DMA1 Channel 7
赞 收藏 评论7 发布时间:2012-11-9 11:02
7个回答
Hust-400285 回答时间:2012-11-9 11:34:56
回复:stm32 Usart DMA中断,无法进去DMA中断函数,求解???
有大侠,指点一下吗?
废鱼 回答时间:2012-11-9 16:00:27
我刚才测试官方例程是可以的,你可以参考一下:
DMA_Interrupt.rar
15.31 KB, 下载次数: 584
xiaodc88 回答时间:2012-11-9 21:22:57
RE:stm32 Usart DMA中断,无法进去DMA中断函数,求解?? 【悬赏问答】
用官方的例程改吧,我一般先用官方的例程跑一遍,再慢慢改,最后就一定成功了,哈哈
zykzyk-93033 回答时间:2012-11-9 22:52:53
还是DMA得中断没有设置好。你看看例程。
xieyuanfu 回答时间:2012-11-11 23:25:59
回复:stm32 Usart DMA中断,无法进去DMA中断函数,求解?? 【悬赏问答】
 那是因为 你只是 使能了 DMA   你还没有 进行DMA  中断的相关 配置啊
怎么会进中断呢    楼主 要配置 下面 这个函数 就会进中断了
void DMA_ITConfig(DMA_Channel_TypeDef* DMAy_Channelx, uint32_t DMA_IT, FunctionalState NewState)
  /* Check the parameters */
  assert_param(IS_DMA_ALL_PERIPH(DMAy_Channelx));
  assert_param(IS_DMA_CONFIG_IT(DMA_IT));
  assert_param(IS_FUNCTIONAL_STATE(NewState));
  if (NewState != DISABLE)
    /* Enable the selected DMA interrupts */
    DMAy_Channelx->CCR |= DMA_IT;
  else
    /* Disable the selected DMA interrupts */
    DMAy_Channelx->CCR &= ~DMA_IT;
aw76 回答时间:2013-1-24 14:40:55
回复第 3 楼 于2012-11-09 16:00:27发表:
Volcanoscar 回答时间:2014-7-15 14:46:56
